Pulsing brakes - Page 4
Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 31 to 40 of 42
Like Tree3Likes
Thread: Pulsing brakes
  1. #31
    World Rally Champion
    H3LLON3ARTH's Avatar
    Texas
    4,496
    Quote Originally Posted by NBrehm View Post
    OEM rotors = junk. I haven't had any luck with OEM GM rotors not warping since I bought my TA in 2001. Every new car we have had the rotors warp on. GM uses steel from south america that has a higher tin content (as do most OEM manufacturers and the better part of chain stores for their less expensive brakes). Plus side they are cheap, downside they don't like heat so one good stop from highway speed and they can warp. I swapped mine out for EBC rotors about 4500 miles ago, pulsing went away and ahs stayed away so far.
    Last time I check with ebc they didn't have anything can you give part numbers
    Sent from my Droid using AutoGuide.Com Free App
    Hidden Content GO FOR Hidden Content
    2012 ECO 6MT
    Current Mods:
    K&N Typhoon Short Ram Intake,Tinted Windows, Custom Made Cat Back Exhaust With IMCO High Flow Muffler, Trifecta Performance Tune Plasti-dipped stock ECO rims, ZZP Down-pipe, M-Tech Shifter Shortener, 15" Incriminator Audio Subwoofer in Custom Built Box pushed by a Hifonics BRZ-2100.
  3. #32
    Blue Angel's Avatar
    Ottawa, Ontario, Canada
    4,583
    For anyone that's interested, StopTech has a whole bunch of good reading on their White Papers page:
    Technical White Papers
    Lots of good brake-related articles there, including the one I linked to above.
  4. #33
    10,998
    Some brakes specifically tell you NOT to bed them in.
    I used Akebono ceramic pads and Zimmerman rotors on my last car, and I liked them a lot - so much so that when they wore out at 90,000 miles, I went back for a 2nd set. Not a lot of dust, good stopping power when driven hard, but still good street stopping power. Occasionally there was a squeal when reversing in the rain, but that was it.
    2012 Cruze 1LT 6M
  5. #34
    NBrehm's Avatar
    Jun 2011
    Whaley Lake, NY
    2,136
    Quote Originally Posted by Blue Angel View Post
    What pads are you using?
    I put EBC Green Stuff pads and Power Slot rotors on my last Saturn after having good results with the same parts on my previous Saturn. I bedded them in properly, and took them off the car after a few months of easy street driving because they were pulsing so bad. Since I would soon be selling the car I replaced them with the cheapest pads/rotors, drove it that way for a few months and the brakes had NEVER felt better. In my experience there's been no rhyme or reason to why one set of brakes works/lasts better than another. Aftermarket parts are a total crapshoot, unless you're spending big bucks on a proven combination.
    Good or bad, at least you know what you're getting with the oem parts. In my experience, OEM has had a higher success rate than aftermarket. I've never owned a big-buck brake upgrade so I can't comment there.
    Having said all that, there's almost NOTHING worse than pulsing brakes... they remove all confidence you have in slowing the car, and it is extremely annoying to boot.
    TOUCH WOOD, my Eco's brakes have been perfect so far, but I am really easy on brakes compared to most people (look at my Fuelly report). I doubt my brakes have ever been warm let alone hot. I purposely DID NOT do a "bed-in" procedure on these brakes as I've had mixed results with that also (though I do believe a performance car that will be used as such will defenitely benefit). The one common element of bedding in your brakes is that everything gets so hot that all protective plating and/or coatings on your rotors burns off, leaving bare unprotected iron exposed to the elements. It also tends to affect the caliper finish as well. Listening to myself, it's almost a bit embarassing to be thinking this way as I usually value performance over asthetics, but a wheel full of rusty brake parts just looks terrible.
    I just went with the standard Ulti-max stuff from EBC for pads and rotors. One of the "tricks" I have always used when breaking in HP pads is put them in the BBQ, you can heat/cool them evenly for specific times. I didn't bother with these since it is just my DD but heat cycling them off the car works great. I normally use centric stuff on all my DD cars, but as of now they didn't have anything in stock for the Cruze. Best cheap pads/rotors I have ever used
    Edit: Here is the process http://www.team3s.org/FAQbrakeBBQ.htm
    Nick
    USAF
    2011 Cruze Eco
    1988 Pontiac Trans Am GTA Hidden Content
    In the recent past:
    2002 Trans Am WS6 346CI of unbridled fury! 469RWH/434RWTQ 11.01 @ 123MPHHidden Content You will be missed!
    2005 Subaru Legacy GT 309WHP/357RWTQ 12.21 @ 113
    2000 Subaru Impreza RS 203WHP/201WTQ 14.2 @ 103
  6. #35
    NBrehm's Avatar
    Jun 2011
    Whaley Lake, NY
    2,136
    Also if you use that procedure do not stand in the smoke, it can lead to health issues down the road. There is bad ju-ju in brake pads
    Nick
    USAF
    2011 Cruze Eco
    In the recent past:
  7. #36
    Blue Angel's Avatar
    4,583
    Nice! That makes a lot of sense. When I last bedded pads in on my Corvette the pad material up to about 1/8" away from the rotor face turned almost white. I would imagine based on the quick heating nature of the procedure that the bads were baked from the rotor surface in, meaning they were unevenly heated. Doing this in the BBQ would heat them evenly through the thickness of the pad. I may have to try this out!
    Have you noticed a reduction in pad deposits on the rotor using this method? One the pads are baked, I would assume a very easy low heat bedding process would suffice, just to get the pad surface worn to mate properly with the rotor? I may send the guys at Stoptech an email with these questions...
  8. #37
    NBrehm's Avatar
    Jun 2011
    Whaley Lake, NY
    2,136
    After i bake them I sand lightly with 1000 grit to clean them up, put them on and drive. No additional bedding. Unless you plane them or something they will never be perfect but the biggest things is getting the gases out. All of my pads I have done this way wore very evenly. It virtually eliminated deposits on the rotors, i normally use HAWK HPS pads or SSBC Big Bites for hi-po vehicles and they are the only ones I have BBQ'd so I can't tell you how an EBC pad with that stupid break in coating would react or other makes. Works great on those 2 though. You may need to repaint the backing plate if you go too hot, that is the only problem I have seen. Also pretty much eliminates "glazing"
    Nick
    USAF
    2011 Cruze Eco
    In the recent past:
  9. #38
    Dec 2012
    NJ
    13
    I had a 2000 Cavalier that I bought new. I had the car for 12 years. I had problems with warped rotors constantly. Started checking torque on wheel lug nuts when returning home from tire balance and rotation. I set torque on all wheels to 100 lb ft. Most shops just throw the wheels back on with air gun and the wheels are not properly torqued per the owners manual. I have had my 2012 Cruze Lt for 14000 miles so far and have had no problems. I believe that unevenly torqued wheels will lead to premature rotor warpage which will make your brakes pulse.
  10. #39
    Blue Angel's Avatar
    4,583
    Also the reason I told my buddy not to powder coat parts in his kitchen oven!
    NBrehm likes this.
  11. #40
    NBrehm's Avatar
    Jun 2011
    Whaley Lake, NY
    2,136
    Quote Originally Posted by DevilsRule View Post
    Overtorqued could, can also damage the wheel hub/bearing. I hate places that do that. I use a gun to put my wheels on, but I use the lowest setting and just snug them, then go back and hand torque them. If the torque wrench clicks on any lug without tightening it I back it off a turn and re-torque it. I've seen those idiots just hammering on the lugs with a 1/2 impact. At the very least if you get a flat you will probably not be able to get the wheel off by hand unless (like me) you keep a breaker bar in the trunk
    Nick
    USAF
    2011 Cruze Eco
    In the recent past:
  1. big brakes
    By papoose42 in forum Wheels, Tires, Brakes, & Suspension
    Last Post: 10-28-2012, 11:50 AM
  2. Brakes. Same ole same ole
    By thaicruze in forum General Discussion Forum
    Last Post: 10-17-2012, 08:08 AM
  3. Brakes work
    By obermd in forum General Discussion Forum
    Last Post: 09-21-2012, 01:24 PM
  4. Brakes
    By JGA in forum Service Issues
    Last Post: 03-22-2012, 09:56 AM
  5. Brakes
    By oldman2 in forum Powertrain
    Last Post: 08-03-2011, 01:55 PM
