Frozen windshield washer nozzles
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Like Tree2Likes
Thread: Frozen windshield washer nozzles
    spaycace is offline [OP]
    3rd Gear
    spaycace's Avatar
    Feb 2012
    Colorado
    627
    Greetings everyone!
    On my way home from work yesterday morning, I went to use the washers on my car and nothing came out at first. Then, after driving about 12 miles and getting the car to operating temp, I was at a stoplight and tried to use them again. Slush came out this time and that baffles me, because I just filled the reservoir with fluid that was supposedly good to -25 degrees, yet it was still 10 degrees outside. Is anyone else having this type of issue and if so, does anyone know if there is a TSB on it? Any help and/or suggestions would be greatly appreciated!
    "I refuse to have a battle of wits with an un-armed person" Hidden Content
    2015 Chevy Camaro SS Indy 500 Official Festival Car (#95 of 100) NOW she's happy!
    2014 Cadillac Escalade ESV Platinum AWD ... Happy Wife, Happy Life
    2013 Chevy Volt
    2009 Pontiac G8 GXP 6MT pushing 678 ponies & 718 ft/lbs to the wheels! Hidden Content
    Chicago
    779
    That hasn't happened to me yet since owning it, HOWEVER...just wait until the windshield wipers freeze to the windshield. That WILL happen!!!
    3rd Gear
    spaycace's Avatar
    Feb 2012
    Colorado
    627
    Quote Originally Posted by iCruze2 View Post
    Well, maybe not if I can't get any fluid out of the washers!
    2013 Chevy Volt
    Chicago
    779
    Quote Originally Posted by spaycace View Post
    WRONG!!! lol, when it rains/snows, they freeze to the window..inevitable unfortunately :/
    5,163
    Sounds like cheap fluid. Was it the cheap blue stuff, or a more expensive fluid?
    Also, there was probably some old fluid in the lines still that froze until the new fluid reached it. If you filled with summer-only solution previously and only recently needed to refill, that could be an issue also.
    titan2782 likes this.
    12,670
    That's why you put 'em up in the air whenever it's going to snow!
    iCruze2 likes this.
    22,622
    If your car got wet recently and you hadn't used your washers in a while you could have gotten a small amount of water in the nozzle itself.
    Hidden Content Hidden Content
    2002 Pont Montana AWD (traded for 2012 LS @182K miles - title transferred to son on college graduation)
    spacedout's Avatar
    SW Wisconsin
    6,886
    Seeing where the fill is for the washer bottle indicates it hangs on the outside of the engine compartment. That means when driving the container does get some windchill effect. If you tank was not fully empty even a little summer washer fluid will drastically change the cold weather performance.
    My last car had a very similar location & even the -25 stuff would turn to slush. If you buy the -35 washer fluid it would not do it. Another option you added a bit more methyl alcohol(also known as methanol). This is the active ingredient in the yellow bottles of 'heat' brand gas line antifreeze. This is the same thing they add to the washer fluid to give it the lower rating.
    spacedout's Avatar
    SW Wisconsin
    6,886
    I use Prestone de-icer washer fluid that has a -34 rating. Here's a link to amazon but there price is ridiculous. think its under $4 at walmart.
    Amazon.com: WASHER FLUID DE-ICER -- GALLON: Automotive
    3rd Gear evo77's Avatar
    Sep 2011
    Zion, IL
    668
    You need to purge all the old fluid out of the resovoir.
    What I did was this:
    - pull the wiper fuse from the relay box under the hood.
    - disconnect the single rubber line that attaches to the T connector for the spray nozzles.
    - insert this line into a large empty bottle.
    - key on the ignition power (dont start vehicle)
    - press the lever in the cabin which releases windshield fluid (this will purge all the fluid into your empty bottle)
    Be sure to unrelease lever for fluid once you see there isnt anymore shooting out or until the sound pitch of the fluid motor starts to increase. You dont want to burn it out.
    - reconnect rubber line to plastic T
    - reinsert wiper fuse
    ........2012 Cruze Eco - 6AT........
  1. How-to: Add Windshield Washer Fluid
    By sciphi in forum Gen1 Diesel How-To & DIY Library
    Last Post: 08-04-2015, 07:50 PM
  2. Windshield Washer Gripes...
    By digitick in forum General Discussion
    Last Post: 01-31-2013, 10:23 AM
  3. Windshield Washer Fluid - Quick Question
    By Dwnshft in forum Gen1 Service Issues
    Last Post: 09-27-2012, 10:19 PM
  4. Frozen trunk latch
    By CHUV in forum Gen1 Service Issues
    Last Post: 01-02-2012, 12:12 PM
  5. No Washer Fluid Low Message
    By regnant in forum General Discussion
    Last Post: 02-24-2011, 12:02 PM
