2012 TPMS relearn
Results 1 to 10 of 12
Like Tree4Likes
Thread: 2012 TPMS relearn
    1st Gear silverram323's Avatar
    Cambridge, MN
    335
    2012 TPMS relearn
    So i searched, and most are saying for the 2012 you have to buy this EL-50448 tool, anyone find a way around this?
    My 2011 will do it using the deflate learning process, my 2012 don't.
    HIS 2012 Topaz Blue LT 1.4T 6 spd Auto
    HERS 2011 Crystal Red LT 1.4T 6 spd Auto
    OUR Weekend Warrior 95 12V Dodge ram Cummins Diesel
    Our HOG 2014 Street Glide 103" motor
    Feb 2012
    Bucks County, PA
    70
    I rotated the tires on my 2012 yesterday and tried the deflate learning procedure. It didn't work on my car. I really didn't expect it to work but I gave it a try anyhow. I went on the internet and it seems as though the EL-50448 tool is the lowest cost option to reset it yourself. I almost ordered one. Then I came to my senses! What did I do before the TPMS system? I checked the tire pressure every month or so. Now the TPMS system will alert me if a tire is low. That's a good thing. It just won't tell me exactly which tire is low. No big deal. If I forgot how I rotated the tires, just check them all as I did a few years ago.
    I had a Hyundai with a TPMS system. It didn't identify the specific tire that was low. Just that one of the tires were low. Basically no different than the Cruze without the correct pairing.
    jdubb11 likes this.
    ive wondered why people are worried about those sensors. if the car alerts you get out and look at ALL four tires and i bet u can tell which tire is low
    23,025
    Until I got my first Cruze, my TPMS only worked once a month on Saturday morning.
    Hidden Content Hidden Content
    2002 Pont Montana AWD (traded for 2012 LS @182K miles - title transferred to son on college graduation)
    1st Gear Gritts's Avatar
    Jan 2011
    Virginia
    269
    To reset TPMS
    1. Remove ALL four of the plastic tire valve caps before you get started.
    2. Use the owner's manual instructions on how to get to the TPMS screen on the DIC
    3. Start letting air out with front driver tire valve. Horn will sound when sensor detected
    4. Next procede to front passenger tire valve. Again horn will sound when sensor det.
    5. Procede down side of car to rear passenger tire valve and deflate. Again horn will sound when sensor det.
    6. Go around rear of car to driver side rear tire and repeat above. Horn will sound.
    Once this is done re-inflate tires starting with the tire whose PSI reading is flashing on the DIC. Reinflate the next tire with the flashing PSI indicator and so on.
    Worked first time for me.
    God put obvious limitations on our intelligence...but none whatsoever on our stupidity.
    23,025
    Unfortunatly GM decided that at some point in the 2012 model firmware build this needed to be removed. It appears all the 2011s work with the tire deflation method and some 2012s do as well.
    5,163
    It works on my 2012 built August 2011.
    Patman's Avatar
    Cincinnati, Oh
    4,150
    Quote Originally Posted by jdubb11 View Post
    My 2002 -2004 Aleros had a TPMS system that had nothing to do with knowing which wheel caused the problem. it just alerted you to a problem and you had to actually get out of the car and determine which one(s) were causing the problem. FWIW manually checking tire pressure is the best way of doing things. Just use the TPMS as a guide to let you know if there is a problem or not!
    jdubb11 likes this.
    Jul 2011
    Hot Springs, AR
    720
    Even on a 2011 there can be problems. I attempted to retrain mine and the first tire worked but the second tire didn't get a horn beep and when I looked at the dash I had a message saying to service the tpms. I took it to the dealer and they reset it with the tool no problem.
    The reason GM changed is there can be interference if there's another GM car parked nearby. My 2010 GMC pickup was only a few feet away when I tried the air deflation procedure and I guess that created the problem.
    Patman's Avatar
    Cincinnati, Oh
    4,150
    I just found out my 2012 Eco does not do the pressure drop thing! Guess I will just have to check to make sure it the pressure is good. unless I buy the EL 50448. But I doubt I will. I just did my first change and rotation for my 2012. Kinda difficult to get the jack under the front of the eco with the air dam! Even harder with the 16 inch spare on the car! Even for the side of the car!.
  1. TPMS new tool..only $62..manual relearn gone?
    By jlalill in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 11-01-2012, 04:25 PM
  2. TPMS Question
    By Lightz39 in forum Gen1 Service Issues
    Last Post: 05-30-2012, 11:40 AM
  3. TPMS Needs to be Serviced?
    By sbickmeyer in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 03-13-2012, 10:41 PM
  4. Tpms sensors
    By hkfez in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 03-04-2012, 03:14 PM
  5. TPMS Reads low?
    By danimal in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 10-31-2011, 02:43 PM
