LAUNCHED- Forge 1.4T BPV and ATMOSPHERIC BOV **DIRECT FIT** - Page 10
Page 10 of 17 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 162
Like Tree39Likes
Thread: LAUNCHED- Forge 1.4T BPV and ATMOSPHERIC BOV **DIRECT FIT**
  1. #91
    Chicago
    774
    Quote Originally Posted by Toyotech View Post
    If you are getting this just for sound don't... The bpv is just about the same in tone as my modified airbox.
    It holds 12.3 at full throttle highest I ever saw was 11.9 before then would drop to 10 then 8.2... That doesn't happen anymore
    The oem is the cheapest bypass I've ever seen
    See below
    Attachment 8836
    It physically just came apart
    For the install tools I used.
    Flat head screwdriver for intake piping
    T20 torx screwdriver for vacuum valve
    T30 torx screwdriver for bottom bolt and far side bolt (the back bolt cannot be tightened with the torx bit due to housing clearence)
    1/4 drive ratchet with extensions
    T20/t30 torx bits
    90" long end pliers for vacuum lines
    Extendable magnet ( I have big hands and from working on cars for a while my fingers also lock up so for those hard bolts to reach this helps hugely)
    Now I definitely need this!!! So I can boost 25lbs and hold it, my car should be a pinch faster by holding all the boost it builds.
  3. #92
    Learning about my Cruze jayman4312's Avatar
    May 2012
    chicago IL
    74
    are oyu having trouble holding boost now with the stock bpv? it's leaking?
  4. #93
    Aug 2012
    NJ
    219
    Quote Originally Posted by jayman4312 View Post
    After seeing it apart I wouldn't want high boost with it. A 3 cent spring and a plunger I wouldn't install on anything. If it costs 25 cents to produce this part I would say its overpriced
  5. #94
    2nd Gear smorey78's Avatar
    Lusby,Maryland
    440
    Ok here is my big question. What do you do if you need to take the car into the dealer and you need to tune back to stock? Will the BOV still work with a stock tune and no ECP enabled? Or do you have to pull it out and reinstall the stock one. That will suck!!
    cronyjabrony likes this.
    2012 Cruze 1.4T 6AT Eibach's, DDMworks Spacers, Ultra Racing bars +4, Trifecta Custom Tune, Bosch 42# injectors, Ported Intake, Injen CAI, Forge BOV, ZZP FMIC, EBC Greenstuff Pads, Slotted Rotors, MagnaFlow Dual Exhaust, ZZP O2 Housing/Down Pipe, ZZP Catless Mid-Pipe, AGT 6K HID Headlights, AGT 3K HID YELLOW Fog Lamps, ASD Custom Shifter and 10% Tint, AEM Boost Gauge, AEM Wideband A/F Gauge.
  6. #95
    1st Gear cronyjabrony's Avatar
    Aug 2012
    Wasaga Beach, Ontario
    309
    Quote Originally Posted by smorey78 View Post
    Yeah good question???
    ADDICTED TO TURBO
    http://www.facebook.com/christophercroninvfib
  7. #96
    Nov 2011
    530
    The atmo valve would have to be uninstalled to flash back to stock but the recirc valve would be fine on the stock tune
    Your 1.4T Performance Specialists
    Trifecta Tunes
    ZZP Parts
    DDMWorks Parts
    And more....
    Want to make some cash? Sign up on our site as an affiliate!
    Don't forget to like us on Facebook so you can get in on all the awesome deals we post!
  8. #97
    Lusby,Maryland
    440
    Quote Originally Posted by Jerry@BNR View Post
    what would happen if you did not uninstalle it and flashed back to stock. what would the car run like
  9. #98
    Driver's Ed chrissn89's Avatar
    Feb 2012
    Australia
    44
    In Australia the stock recirc valve is $335.50AUD. So this mod is great value for money if your standard unit fails.
    buk azwell likes this.
  10. #99
    Aug 2012
    NJ
    219
    I took my time with it. Used silicone spray on all fittings and removed extra and it took about a half hour at most. It wouldn't be bad. Doing it again knowing the right tools it would take about 15 minutes. I would much rather swap this over compared to a downpipe for warranty work
    On another note the bpv is a bit louder after a day of driving
  11. #100
    Lusby,Maryland
    440
    well that not to bad.
    15 mins for BOV
    10 for Tune back to stock
    25 mins back to stock cats
    20 mins back to stock intake.
    that's the price you pay.
    just hope the stock bpv dont brake like some of the other guys said had happen when it came apart. not spending $355 for a new one
  1. Warranty Direct UK, reliability, ratings
    By zr1000a1 in forum Off Topic Discussion
    Last Post: 08-10-2012, 06:20 AM
  2. GM Parts direct
    By Patman in forum Chevrolet Cruze General Discussion Forum
    Last Post: 03-20-2012, 11:26 PM
  3. iPod Direct Control
    By magneto1138 in forum Audio & Electronics
    Last Post: 11-07-2011, 07:09 PM
