BOV open at idle?
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: BOV open at idle?
    Learning about my Cruze Markj2222's Avatar
    Jul 2012
    Edmonton, AB. Canada
    76
    BOV open at idle?
    So im working on my car, and i noticed that during idle the Forge BOV valve is 25% open!
    So i rev'ed the engine and the valve appears to be working properly / moving freely. Also i figure the BOV is not pushing out air but sucking in air at idle.
    My best guess is that the intake manifold has a vacuum at idle where pre-throttle blade the pressure is neutral, so the vacuum is pulling the BOV open.
    What do you guys think?
    2012 Chevrolet Cruze LT Manual 6
    Mods: Trifecta Tune ~22 , Injen SRI
    Next: Water/meth injection, No lift shift, HID's
    Tires:
    Michelen X-ICE Xi3215/60R16/XL 99 H
    Wont rest until i reach 200 WHP
    Autocross Champion
    titan2782's Avatar
    Nov 2011
    SoCal
    1,831
    Do you have an atmo or recirc?
    I'd say that there is a leak because the the vacuum should come from the solenoid instead of the manifold directly. Your thinking does make sense though, but obviously something is wrong. I'll have to check mine and see if it does the same thing. I tried to call forge but they're closed ATM.
    Different.
    Black '11 Cruze Eco 1.4T M6 - 146HP/190TQ (Estimating 163HP/216TQ, dyno results pending)
    Mods
    : Trifecta premium tune, 42# injectors, Forge BOV, DDMWorks Sonic Shifter Bushings, Reso delete, K&N panel filter, oil catch can, boost gauge
    Visual: 30% tint all around, Custom bow-ties front/back/steering wheel, godspeed forged aluminum black lug nuts
    Also: 2005 SRT-4 ACR, 2001 Dodge 1500 4x4
    Previous projects: 88 Camaro V6->V8 Swap (First Start, No exhaust) http://bit.ly/uET6j7
    Autocross Champion
    titan2782's Avatar
    Nov 2011
    SoCal
    1,831
    Hm, it doesn't look like mine is sucking air in, but I do hear a sucking which I believe is the IAC. I put a peice of paper next to the BOV and i didn't move. I have an atmo BOV.
    Different.
    Mods
    Jul 2012
    76
    Quote Originally Posted by titan2782 View Post
    I also have the atmo BOV, could you see if the valve was open?
    Tires:
    Autocross Champion
    titan2782's Avatar
    Nov 2011
    SoCal
    1,831
    Didn't look. You using a mirror and looking through the vent holes?
    What is your engine idling at?
    Different.
    Mods
    Jul 2012
    76
    I just used a trouble light and i could see that it was open. Idle is at 600 rpm.
    note that the valve firmly closed when the engine is off...
    Tires:
    Autocross Champion
    titan2782's Avatar
    Nov 2011
    SoCal
    1,831
    I'll check in a tonight when I'm putting my shifter bushings in and I'll let you know what I find.
    Different.
    Mods
    Autocross Champion
    titan2782's Avatar
    Nov 2011
    SoCal
    1,831
    Wow, good find, sir. I checked mine and I can see it is open. This is very concerning. I'd rather not get crap in my turbo compressor wheel...
    Also, I don't see any solenoid on the vac line so I think it's a direct tap which would make sense on why we're seeing what we're seeing.
    Different.
    Mods
    2nd Gear AutumnCruzeRS's Avatar
    Sep 2012
    Putnam Township, Livingston County Mi
    465
    Can you guys explain exactly how these BOV/BPVs work? I wonder if my Forge BPV is also open at idle but not sure how I could determine that.
    Nov 2011
    528
    This is completely normal behavior. Cat warm up is the cause. My LNF Cobalt does this also during the cat warm up cycle.
    Your 1.4T Performance Specialists
    Trifecta Tunes
    ZZP Parts
    DDMWorks Parts
    And more....
    Want to make some cash? Sign up on our site as an affiliate!
    Don't forget to like us on Facebook so you can get in on all the awesome deals we post!
  1. What is your rpm at idle?
    By Ru5ty in forum Engine and Technical Discussion
    Last Post: 12-01-2012, 11:58 PM
  2. Why Does the DIC sit at Max in Idle?
    By YKNWT in forum Fuel Economy
    Last Post: 10-24-2012, 11:50 PM
  3. How-to: Open the Hood
    By sciphi in forum The How-To Library
    Last Post: 09-05-2012, 08:07 PM
  4. How to open trunk when car is on?
    By ack23 in forum Chevrolet Cruze General Discussion Forum
    Last Post: 05-09-2012, 02:15 PM
  5. Trunk Keeps Coming Open
    By gmarcucio in forum Chevrolet Cruze General Discussion Forum
    Last Post: 04-05-2012, 06:54 AM
