Bilstein B8 : The sweet spot
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
Like Tree10Likes
Thread: Bilstein B8 : The sweet spot
    Poje is online now [OP]
    4th Gear Poje's Avatar
    Aug 2012
    Canada
    796
    Lightbulb Bilstein B8 : The sweet spot
    History of my suspension : Stock, then installed UR bars, then installed Pedders Xa coil-overs, then removed some UR bars, then installed Camber bolts and 15mm H&R spacers, then went back to stock shocks but with H&R springs and then installed Bilstein B8 shocks and kept the H&R springs.
    Some of you may remember i was one of the few back in the day that actualy raced on a local racetrack, did some lapping and calibrated my coil-overs for months b4 i was very satisfied. The trouble is, after that year of joy and incredible handling, they broke in the following winter. (I don't think Pedders thought they would be used in -30c weather...)
    So i changed to H&R springs + stock shocks... It didnt take me long to realise that it wasnt a good combo : They bottomed-out way too often in normal driving and when pushing the car, it was even worst. (The reduction of wheel travel with underdamped shocks doesnt work at all.)
    It was either buy another set of Coil-overs or try to find another solution and i did : Bilstein B8.
    These shocks are made especialy to work with Sport springs : They are shortened and the damping is increased.
    In one word : WOW.
    No more bottoming-out, increased confort, increased body control and handling. Im super satisfied!
    For someone like me who use his car all year, in the winter and with the bad roads we have in Quebec, this is the sweet spot.
    PS : - 1st pic you see the B8. Notice how thick is the shaft compared to our stock shocks.
    - 2nd pic installed. List of stuff you see : H&R springs, Bilstein B8, Eiback camber bolt, ZZP 12" brake kit, H&R 15mm spacers and Moog endlink.
    - Alignment : -1.6 of camber, 0 of toe-in, stock caster, stock rear alignment and 32lbs in tires.
    2015 Cruze Diesel White : Tinted windows, de-badged, Fleece tune and downpipe, PTP Turbo Blanket, Intake mod, 3M black gloss roof and Plastidip diffuser, Bilstein B8 shocks, PZero tires.
    2014 Cruze Diesel Red : Stock.
    2012 Cruze RS Silver (Sold)
    2nd Gear 170-3tree's Avatar
    Nov 2014
    louisburg, ks
    481
    Cool! Thanks for this. I'm making a shopping list now. Hopes and dreams ya know? I was looking at the b12 kit. But still thinking kw maybe. Our season stops in October and starts in April.
    Thought about shims on the rear??
    Aug 2012
    Canada
    796
    Quote Originally Posted by 170-3tree View Post
    Ya, i thought about it, but its not necesary. The rear is stable and the stock alignment is ok. The only thing i may add in the rear in the futur is a Whiteline swaybar, but i like the way the car is driving right now.
    Nov 2014
    louisburg, ks
    481
    I've thought about a sway bar back there, but that might jump my class as well. Doing the b12 kit, not the coilovers, costs just a smidge more than the springs and just front struts.
    Aug 2012
    Canada
    796
    The B12 kit would be a very good choice!
    Just went on a road trip and im very impressed how good those B8s are. Knowing what i know now, for sure i would have installed that right at the start.
    Nov 2014
    louisburg, ks
    481
    It looks good. My concern is that under dampered rears might cause chopped rear tires or even slight cupping. I see it all day long on compact cars with bad rear shocks. If it helps reduce weight transfer on starts it wouldn't hurt anything either. I wish they'd make the sportlines honestly, but they'd have done it if they were going to.
    Aug 2012
    Canada
    796
    If you order the B12 you will have front and back shocks.
    Nov 2014
    louisburg, ks
    481
    That's my goal, and why I think it looks like the best option without coilovers. But I've got time to get off the fence on the subject.
    Nov 2014
    louisburg, ks
    481
    Also!!! What do you think of those spacers? Did you have to mess with the studs?
    Aug 2012
    Canada
    796
    I wouldnt touch the back if i were you. Just install the B12 kit, do a normal alignment and see how you like it.
  1. Sweet Spot Exhaust Tubing Size?
    By Lindan in forum Gen1 1.4L Turbo
    Last Post: 11-03-2014, 03:47 PM
  2. bilstein b8 + eiback springs vs coilovers bilstein b14 pss
    By nosidefcp in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 08-09-2012, 08:33 PM
  3. Mileage sweet spot
    By StoneCrab in forum Fuel Economy
    Last Post: 05-01-2012, 09:18 AM
  4. Fuel Economy "sweet spot"
    By ErikBEggs in forum Fuel Economy
    Last Post: 03-22-2012, 11:52 PM
  5. The Sweet Spot
    By Quazar in forum Fuel Economy
    Last Post: 05-18-2011, 10:04 AM
