How to Adjust Rear Drum Brakes - Page 15
Page 15 of 15 FirstFirst ... 5 13 14 15
Results 141 to 146 of 146
Like Tree76Likes
Thread: How to Adjust Rear Drum Brakes
  1. #141
    Handbrake Released ssnscruzeeco2015's Avatar
    Bridgewater, Nova Scotia
    233
    After 32000 Km, I decided it was time to check out the rear brakes. the car was bought new in late Feb 2015.
    They only needed a few clicks of adjustment... which has me convinced that all is good ad properly adjusting.
    I am entertained by the location of the backing plug. center of the rear shoe web adjacent to the hold down pin. I am guessing that is where GM techs take a heavy drift to the well worn brakes to knock the drum off.
    I also use antii-sieze on the hub surfaces of drum and threads of the hub. I use caliper lube on the sliding and threaded components of the actual braking system.
    Now for all you folks that actually enjoy doing Preventive Maintenance aside from the stuff above, you might find this interesting or crazy.
    On other cars that I have owned with drums and no means of backing off the shoes. Each time that I would go to check my brakes, which is typically each oil change. I would have the car up on stands all around, remove all the wheels, remove the rear drums.
    Find my drill and a round stone like the one attached below, and some earplugs!
    I would attach one drum to one of the front hubs of the car backwards with lugnuts clamp the other side disk so it would not rotate. an start the car and gently put it in idle first gear.
    Run the drill in the opposite direct of the rotating drum and carefully grind down the lip until it was polished down to the same level as the braking surface. For those of you that recall having turned brake rotors and drums this will instantly give you flashbacks from generated noise.
    Crazy or interesting. It is what I will be doing for this car too in about 4000 KMs. and every 24000 thereafter.
  3. #142
    Aesop
    9,898
    For rear drums, this is what the return spring looked like on the 04 Cavalier.
    Took a strong guy with the help of a boy to install this spring. Maybe the mechanics complained about it being too much work, but this spring had the power to recenter the shoes after the brakes were applied. And if the shoes do not self center, the self adjusters WILL NOT WORK.
    To adjust your brakes, all you had to do was to back up the vehicle and tap on the brake pedal. I would intentionally set my adjusters loose, my driveway has a decline, would roll backwards and could tap on the brake pedal about ten times. Each time the brake pedal would come up. This way, I knew for sure my adjusters were working.
    This is what the Cruze rear drums look like, for you older guys, not much different than used on a 41 Chevy, only difference is adding that tab on the front shoe that if the shoe clearance was sufficient, Would click down on that toothed gear a notch, then when the pedal releases, would bring it up to close that shoe gap.
    But you can see that return spring is very weak compared to what Chevy was using, practically effortless to install it. And this is the problem.
    The shoe rests at points on the backing plate, slightest bit of rust on those points can cause the shoe to drag, also the anchor points at the bottom, that prevents the shoes from self centering. Those pins and springs that hold the shoe are exactly what the 41 Chevy was using. But on these cars, the shoes, not just the rears, but all four had drum brakes. With city driving, would practically have to be adjusted every couple of thousand miles, a special tool is available for this.
    Full service gas stations use to charge a buck for this. Ha, I purchased that tool when I was like 14 years old, hmmm, like 63 years ago.
    Ha, still make it, found this on the web, too lazy to did out my camera.
    Attachment 181649
    Hmmm, 8 bucks now, think it was like 75 cents back then.
    After cleaning all the contact points of the shoes, and even for that adjuster, the best lubricant I found that works the longest is Permatex Anti-seize. That black brake grease is next to worthless, Also using this on the front calipers particular under the clips and where the pads contact them.
    Ha, take it from a guy that was doing this for over 60 years. First sign of excessive clearance is the pedal gets lower, but if you quickly hit it again, the brakes will pump up, a couple of times, will get a full pedal.
    If the pedal does not come up with pumping, have air in the system, another newly created problem with ABS. Could search for a stronger return spring that holds those two shoes together. Parking brake has to be adjusted just right so the shoes can return to their home position.
    Another new problem is the brake hoses made in China, not vulcanized properly, inside collapses acting like a check valve. sp when you release the pedal, brakes are still engaged.
  4. #143
    233
    It should be the case with this setup too, the shoes open up at the top when the brakes are applied, the level rotates, the adjuster screw should be slightly loose in between the saddles of the shoes, a click of the star wheel, and boom one little adjustment.
    I just wonder if the handbrake lever on the rear shoe is just holding everything too tight to allow play and operation of the adjuster. Looking at the pivot points of the adjuster lever and the handbrake level, and compare them to the seat locations of spring and the adjust screw, everything appears parallel
    Looking at pictures the whole handbrake level should be going back with the moving shoe, but I wonder if the handbrake cable is too tight and counter rotates against the movement of the shoe yielding zero net movement of the adjuster system.
    Spring is coming, I think I have a periodic inspection of the car coming due.
  5. #144
    Jan 2016
    Portland, Oregon
    39
    Of all things I liked about my Cruze upon first inspection at the dealership the brakes condition were not one of them. The front rotors (especially the driver's side) already had excessive wear and a slight grooving at just over 26k. So I knew it would be an issue I'd have to deal with and fairly soon.
    Thanks for sharing these posts because I too am old enough to remember "self adjusting" rear brakes. Simply by backing up many of my Chevrolet cars in the past made this easy. So on the next dry weekend I will be performing a rear brake adjustment procedure as well as adding new grease to the pivot points. Also way before it's time I will have to do a front pad replacement and either resurface or replace the rotors. I just hope I don't end up having to replace the brake hoses, man what a pain that one would be.
    Thanks again.
  6. #145
    Driver's Ed vantage08's Avatar
    Jul 2013
    Warminster, PA
    36
    I'm going to get mine up in the next few days. I bought new shoes because I can't stand the random cold/ wet braking squeal anymore. It's embarrassing. I'll check out the adjustment as well. I've never changed the rear shoes with over 50k on it and I bought it with around 24 I think but I have checked them several times with minimal wear. Maybe they weren't even working? lol.
  7. #146
    Jan 2017
    Still having trouble removing the drum
  8. Remove Advertisements
  1. Drum to Disc Brake Conversion
    By Smurfenstein in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 03-03-2016, 01:25 PM
  2. Rear Disc Brakes Conversion
    By BallingerMike in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 05-16-2014, 07:38 PM
  3. Drum brake adjustment
    By oldman2 in forum Gen1 Powertrain
    Last Post: 10-22-2012, 03:13 PM
  4. Rear disc brakes 1LT
    By pedaltheglobe in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 05-01-2012, 08:11 PM
  5. Pics of Rear Disk Brakes, Pads and Suspension
    By Caballero777 in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 07-11-2011, 11:07 PM
