Light Sensor blinking when car is off and locked
Results 1 to 10 of 17
Like Tree2Likes
Thread: Light Sensor blinking when car is off and locked
    Jan 2011
    When I parked my car in my driveway tonight and locked the door, the light sensor (that ball under the windshield, in front of the cell phone pocket) started blinking a red light and I do not know what it means I'm afraid it's going to drain the battery of my car, would somebody please explain how to stop it or at least why it is blinking like that despite the car being off and locked.
    When I unlock it, it stops, when I lock it and the dashboard is still lit up, it is a solid red, but when I lock it so no lights are on it blinks red.
    I hope somebody can explain this to me.
    4,337
    ...it does the same thing on our car, the salesman said it's normal.
    • 2011 Chevrolet Cruze LTZ 1.4LT 6A
    • 2009 Pontiac Vibe 1.8L/SFI 4A
    • 2004 Pontiac Vibe 1.8L/MFI 4A
    • 1971 Dodge Charger 318 3A
    • 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
    • 1968 Dodge Charger 383 3A
    • 1967 Plymouth Barracuda Formula-S 383 4M
    • 1965 Plymouth Barracuda Formula-S 273 4M
    Handbrake Released GoldenRS's Avatar
    Twin Cities,Minnesota
    234
    Alarm 'ARMED' indicator is the likely answer here..
    Jan 2011
    Weird because I had never noticed the light going off at all since I got the car a month or two ago, I had no idea that ball even lit up until tonight, nor did I even know what it was .
    4,337
    ...page 1-3 of the Owners Manual describes it as:
    L. Light Sensor. See Automatic Headlamp System on page 6-3.
    ...and page 6-3 says this:
    • Automatic Headlamp System
    When it is dark enough outside and and the exterior lamps control is in the automatic position, the headlamps come on automatically. See Exterior Lamp Controls on page 6-1.
    The vehicle has a light sensor located on top of the instrument panel. Make sure it is not covered, or the headlamps will be on when they are not needed. The system may also turn on the headlamps when driving through a parking garage or tunnel.
    ...but, page 2-10 has the answer (ta-da)!
    • Immobilizer Operation
    This vehicle has a passive theft-deterrent system. The system does not have to be manually armed or disarmed. The vehicle is automatically immobilized when the key is removed from the ignition. The system is automatically disarmed when the vehicle is started with the correct key. The key uses a transponder that matches an immobilizer control unit in the vehicle and automatically disarms the system. Only an authorized key starts the vehicle. The vehicle may not start if the key is damaged.
    The security light, located in the instrument panel cluster, comes on if there is a problem with arming or disarming the theft-deterrent system. When trying to start the vehicle, the security light comes on briefly when the ignition is turned on. If the engine does not start and the security light stays on, there is a problem with the system. Turn the ignition off and try again. If the engine still does not start, and the key appears to be undamaged or the light continues to stay on, try another ignition key. If the engine does not start with the other key, the vehicle needs service. If the vehicle does start, the first key may be damaged. See your dealer who can service the theft-deterrent system and have a new key made.
    Do not leave the key or device that disarms or deactivates the theft-deterrent system in the vehicle.
    Jan 2011
    Yeah I saw that in the book but I'm still at a loss as to why it is doing it when the car is off.
    398
    i dont think mine does that.
    87
    Mine does it. I believe it's actually just to tell you and warn others that the integrated security system is active - The light flashes from the ball shaped object on the dash near the defrosting vents.
    Southeast Michigan
    434
    Yes, that's HAL's eye.
    Jan 2011
    White Plains, N.Y.
    31
    Mine does it as does my folks Subaru Forrester, brother's VW Tiguan and my former car (a Nissan). It is related to the security system being on as far as I know. Its pretty common on new cars. Saw it on a BMW parked next to me this evening.
  1. Mass Airflow Sensor
    By nickys68chevy in forum Powertrain
    Last Post: 10-29-2012, 04:49 PM
  2. TPMS sensor matching
    By oldman2 in forum Powertrain
    Last Post: 07-29-2012, 10:47 PM
  3. Tire pressure sensor bugs?
    By titan2782 in forum Service Issues
    Last Post: 11-06-2011, 09:23 AM
  4. TPMS sensor part number for the Cruze??
    By TSURacing in forum Wheels, Tires, Brakes, & Suspension
    Last Post: 09-03-2011, 05:51 PM
  5. Blinking Side Markers?
    By 4piecekit in forum Appearance, Body, Detailing, & Interior
    Last Post: 03-27-2011, 09:22 PM
