Robotic brake noise...part 2?
Results 1 to 10 of 18
Thread: Robotic brake noise...part 2?
    titan2782 is offline [OP]
    titan2782's Avatar
    Nov 2011
    SoCal
    2,018
    There is another thread on this, but no one posted an audio file. I've been noticing this noise in the last 2 weeks and it's happening all the time now. when the brakes are applied while the engine is at low speeds or idle (may occur all the time, but can't tell due to road noise) there comes a robotic servo noise that will continue for 2-3 seconds even if I take my foot off the brake. It happens EVERY time i put pressure on the brake pedal and if I pump the pedal, I can get the noise to continue on forever.
    I'm at just under 45k and i've only heard this noise in the last few weeks so it isn't "something these cars do". It's very noticeable inside the cabin with windows rolled up and even when music is playing (low volume).
    Ideas? Maybe vacuum issue or low fluid? I haven't investigated as of yet.
    Audio 1: https://www.dropbox.com/s/31ws6avmbj...oice%20002.mp4
    In a drive thru (kind of noisy outside)
    Audio 2: https://www.dropbox.com/s/e80ksay5p1...oice%20003.mp4
    In my garage with car running
    Have to turn the volume up.
    2014 Genesis Coupe 3.8 R-Spec Hidden Content
    2005 SRT4 ACR
    2011 Cruze Eco: Gone
    Handbrake Released kobowm's Avatar
    Jan 2013
    twin falls, idaho
    196
    They are called electric pumps...... They pump brake fluid to the brakes.... Its 100% completely normal.
    Sent from my Galaxy Nexus
    titan2782's Avatar
    Nov 2011
    SoCal
    2,018
    No, it isn't normal. During initial start up from 1 mile until ~44k miles the robotic noise happens during and only during the initial key switch. Now it happens both when I press the pedal AND release and does not matter if the engine is running or not.
    I topped off my fluid, it was about 1/2 way but that didn't help. If I remove the plug from the valve on the brake booster, there is no more noise and brakes work ok...at low speed. Since I only have manuals for the engine, I can't tell you if that means anything or not (probably doesn't).
    Taking it in to have it looked at. Will report back.
    2005 SRT4 ACR
    Handbrake Released phantomknight321's Avatar
    Jan 2013
    Houston, Texas
    153
    I hear this quite often as well, but i only have almost 16k miles. Let me know if you find anything out about it
    Past: 2012 Cruze LT Auto
    Current: 2014 Hyundai Veloster Turbo
    Nov 2012
    Akron, Ohio
    252
    It almost sounds like the a valve fluttering in a vacuum hose, too. Kind of like a pcv valve or an evap solenoid.
    titan2782's Avatar
    Nov 2011
    SoCal
    2,018
    kobowm is correct in saying it's "normal" however, it's only been normal during first start when I flick the key to the on position all this time. I always thought it was the fuel pump (since all my other cars did this as well). Didn't realize it was the brakes.
    I'll report what they tell me.
    2005 SRT4 ACR
    titan2782's Avatar
    Nov 2011
    SoCal
    2,018
    Alright so the 1.4's have an extra vacuum pump to compensate. The service tech said I should bring it in. Have to wait for my PCV pipe to come in before I do it so it will be next week sometime.
    2005 SRT4 ACR
    12,852
    I heard this noise once when I turned off the car and turned it back on.
    Yeah, shouldn't be doing that all the time.
    A lot of turbo VVT motors have these pumps to compensate for there being a total lack of vacuum at a cold, high idle with the timing off "normal" settings.
    12,852
    HOWEVER I wonder if the pump is running just because you have a vacuum leak to make up for the lost vacuum to the brake booster? You said youre waiting on a PCV hose? Perhaps that's all it is and it will stop as soon as you fix that problem.
    titan2782's Avatar
    Nov 2011
    SoCal
    2,018
    I'll check if that's the issue, but I doubt it. I've sealed it all up (maybe) and the pump is running even when the car is off which i know for a fact didn't happen because I regularly push my car out of the garage when cleaning it (I don't like to start it just to move it 15ft then turn it off).
    2005 SRT4 ACR
  1. Brake Noise - is this an official Cruze quirk?
    By thaicruze in forum General Discussion
    Last Post: 07-19-2014, 08:49 AM
  2. Brake noise
    By bryanakron40 in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 05-02-2013, 03:04 AM
  3. Robotic brake noise!!!
    By AkiRaw in forum Gen1 1.4L Turbo
    Last Post: 01-04-2013, 02:18 AM
  4. Brake hissing/vibration noise
    By 12blkrs in forum Gen1 Service Issues
    Last Post: 12-06-2012, 04:22 PM
  5. Electronic Brake Noise
    By Popadopolis in forum Gen1 Audio & Electronics
    Last Post: 11-02-2012, 11:16 AM
