cam sensor problems
Results 1 to 9 of 9
Thread: cam sensor problems
    Robrsa is offline [OP]
    4
    cam sensor problems
    My engine light keeps coming on and the codes are PO 0016 and PO 0340 The car has been in several times to the agents and despite replacing the cam sensor ,they cant sort it out.They have been fiddling with cams and checking cam timing .The car runs fine and and I have to keep clearing the DTC s.the model is a ls 1.6 l
    Does anyone have any ideas
    5,163
    We don't have a 1.6 liter engine in these cars.
    Also, I'd start checking wiring to the sensor. It's possible something got messed up near the sensor pigtail and connector.
    1st Gear The_Madcat's Avatar
    South Central Wisconsin
    391
    We do actually have a 1.6 in the cruze.
    Chevrolet Cruze - Wikipedia, the free encyclopedia
    How many miles on the engine? I have seen these things on other cars when the timing components are off kilter. The sensor may be just fine but if the timing components are offset, the sensor will see the cam/crank in an unexpected position and kick off the CEL.
    4
    Definitely a 1.6 It's a year old and has 68000 kms on it
    Nov 2012
    Akron, Ohio
    252
    Could be wiring, computer, component, or related components. Replacement didn't work. Is the timing set correctly? The dealer should have tests in the shop manual to show if the sensor or computer is bad or if the signals are making it over the wiring.
    You say it runs fine, so timing may bot be an issue. Although, the parameters may be small enough that even if the timing is out a little, it will still run ok.
    5,163
    Quote Originally Posted by Robrsa View Post
    Ahh, we don't get that engine in the States.
    Madcat, thanks for the link. I'd forgotten about the engine choices in other markets.
    Almost sounds like the timing belt skipped a tooth, and the engine computer's getting really mad about it. The VVT might be able to compensate for that while throwing a code for a cam sensor. I think somebody needs to time the engine to make sure it didn't skip a tooth, or that something is wrong with the timing belt.
    22,616
    Quote Originally Posted by sciphi View Post
    Rosbrsa - where are you? North America only has the 1.8 and 1.4T engines. Also, I second the wiring option. If the sensor isn't getting correct power (voltage and current) it will fail intermittently even though there is nothing wrong with your car or the sensor itself.
    Hidden Content Hidden Content
    2002 Pont Montana AWD (traded for 2012 LS @182K miles - title transferred to son on college graduation)
    4
    The timing is confirmed correct I'm in Cape Town South Africa
    391
    I would think what Ober said is the next logical step. Might have the dealership run some tests on it if it is still under warranty.
  11. Remove Advertisements
  1. Replies: 76
    Last Post: 10-22-2016, 05:20 PM
  2. Help.... asap!! map sensor
    By cruzeSRB in forum Gen1 Powertrain
    Last Post: 07-11-2013, 12:03 PM
  3. Mass Airflow Sensor
    By nickys68chevy in forum Gen1 Powertrain
    Last Post: 10-29-2012, 04:49 PM
  4. Rain Sensor
    By krinksta in forum Gen1 Audio & Electronics
    Last Post: 09-26-2012, 07:09 PM
  5. Help.... asap!! map sensor
    By cruzeSRB in forum General Discussion
    Last Post: 03-11-2012, 02:07 PM
