Tire pressure
Results 1 to 10 of 10
Thread: Tire pressure
    Fleetwood, PA
    97
    Tire pressure
    About 3 weeks ago DIC alerted me that my rear passenger side tire was at 26 PSI. This went on daily for a week after i filled air back to 36-37 PSI- fill on way home from work, then by next day went down to 26psi.
    Now it is holding steady at 35-36. At the time I thought it was a slow leak, but now have no idea. Any thoughts?
    Thanx
    • 1981 Ford F-100 3 Spd OD MT
    • 1994 Ford Ranger 5 Spd MT
    • 2001 Kia Sephia 5 Spd MT
    • 2011 Cruze Eco 6 Spd MT
    2nd Gear WHITECO's Avatar
    Lethbridge Alberta
    532
    And this is why I hate TPMS cause of those problems.
    You will have to take it to the dealership to see if they can fix it, but they most likely won't be able to and it will annoy the **** out of you forever!!
    4,337
    THOUGHT: there's a battery in each TPM device located in each wheel, maybe that one (right rear) wasn't firmly "seated" at first?
    2009 Pontiac Vibe 1.8L/SFI 4A
    2004 Pontiac Vibe 1.8L/MFI 4A
    1971 Dodge Charger 318 3A
    1968 Dodge Charger 383 3A
    Fleetwood, PA
    97
    the guage on the air pump confirmed the pressure reading from the DIC, so the tire was loosing air.
    Apr 2011
    Hamilton, Ontario, Canada
    113
    Quote Originally Posted by usaalways View Post
    Air pump gauges are notoriously inaccurate (buy a tire pressure gauge and keep in glove box).... but if the tire is loosing air get it in the water tank and find the leak if you can't see a screw etc. stuck in it....
    Burt
    Apr 2011
    15
    It is possible that the valve stem is slightly bad. Perhaps on one day, after you checked the tire pressure, the needle seated better than on previous occasions. You can get a tool that changes out the needle (plus new needles) at an auto parts place or just go to a local tire shop and have the valve stem changed.
    NBrehm's Avatar
    Jun 2011
    Whaley Lake, NY
    2,136
    Could be a puncture but if it isn't leaking now I doubt it. Try pushing gently down on the valve stem and see if it leaks at the bottom (do not push too hard, this is part of the TPMS sensor!). Otherwise it could be there was dirt in the bead, or the bead wasn't properly seated and that dirt may have fallen out our the bead may have seated when you re-filled the tire.
    Nick
    USAF
    2011 Cruze Eco
    1988 Pontiac Trans Am GTA Hidden Content
    In the recent past:
    2002 Trans Am WS6 346CI of unbridled fury! 469RWH/434RWTQ 11.01 @ 123MPHHidden Content You will be missed!
    2005 Subaru Legacy GT 309WHP/357RWTQ 12.21 @ 113
    2000 Subaru Impreza RS 203WHP/201WTQ 14.2 @ 103
    3rd Gear Macman's Avatar
    644
    mine just showed one tire low, the next day is went back above normal. odd, I'm hoping for a number of updates with a firmware update to fix so many small issues.
    Fleetwood, PA
    97
    update
    when I took the eco to get an oil change they found a slow leak and plugged it.
    Handbrake Released Caballero777's Avatar
    Jun 2011
    Houston, Texas
    104
    I had the same issue, not even 4 days after I purchased my 2011 Cruze LTZ. I kept adding air that would last a day or 2. I kept checking the tire for nails, but could not see anything till I finally took it to a local tire shop and behold a screw had punctured the inside of the tire where I could not see.
    I would just take it to your local tire shop and have them check it out.
  1. Tire Pressure sensors?
    By shawn672 in forum Service Issues
    Last Post: 01-03-2015, 09:22 PM
  2. tire pressure
    By audiophile64 in forum Wheels, Tires, Brakes, & Suspension
    Last Post: 11-02-2013, 09:08 PM
  3. Tire Pressure (LTZ profile tires)
    By ErikBEggs in forum General Discussion Forum
    Last Post: 09-04-2012, 01:28 AM
  4. Tire pressure tool
    By c6vette in forum General Discussion Forum
    Last Post: 08-27-2011, 10:40 PM
  5. Tire pressure
    By Flag City Cruzer in forum Wheels, Tires, Brakes, & Suspension
    Last Post: 04-27-2011, 09:27 AM
