Before I go back to the dealer, or another one to get this looked at AGAIN..I still smell coolant even with the tsb fix. It is strong when I first lift up the hood. I assume this is still not normal for the car
I may be wrong,but i don't believe you are going to get rid of the antifreeze smell in the engine compartment. Probably the best you can hope for is to keep the smell from entering the car's cabin. That was the case with my 2011 LT. The additional air intake plenum seals stopped the smell inside, but it was still in the engine compartment. Having retired from a GM dealer as a service manager after 40 years, I wanted to stay with a GM car. I traded the Cruze on a 2013 Malibu last month. The Cruze is a great car except for the coolant smell. It just seems to be one of those problems that often happen to a vehicle, that there may not be a fix for. Again this car was designed by Daewoo. BTW the Malibu seems to be a great car. No problems so far.
Ugh..I just don't know what to do. My coworker got a 2012 Cruze as a rental today- I went to check it out- sure enough, popped the hood and we did smell a little coolant. It will cost me way more money to get into a Malibu with similar equipment. We use the remote start a lot and you can't get the remote start unless you get a Malibu LT which is at least 25 grand.
Have to wonder if eventually we will see a recall because of this. I am going to stop at another dealer to see what they say tomorrow, however now that I had a chance to look at another Cruze that still smells of coolant (a 2012 LT with 16,000 miles) I have to wonder if it is some design issue that they don't have a fix for now.
I wonder if anyone has considered starting a class action law suite over this. Apparently there are many others like myself who have lost thousands of dollars due to having to trade the thing off!
Update: Dealer is going to pressure test my car again and look around the water pump. Another lady dropped off a 2011 LT when I was there and he checked her car, sure enough, you could smell coolant as soon as you lifted up the hood and the fluid level was barley above the bottom hose- about an inch lower of where it is supposed to be. I am convinced this a general design issue.
As to what you said Cruze01- you are exactly right- I test drove a Dodge Dart today and they looked at my car and would give me less then what I owe and this is the sister dealership to the Chevy dealer I bought my Cruze from- they are literally right next to each other. I will take a big loss if I get rid of the Cruze. I have about 10 grand in principle and trade in I would lose if I get into another car.
