rust issues
Results 1 to 9 of 9
Like Tree3Likes
  • 1 Post By sciphi
  • 1 Post By brian v
  • 1 Post By sciphi
Thread: rust issues
    Junior Member
    Nov 2011
    evansville in
    24
    Question rust issues
    i have had my 2012 chevy cruze since november and am noticing some rust on some of the under body parts such as the drive axles brakes (which is normal), parts of the alloy wheels and various other parts. just wondering if anyone has done anything to prevent, or treat these rust issues any help would be great because i want to keep my cruze running and looking good for a long time
    Senior Member XtremeRevolution's Avatar
    SW Chicago Suburbs
    2,307
    Quote Originally Posted by emmaiden2005 View Post
    Aluminum wheels don't rust. If you have anything on there, its either rusted brake pad material, or dirt.
    You won't be able to do a whole lot to keep from some bare metal parts from rusting, but the car does have a corrosion warranty that should prevent any significant rust from popping up.
    Senior Member
    316
    This
    Junior Member
    Nov 2011
    evansville in
    24
    how long is that warranty good for?
    Senior Member
    Southern Tier, NY
    1,140
    Drive axles rusting on the shaft is not a big issue. It's happened before with every other car I've owned. Brake rotors rusting is normal.
    XtremeRevolution likes this.
    2012 Chevrolet Cruze Eco
    Member
    32
    Blog Entries
    1
    OK brother here is some help
    wash your car more often winter brings on new issues with metal midwest uses salt so rinse undereeath body often
    for added protection puchase a gallon of WD 40 or comperable lubricant spray all metals you can underneath
    this will put a film over parts and helps protect metals from corrosive salts and such welcome to the rust belt
    emmaiden2005 likes this.
    Senior Member
    Southern Tier, NY
    1,140
    I used Fluid Film on the Fit for the previous two winters. The Cruze got the same treatment before this winter. I removed every single underbody panel I could, and sprayed Fluid Film over the body panels. I got inside the door and trunk seams, too. Anywhere there was a gap got Fluid Filmed. I used 80 fluid ounces of it on each car. It's still there 4 months later.
    Junior Member
    Nov 2011
    evansville in
    24
    Quote Originally Posted by brian v View Post
    Quote Originally Posted by sciphi View Post
    thanks guys that is just the kind of answers i was looking for ... was going to look into zeebart maybe even tarring it but this sounds easier and more cost effective
    Senior Member
    Southern Tier, NY
    1,140
    The Fluid Film is something that needs to be applied every year. 12 cans is about $90 shipped. A Cruze will take 4 cans. So it's about $30 a year and a few hours of time to DIY it. If you have an air compressor, I'd get the application gun they sell, a gallon of FF, and use that for years.
  11. Remove Advertisements
  1. RUST already in door sill!!!
    By kkilburn in forum Appearance and Body
    Last Post: 10-24-2011, 07:43 PM
  2. Rust in paint.
    By Crewz in forum Service Issues
    Last Post: 10-24-2011, 08:17 AM
  3. Rust spots on new 2012
    By Chris.P in forum Appearance and Body
    Last Post: 09-21-2011, 09:13 AM
  4. Rust Protection
    By CHUV in forum Chevrolet Cruze General Discussion Forum
    Last Post: 09-13-2011, 02:09 PM
  5. Rust!
    By 72buickgs in forum Engine and Technical Discussion
    Last Post: 05-02-2011, 08:41 AM
