vibration once lowered
Results 1 to 9 of 9
Thread: vibration once lowered
    Member Sheldon's Avatar
    Jul 2011
    Gold Coast, Australia
    47
    Lowered my Holden cruze SRiV by 45mm the other day, since spring installation it has got a pesky vibration at low speeds, minimal whilst taking off in first gear going straight, but when turning left of right at low speeds the car vibrates real bad.
    I just got a wheel alignment to make sure the toe is fine and narrow down the possibility of what it is. I got them to take a look. They couldn't work it out, but after chat with them we worked out its the new angle of the drive shafts and that are vibrating slightly.
    I then talked to a guy I work with and he said they had issues getting the shafts to balance properly.
    So just a heads up if your planning on lowering your cruze
    Senior Member Chefmaster87's Avatar
    Wellington FL.
    417
    That sucks to hear I really want to lower the car, really bad. Well if you hear that u can fix the vibartion please make a video or pictures on how to fix it thanks man
    Senior Member osiris10012's Avatar
    Az
    253
    I wonder if thats just an issue with the holden cruze because i have mine(cruze LT) lowered 1.6in(40.6mm) in the front and 1.2in(30.48mm) in the rear and have no vibration issues. Now granted you are about 5 mm lower in the front than i am but i would still think i would be getting the vibration issue if there was one. You may have different driveshafts in yours due to the difference in motor selection for the holden, but i am not sure. the only issue i have with mine is that the rear is creaking when i go over a speed bump and the rear tires get pushed up pretty far but while driving under normal conditions i have had no issues. I am going to try and figure this creaking out i am thinking its either my shocks or the springs rubbing on themselves. i will keep you all updated.
    Senior Member
    Kenton, OH
    140
    I doubt it is the halfshafts unless its been abused pretty bad. Could be an unbalanced tire, tire with abnormal wear before lowering, or even alignment still out. How old is the car before it was lowered? Also, when lowering, any irregularities with suspension, steering, and tires can be accentuated.
    1995 Saturn SL2-
    high compression engine w/factory parts(in progress), full custom exhaust, custom intake, and custom made short throw....got some work to be done.
    2012 Chevy Cruze LT-Blue Topaz Metallic, RS package, Injen intake, B&G springs, and more to come
    Jul 2011
    47
    Car had done 1500kms when it was lowered, currently at about 1700km mark. Not abused, wheel alignment was pretty much spot on after lowering but I had it done anyway for my peice of mind. Tyres are fine, no irregular wear and or balance issues. If it was tyres I would notice it at higher speeds aswell.
    Everything is tight and there is no clearance issues with suspension and or guard clearances.
    I am going to take the car to a driveshaft shop and have them check the balance and test the balance at the angle of when the car would be once lowered, see if they can find something.
    Senior Member
    windsor, on
    191
    since the problem appears only when turning, i would suggest a half shaft angle problem at the wheel side knuckles/ujoint, when the wheels are turned.
    Gerry
    1972 Buick GS
    2008 Saturn Astra XR
    2011 Cruze LS
    1970 Malibu L48 - gone
    Member
    98
    Usually there are 2 problems that i could think of. My car is also lowered pretty low i can only put 2 fingers in the front and only 1 in the rear. Now, my car makes kind of a thudding sounds when i slowly turn the wheel at a standstill. For your vibrations to happen, i think its because they didn't install the springs properly, or they didn't align the spring to the structs. Are your wheels stock? or they aftermarket?
    Mods: ALOT~!!!
    Jul 2011
    47
    Stock factory 17" alloys
    Springs are seated properly.
    The car vibrates going straight aswell
    Member
    Jun 2011
    51
    Had the same issue in my S40. It was slammed and the driveshafts did not like it at ALL. I also had a bitch of a time getting it to be adjusted perfectly as far as camber was concerned. Never was able to find that happy medium.
    Other common causes of this issue can be mud "in the tires" throwing off your wheel balance, and cupping of the tires (which is usually caused by the camber being off. You say the toe was checked so I'm guessing that won't be an issue.)
    I'm going to keep an eye on this thread. Please keep it updated if you encounter any more possible solutions. Good luck.
  11. Remove Advertisements
  1. ***Official Lowered Cruze Photo Thread***
    By limited360 in forum Wheels, Tires and Suspension
    Last Post: 05-12-2012, 12:22 PM
  2. Lowered Cruze Photo's
    Last Post: 12-07-2011, 12:52 PM
  3. Lowered suspension options
    By Sheldon in forum Wheels, Tires and Suspension
    Last Post: 08-21-2011, 04:56 PM
  4. MeccaTune Suspension: Lowered, installed... REVIEWED w/ Pics
    By kevin1214 in forum Wheels, Tires and Suspension
    Last Post: 06-18-2011, 01:21 AM
  5. Chevy Cruze lowered DUB style on 20's, photoshopped!
    By ChevyPower in forum Chevrolet Cruze Pictures
    Last Post: 05-05-2011, 11:48 AM
