Hello All,
I'm hoping one of you would have some advice on how to get this fixed -
I have a completely unmodified 2011 Cruze Eco from Canada, with the 6 speed manual. It currently has around 1550 KM on it.
I find I am almost unable to get the car shifted into gear 1 or 2.. for example: after leaving my driveway, and driving 500 feet to a stop sign, I put the car into neutral while stopped, with clutch pressed firmly in. I then shift into first gear, with clutch held firmly down (carpets not blocking me), but the shift lever basically refuses to engage, or requires a good bit of force, or letting the clutch out several times, then attempting to shift into first again.
Now, once we get rolling in first, I rev match by letting the engine rpm slow down to an appropriate speed for second gear, with clutch held down, then try and put the car into second gear, and it appears to "grind" before accepting the gear shift, or it kicks back the shift handle.
This only seems to happen in gear 1 and 2, and maybe a tiny bit in gear 3, and ONLY seems to happen when the vehicle is COLD. We have temperatures from -21 to -5 here on average lately, but I do give the vehicle 2 to 5 minutes idle warmup before taking off.
The issue does not seem to occur when the vehicle has been driving for a while (20 min for example).
Any ideas ? Any ideas how I can explain this to a dealer in a way that will get them to warranty repair it and not just tell me it's user error? I don't suspect dealer abuse of the vehicle, as it only had 8 km on it when I chose it.
1Likes
LinkBack URL
About LinkBacks
Reply
Aztek
Cruze
SV
Corvette
Cruze
