How hard do y'all think it will be to add the z- link to my 2012 eco 6mt
Sent from my Droid using AutoGuide.Com Free App
http://www.youtube.com/user/H377ON3ARTH?feature=mhee
2012 ECO 6MT
Current Mods: K&N Typhoon Short Ram Intake,Tinted Windows, Custom Made Cat Back Exhaust With IMCO High Flow Muffler, Trifecta Performance Tune Plasti-dipped stock ECO rims, ZZP Down-pipe.
Future Mods: Ultra Racing Front & Rear upper strut mounts, Whiteline Front & Rear Sway Bar kits, e85 Tune and Injectors, Stage 2 clutch, Murdered out Chrome Trim Pieces,
There was a topic posted here about converting to rear disc brakes awhile back, they mentioned two different rear axles used int he cruze. Sounded like if you had a 2011-2012 1LT,2LT or LTZ(the axle with the zlink) you could convert to rear discs(only the 1LT has drums of those three).
That would mean the LS & Eco manual are using a different axle.
IN 2013 the 1LT nolonger get the zlink unless you buy the RS package.
The main beam is the same, but for what the parts would cost you would be better off looking for a complete rear axle assembly from a junkyard
Nick
USAF
www.motorcityforums.com
2011 Cruze Eco
1988 Pontiac Trans Am GTA http://www.fquick.com/garages/viewvehicle.php?id=9723
In the recent past:
2002 Trans Am WS6 346CI of unbridled fury! 469RWH/434RWTQ 11.01 @ 123MPHYou will be missed!
2005 Subaru Legacy GT 309WHP/357RWTQ 12.21 @ 113
2000 Subaru Impreza RS 203WHP/201WTQ 14.2 @ 103
2012 ECO 6MT
Found everything ill need to do rear disc and z-link for 300 without shipping so this will be my next mod. And there will be videos photos and a diy.
2012 ECO 6MT
Its held in by 4 bolts 2 in the frame rails and 2 on the axle/ spring perch, my advise buy a zlink somewhere and see where you need holes and go from there the 2011 ls has zlink so the only difference in axles could be the eco
Sent from my MB886 using AutoGuide.Com Free App
Yea I printed a install procedure from mitchell it bolts right up to the stock eco axel with one bracket and two studs into each knuckle dosnt look to hard I hope.
2012 ECO 6MT
I wouldn't think so since mine has stability trac and they should be tge same set up
2012 ECO 6MT
Nick
USAF
2011 Cruze Eco
In the recent past:
