2011 Chevy Cruze traction control button functions
Results 1 to 10 of 18
Thread: 2011 Chevy Cruze traction control button functions
    cerbomark is offline [OP]
    upstate, NY
    255
    FYI/ When you push the button on the shifter console it shuts off the traction control and you ll see the light on in the dash. When you again push and hold that button down for a few seconds it shuts off the stability control also and a seperate light will come on in the dash. I was playing around in the snow when I came across these funtions and didn t know if you all were aware.
    1st Gear CRUISE-CRUZE's Avatar
    USA
    306
    Interesting, I didn’t know that! Could you shut off just the stability control?
    4,339
    ...in the Owners Manual, see pages:
    5-18 = Traction OFF light
    5-19 = Traction Control System (TCS)/StabilTrak Light (STL)
    9-32 = Traction Control System.
    2009 Pontiac Vibe 1.8L/SFI 4A
    2004 Pontiac Vibe 1.8L/MFI 4A
    1971 Dodge Charger 318 3A
    1968 Dodge Charger 383 3A
    upstate, NY
    255
    Quote Originally Posted by CRUISE-CRUZE View Post
    try it and you ll see the lights..
    Jan 2011
    11
    Hi, newbie here. I'd like to know what "stability control" and "traction control" mean in terms of the mechanical operation of the vehicle. Edit- sorry, should have done my googling first:
    Traction Control
    Stability Control
    But are there any situations where you could benefit by turning one or both of those features off?
    Thanks
    Retired Moderator shawn672's Avatar
    Oct 2010
    Rochester, NY - Charlotte, NC
    2,475
    Quote Originally Posted by Paul7893 View Post
    Also, are there any situations where you could benefit by turning one or both of those features off?
    Thanks
    Traction control is a system that allows a vehicle to send power away from wheels that are slipping. It is useful to get a little more grip in slippery conditions, but most systems are limited to lower speeds.
    Stability control is a system that detects the movement and speed of the vehicle. If it senses the car begin to swerve or spin, it helps to compensate to allow the driver to keep control of the vehicle.
    Most stability control systems will include traction control, since the hardware is essentially the same. On the other hand, many vehicles have traction control but not stability control, which is more expensive to add.
    Traction control vs. Stability control - Car Seat.Org - Carseat, Vehicle & Child Passenger Safety Forums
    The only time you'd really want to disable it is at the Track or if you're feeling frisky and need to do some kind of maneuver on the road - most people wont touch the button their whole life
    Handbrake Released Knightslugger's Avatar
    Jan 2011
    167
    or if you need the tires to spin... like snow.
    2004 Trailblazer LS 4.2L 4WD
    2006 Honda CBR600RR (CCS #907 MW Race bike)
    237
    RTFM.
    In the manual it states that if you get stuck in the snow, and need to rock the car back and forth by going into drive and reverse back and forth until you are unstuck, you should turn off traction control first.
    spacedout's Avatar
    SW Wisconsin
    6,921
    Quote Originally Posted by shawn672 View Post
    That may be true about most people, but every car I have had with TC I find that trying to get up my really steep & long snowy driveway I need to disable traction control or I will end up backing all the way down(driveway is about 150ft long & 50ft elevation change).
    With traction control on you'll be making it up the driveway really well then all of a sudden the TC comes on & you loose half your momentum. once this happens the TC comes on again you pretty much loose all your momentum & are just sitting there spinning/sliding back down.
    I also don't like it in city driving(though not as bad as above example), taking off across an intersection & the TC comes on half way across, again loosing half your momentum almost making you almost come to a stop dangerously in the intersection. I can do much better with my own foot.
    The only time I like TC is at hwy speeds & you hit some deep snow/water, the car cuts power & keeps you going very well on your desired path.
    Oct 2010
    2,475
    Quote Originally Posted by spacedout View Post
    Totally agreed. When I said "most people" I meant the typical consumer and the "newbie" asking what TC was. I disable it from time to time usually at stopped snowy/slushy intersections
  1. Need Cruise Control for my Chevy Cruze LS
    By MWCOOL in forum General Discussion
    Last Post: 09-04-2016, 02:47 AM
  2. Stabilitrac/Traction control Problem
    By yyzcruzer in forum Gen1 Powertrain
    Last Post: 01-13-2012, 06:52 PM
  3. Chevy cruze push start button
    By Chefmaster87 in forum Gen1 Audio & Electronics
    Last Post: 08-24-2011, 04:19 PM
  4. LTZ - w/auto climate control - rear defog button not working
    By bochey1314 in forum General Discussion
    Last Post: 04-27-2011, 05:32 PM
  5. Traction control
    By Flag City Cruzer in forum General Discussion
    Last Post: 04-20-2011, 07:56 PM
