Cruze 1.4 Intake Porting
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 30
Like Tree7Likes
Thread: Cruze 1.4 Intake Porting
    Oct 2011
    Iowa
    44
    What is Cruze plastic intake manifold porting? Is it the removal of the small "dam" at the point the intake attaches to the head? Does removing this "dam" make more power? Does it make less power? Does it make more or less low end torque? I have the head off putting in new pistons, so it would be easy to do now, IF, it would help.
    We are making 249 HP @ 7400 and 206 # @ 4700 with HEP turbo upgrade and Trifecta tune.
    Del Long
    Mattburgess likes this.
    Aug 2012
    10
    Yeah it is pretty much carefully cut out that "dam" and don't cut into the rest of the intake. I know there was a thread with pictures posted, search should find it.
    Oct 2011
    Iowa
    44
    I tried searching "porting" I'll try Air dam removal.
    Del Long
    Aug 2012
    10
    haha yeah i did to right after and was surprised, I know I saw it here on a forum.
    it is vermont tuning that has pictures up of their porting, clearly showing them taking out the dam.
    PMd you the link since it is in another forum
    1st Gear patatewz's Avatar
    Aug 2012
    357
    you need a tune if you cut out that dam. Maybe its safer to buy the stage 1 kit from vtuner like me.
    The dog is a option.
    Poje likes this.
    Chevrolet Cruze 2012 1.4T MT
    Tuned by: Vermont Tuning
    Best ET time 16.534 At 83.85 MPH (STOCK CAR)
    Best ET time 15.695 At 89.12 MPH (STOCK CAR + STAGE 0 93 Octane TUNE)
    Best ET time 15.311 At 92.32 MPH (Engine Mount + Down/Mid pipe + ported intake + SUPER 14GT turbo + water/meth TUNE)
    Best MPH15.833 At 89.40 MPH (Engine Mount + ported intake + STAGE 1 93 Octane TUNE)
    Best MPH time 15.357 At 95.22 MPH (Engine Mount + Down/Mid pipe + ported intake + STAGE 1 93 Octane + water/meth TUNE)
    Aug 2012
    10
    I would assume that he has a tune if he is at 249hp and his post clearly states he has Trifecta.
    Aug 2012
    10
    Pics of the ported and unported for future references
    143
    Quote Originally Posted by sprinto7 View Post
    Del Long
    Not to go off topic here but what turbo did you select from HEP? And how are you making it to 7400 on stock springs? I know the HEP kit doesnt upgrade the valve train or pistons. Just curious where you got these parts. I assume you went custom forged pistons? Curious about your setup...
    Typically intake porting is just "clearancing" of material from the manifold itself, internally and for port matching. As far as the dam is concerned I haven't wrenched into the car that far yet so I'm not sure. I'd expect high rpm gains over low. Can't speak to torque on this car but I lost some, not much, on the low end when going from an LS4 -> LS6 manifold on my other application.
    Oct 2011
    Iowa
    44
    Quote Originally Posted by ECOmaniac View Post
    Snakeyes sent me a link to the post on "porting". I'm not sure I want to try it at this time. we're on a VERY close scehdule to get all the parts gathered up and reassembled in time to go the the SCCA SOLO Nationals on 9/01/12. We may not want to add ANOTHER variable.
    I'm not ready to give away all hard work and research we've done to get this far. I will say the Vince at Trifecta has been super on helping us over come all the "I won't let ou blow this engine up" GM put into the ECM programming. The next test session after we got the engine working right we fell victim of the "GM TOO Tight ring gap" failure and lost cylinder 1 and 2. The block cleaned up at .009" over on number one, so we honed the others to the same spec. There is only one company, that we can find, that has made replacement pistons for the 1.4 and they only made one other set. They went to China!
    Howie at HEP makes a favulous exhaust manifold, and trying to get hinm to make an Intake manifold also. We have the engine mounted for RWD and it would be VERY handi to have the throttle body on the other end.
    After the SCCA Nationals, I hope we can have an announcement listing what worked for us, as well as what didn't. We do have stock springs. We have run it to 7830 RPM (7500+ over run) and there is NO evidence of valvle float. WE do NOT let it set on the revlimiter.
    Del Long
    13,714
    De Long, I've seen you on the Facebook Trifecta page. This is Andrei, in case you recognize me. I'm looking forward to seeing what you guys do with that engine and seeing your post of what works and what doesn't. You're a pioneer in this field and are doing much to help us understand what this engine is reliably capable of.
    Hidden Content :: Hidden Content
    "When freedom is at odds with government policy, one of two things eventually happens: Either freedom is crushed, or political leaders are forced out in disgrace and replaced with guardians of individual liberty."
    "...the Supreme Court has ruled that the right to keep and bear arms exists independently of the Second Amendment...the Bill of Rights is a reminder to the government, not [an] authorization..."
  1. Cold Air Intake VS Short Ram Intake?
    By CHEVYCRUZE RS in forum Powertrain
    Last Post: 12-10-2015, 01:18 AM
  2. porting sub box through parcel shelf
    By YES13Q in forum Audio & Electronics
    Last Post: 08-09-2012, 09:50 PM
  3. Cruze Air Intake
    By osiris10012 in forum Powertrain
    Last Post: 07-09-2012, 12:15 PM
  4. FS: 2011 Cruze ZZP Intake - $200
    By VictoryRed08 in forum Chevrolet Cruze Classified Forum
    Last Post: 10-08-2011, 02:16 PM
  5. Anyone interedted in porting and polishing?
    By Memphis in forum 1.4L Turbo
    Last Post: 07-30-2011, 06:06 PM
