So sometimes, after my car sits, and it only does this maybe every few days - when I i go to crank it - it just quits after a half-turn of the engine, like I've let out on the clutch while it's turning over, even though my foot is firmly planted on the clutch pedal all the way to the floorboard. I release the key, and try again - cranks fine. Any ideas? I cannot duplicate this, it's totally random. Oversensitive safety-neutral switch?
That is strange. What i would try is this.. Next time it sits for a few days put the key in turn it to start with the clutch out which will hopefully do nothing and then press the clutch in with the key turned. If it does the same thing I would say its not your sensor.
I've tried everything I can think of to duplicate it. I do know the last 2-3 times it's done it I've had my foot firmly pressed all the way to the floor - I suspect it may be something out of kelter in the ignition as turning the key to the off position and back on w/o moving my foot cranks the car.
Well speak of the devil it did it yesterday. After observing it several times it almost sounds like the engine is turning over, then suddenly running out of juice all within a 1/4second of turning over - bumping the key forward again cranks the car fine.
OK, so if you push the key in with a little pressure it will work fine, but if you use a little pull pressure on it does the engine cut off. Sounds like maybe it the ignition switch. If you can find a way to repeatably demonstrate the issue it makes it alot easier on the repair guy .
