Excessive engine vibration?
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Like Tree3Likes
Thread: Excessive engine vibration?
    14,615
    Has anyone had this issue? I'm noticing what may be excessive engine vibration on my 2012 Cruze Eco MT. My wife can feel the engine's vibration in the floorboards of the car when I accelerate past about 1600RPM. It sounds like I have an mild aftermarket exhaust or an exhaust resonator removed, but the whole system is completely stock. I even put the intake duct back in (which I removed to bypass the intake resonator), to make 100% sure that wasn't it, and that's not it.
    I've also heard this before when an engine mount went bad. The vibration causes an exhaust-like noise. There's also noticeable vibration in the steering wheel when accelerating, especially below 1500RPM. I don't recall it being quite as bad before.
    I checked the engine mounts over and couldn't see anything wrong from the surface. With previous cars, I could tell when they went bad because they were hydraulic and the fluid/grease just explodes and leaves a huge mess, but these seem to be solid rubber.
    Any ideas what it could be? I'll have the dealer look into it when I drop it off hopefully this week to have the front strut assemblies replaced.
    1st Gear zr1000a1's Avatar
    Southwest OH
    281
    My guess would be a heat shield. At certain rpm, vibration and resonance causes the feel and noise. Check along firewall and body, and around the cats. Sometimes the catalytic converter's own shield (or outside casing) comes lose and vibrates. Might also be making contact with exhaust. Check exhaust hangers and rubber bushings. Might need a little adjustment. Noise and vibration might only be around a certain rpm, when it hits a certain resonance, then goes away by 1900-2100 rpm or so. Hopefully there are no exhaust leaks or bad gaskets along the intake and exhaust track, causing vibration and idling problems.
    Tougher to do engine mount checks with a manual. With an automatic it is easy to observe excessive play by observing engine while putting in reverse and then drive a couple times while checking for movement. Sometimes power braking a little will also help while checking. With a manual, might be able to have someone observe from side of car (watching toes and side mirror) while checking in first gear with clutch engagement and disengagement a few times, then repeat in reverse.
    A slight coil or plug misfire might cause more noticeable vibration at certain rpm's, but I think you would probably feel that at idle too.
    Edit:
    The way the turbo is incorporated into the manifold might transmit more vibration and resonance if impeller is slightly out of balance or bearing is a little out of spec, but I doubt that you could feel it, unless exhaust is rubbing against the shields. Even then, I doubt it, and there would be other noise noticeable throughout rpm range.
    Good luck.
    XtremeRevolution likes this.
    14,615
    Quote Originally Posted by zr1000a1 View Post
    Edit:
    Good luck.
    Thanks. I drove it a bit more today and isolated the problem between 1700 and 1800RPM. When the car was cold, it caused a pretty loud vibration somewhere in front of the passenger area, either in the dash or somewhere near the firewall. As the car warmed up, that noise went away, but you could still hear a distinct vibration around those RPMs. Just curious if anyone else had this kind of issue.
    I'll just have the dealer take care of it.
    Chevy Customer Care's Avatar
    Oct 2011
    Detroit, Michigan
    5,708
    XtremeRevolution,
    I would like you to keep me posted on the outcome of your visit to the dealership. They will be in the best position to get this issue properly diagnosed for you. If you have any further questions please feel free to message me.
    Thank you,
    14,615
    Quote Originally Posted by Chevy Customer Service View Post
    XtremeRevolution,
    Thank you,
    Thanks.
    I've been in close contact with GM regarding my first issue with this car; the front suspension popping noise. I'm waiting for the part to be delivered. I understand they were ordered last week with an ETA of 5-12 days. Not sure if you are in the same office, but I've been working with a lady named Rachel, service request number 71-1035532273.
    I will be calling back and filing another case if the dealership gives me absolutely any trouble with this problem. Thank you for keeping up to date on our issues Stacy. Your presence is very much appreciated.
    14,615
    I have an appointment set up for tomorrow at 8:00 to have them replace the strut assemblies on the car, which arrived today, and will drive around a dealer technician to explain this problem. I will report back on the exact cause and remedy when that is determined.
    14,615
    Well, I'm not sure what happened, but the vibration is gone. It could have been related to the strut issue I was having, as that may allow the vibrations to be transferred into the car more easily through the wheel bearing. I will update this thread if the problem comes back, but today was fairly cold out and the car was butter smooth.
    Oct 2011
    Detroit, Michigan
    5,708
    XtremeRevolution,
    I am very happy to hear that you are not experiencing this issue any longer. If it does come back please let me know. I hope you are able to do nothing but enjoy your Cruze now!
    Thank you,
    1st Gear gt_cristian's Avatar
    360
    I am having a similar issue on a 2013 LT A/T. When the engine is cold, it vibrates right before each gear change after 1800 rpm. On the highway I hear a constant BRRRR comming from the engine compartement (passenger side).
    I managed to record this vibration : a little at 9s and very clear at 54s. The engine was already warm when I got this.
    23,024
    I had this with my Lancer. It turned out to be ice build up in the front wheel wells that was interfering with the struts and springs. Once the ice melted the vibration went away. Had you been driving in snow and ice before this started?
    Hidden Content Hidden Content
    2002 Pont Montana AWD (traded for 2012 LS @182K miles - title transferred to son on college graduation)
  1. Rear end vibration
    By gunner22 in forum Gen1 Service Issues
    Last Post: 06-26-2016, 12:36 PM
  2. vibration once lowered
    By Sheldon in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 09-04-2011, 11:26 PM
  3. strong vibration
    By cruzeman in forum Gen1 Service Issues
    Last Post: 08-23-2011, 04:16 PM
  4. Vibration during start up
    By Calintz in forum Gen1 Service Issues
    Last Post: 08-18-2011, 01:01 PM
  5. Cruze engine and Saturn Astra engine
    By 72buickgs in forum Gen1 Powertrain
    Last Post: 03-21-2011, 05:38 PM
