The first is that whenever I plug in my iPhone 4S (with the latest iOS) it'll play a song for a few seconds and then say "Please Try Again Later". The only thing I can do from here is select the "OK" option. I can no longer play Bluetooth music at this point and trying the USB results in the same thing happening. Resetting my phone, turning off the MyLink system, unpairing the device and even turning off the engine does nothing. This has been happening since May of last year. More than likely caused by an iOS update, but I can't be the only one with this issue. Any suggestions?
The second problem I have, is that my key fob has not been operating correctly the past few months. I have to press the lock/unlock button multiple times before it responds. Sometimes it works from 30 feet away on 1 try, but most of the time I have stand in front of my car and hit the button upwards of 20 times for the desired effect. Yes, I've changed the battery in the fob. Twice. Any ideas?
Which iPhone? It could be a combo of hardware and software. For example, I have an iPhone 5 always updated to latest iOS update and have not experienced any of these. But possibly an iPhone 5s or 6 may experience different problems since their hardware is different and acts differently to the software
Is this always in the same location? There might be some radio interference going on.
And I assume the tire pressure system is working fine and shows pressures in the DIC?
Do you have anything electronic mounted by the inside rear view mirror - like a dash cam? Some have reported problems because that's where the receiver is.
Took my baby in to a dealership about a month or two, they banged out all of the recalls I had (stabillitrak, ecu, airbag, etc.). Explained the FOB issue to them and all they ended up doing was changing the batteries in my FOBs. I'm still having the exact same issue. I'm almost positive it's a bad receiver in the car itself.
Sorry for the late reply, here are my answers:
Nope, it happens no matter where I'm standing in relation to the car.
TPS is absolutely fine.
Nothing electronic inside by the rear view mirror.
A shot in the dark, but you might try toggling it in and out of Transport mode. I think with transport mode "on" the receiver would be shut down most of the time to save battery. Sometimes these things get where it's part way on - not "on" enough for the indicators to say it's on, but enough that some of the features are activated. By putting in and out of transport mode, it might reset all of it to be "off".
I'm still thinking it's a case of the receiver going to sleep. If it's on, the range is normal. When it off, you have to keep trying until it comes back on again. But I can't think of why it would be turning off.
