My A/C just quit while driving to a meeting tonight where the car was parked on gravel for a few hours so I did not see anything under the car. After arriving home, I looked under the front drivers side of the car and see a drop of green liquid. The liquid looks almost florescent green with the flashlight but more yellow on my finger. It seems to be almost odorless. It also looks wet as if more liquid leaked out and was blown under the car. I also notice when I turn on the A/C, I do not hear the compressor kick in.
I'm assuming you coolant is orange like it should be.
My guess is something in your A/C system sprung a leak and let our the refrigerant and the oil. Expect to have to replace whatever is leaking. Some people have reported problems with small rocks hitting the condenser (the first radiator) and puncturing a hole in it. Later models got a stone guard to prevent that. It would be a good idea to order it for your car to avoid it happening again.
Regarding the guard; what am I looking for? Can you or someone show me a picture or diagram of this guard and where it goes? When I looked under the car from the front, I couldn't really see anything except guards. Maybe a previous owner already installed it?
Have you refilled the washer fluid recently? Sometimes mine can leak down later if I spilled and then drove a short distance. I use green rainx summer and orange winter.
The shield was added to the 2012s rather late in the build…..so you may not have it.
It only shielded the lower part of the condenser…..the area directly behind your lower grill and was not used on the ECO.
It is black plastic….easy to not see, and it only covers the horizontal tubes without obstructing the fins between the tubes.
It is full width and snaps on at the left and right ends of the condenser.
As long as I've been in the biz, stone damage to condensers (and radiators) has been a fact of automotive life but in the case of the Cruze there likely were more stone damage failures than the norm…..hence the development of the shield.
Anyways, your question about green fluid……PAG oil, the lubricant used in your r-134a A/C is indeed green….also not water soluble……coolant can be rinsed with water, PAG oil just sheds it.
Since you indicate a loss of A/C with a corresponding development of leakage……rocket science not required on this one….there's a hole in the bucket.
Although the thought usually revolves around stones thrown by traffic ahead of you I contend that these punctures are often the result of oncoming traffic lifting and throwing stones into the oncoming side……the stone now has some real damage potential since the closing speeds are going to be rather high…..just a thought.
Anyways, unless a hose failed, the odds are you have a ventilated condenser…..if so, and your insurance deductible is low enough, you can make a insurance claim through your carrier.
I have found that most extended warranty outfits will cover this, even though it is not a mechanical failure….
Most good commercial AC guys could solder it right up, there is a special low melt alloy that is even available at harbor freight that works fine, I soldered my Kubota tractor radiator that I ran a branch through and it holds fine, not easy to get a good looking flow without practice but it does fuse with the aluminum, tons of posts on utube
and if your not comfortable soldering it take it to a commercial appliance-restaurant equipment repair guy, they solder aluminum coils all the time, the condenser coil is not cheep and at the dealer this will be an expensive repair, solder it yourself, buy a vacuum pump and scale 134a Freon and the solder-all available at HF
Take a look at http://www.cruzetalk.com/forum/25-service-issues/7703-looking-link-part-number-c-condenser-shield.html for the part information. Apparently it's relatively easy to install if you're under the car - one member's dealership installed it while cutting away the under-engine shield.
