XtremeRevolution & Co. Mobile Audio Parts
XtremeRevolution.net
"Dreams move on, when you wait too long..."
- Billy Ray Cyrus
The single biggest reason this doesn't apply to the Cruze......the FTC article's date is 2003.
They make it so the engine can run on 87 so cheap skates won't whine about having to spend more on gas. It is an economy car after all.
2012 Cruze RS-T 6M
Performance - Tuned for E85 @ 24psi, 440cc Bosch Injectors, Spec Stage 3 Clutch, CXRacing FMIC, ZZP Down and Catted Midpipe, Forge BOV, K&N Typhoon SRI, Custom Magnaflow Catback, Big 3 Ground Kit, Mobil 1 Oil, RP 75w90 Trans Fluid.
Exterior - Plastidip Wheels, Stripes, Rear Chrome, RS badge relocation
210hp/270tq on E85.
OnlyTaurus's Build Thread
November 2012 Cruze Of The Month
March 2013 Member Of The Month
I'm Building the Very First... Cruze SS!
I don't like this article at all. It is hardly scientific. Inside Line / Edmunds are not scientific at all with their tests (the same people who can only manage 32 MPG maximum in a Cruze?!?) and have some lead foot journalists. Also keep in mind that this is 100+ degree temps which are conditions 90% of people on here will not encounter every day.
I really think if you aren't tuned you will be fine with 87 Octane. I never had any issue with it and tried 4 tanks regular vs. 4 tanks premium (91) before tuned. There was no noticeable change in fuel economy, but a difference in throttle smoothness when pushed. Pretty much every turbo car on the market now is certified to run on 87 Octane gas and their power ratings on 87 are either listed as just slightly below their premium fuel ratings.
2011 Chevrolet Cruze LTZ - 1.4T 6A RS & Black / Brick Interior
Mods: Trifecta "Premium" Tune - 30% tint all around, Injen CAI w/ Hydroshield, VG Sharkfin Antenna
Future: e85 Trifecta Tune
Follow me on twitter! @Opin_YUNATED. Southern Ontario Facebook Group, Trifecta Facebook Group
Looking at the engine specs of the new ford Fusion ecoboost engines they actually list two different horsepower numbers for each engine. One with premium & one without. The 1.6T in the fusion makes 5HP more with premium, the 2.0T makes 9HP more with premium.
Obviously with a turbo to run 87octane the computer has to detune the engine, nice to see some manufactures actually show this on paper.
Ford - Cars, SUVs, Trucks & Crossovers | Ford Vehicles | The Official Site of Ford Vehicles | Ford.com
I'm not saying this is the same case with the cruze, though my well calibrated butt dyno says it is.
- Billy Ray Cyrus
The conditions don't need to be 100+ degrees. It just so happens that 100+ degree temperatures are on the severe end of what your car will be affected by. I'd wager that anything above 80 degrees F with A/C on will necessitate the use of premium fuel. Those conditions. With the intercooler being sandwiched between the radiator and the A/C condenser, heat soak is pretty much guaranteed. Since turbo efficiency also drops significantly with higher temperatures, it creates more heat to produce the same amount of boost.
Keep in mind that certified power ratings are in ideal conditions. If you live pretty much anywhere in the united states except for right along the coast, you are guaranteed to be outside those ideal conditions 4-6 months out of the year.
- Billy Ray Cyrus
Another person here to verify throttle surging on 87, vs nothing of the sort on Shell 89. We bought the car after temps had already dropped below the need for AC so I haven't felt the need to test anything higher octane wise. Also, when running on 87 octane and surging occurs due to timing retard, it seems to screw up the transmission behavior a bit for me as well. Like the car is confused on what gear to grab or hold onto based on throttle position because the power output the transmission has been programmed to receive for a given RPM is slightly altered maybe? I'm not well versed on transmission tuning but my gut assumption would be that they are tuned based on speed, rpm, grade and throttle position with a predetermined power output for a given throttle position.
I did verify from Tom that the horsepower ratings for the Chevy Cruze are taken with 87 octane. This might explain why some people have put down around the same or more than the rated torque on the dyno with their Cruze on 91/93 octane.
Since we know the car does pull timing with 87 octane, we can safely assume that the 1.4L Turbo produces more power than 138hp/148lb-ft on 91/93 octane. I'd put the numbers closer to 142-145hp and 155-160lb-ft on higher octane fuel.
- Billy Ray Cyrus
