Transmission problem
Results 1 to 8 of 8
Thread: Transmission problem
    ntymd8r is offline [OP]
    Dec 2012
    5
    I have a 2011 1.4t 6-speed auto with 45,000 on the clock. This morning started driving and noticed it is stuck in second and the ceck engine light came on solid. Can't swirch to the manual mode. Went to store, turned her off. Came back out and she drove around the parking lot like normal and was able to switch to manual mode. Started for home and got up to 55 in 5th. Switched to 6th and she automatically went to nuetral.....no power! I had to go back to normal drive and the "D" started flashing. She then stuck herself back in 2nd all the way home. What gives?????
    13,442
    Limp mode. Not sure what's wrong with it (sounds like a shift solenoid problem), but there WILL be a code stored in the computer the dealer can read.
    Luckily the transmission has a 100k warranty.
    Dec 2012
    5
    Would that be and easy and quick fix if it were a solenoid?
    13,442
    Not really. Usually requires dropping the transmission pan or sometimes the subframe. Chevy may end up just replacing the whole transmission.
    A fluid change might do the trick but I'm not entirely sure what's wrong with it to begin with. This is knowledge based off other cars than the Cruze with similar symptoms n
    5,159
    Take it to the dealer. The transmission is covered under the 100k mile powertrain warranty.
    Dec 2012
    5
    Took her to the dealership. Nice 30 mile drive at 35 MPH! I called OnStar for a diagnostic check while enroute to the dealership. The rep said there were two codes that are related to the transmission malfunctioning...imagine that! Said to was related to the control module and another system which she couldn't clarify more. The 5 year 100,00 mile warranty apparently does NOT cover control modules and a bunch of other electronics. I hope it's more than that and they end up changing it out....was jerky to begin with! I'll keep you all posted.
    Dec 2012
    5
    Well, they had to drop the transmission and found a "plate" and a "valve" needed to be replaced. Had nothing to do with the electronics. All covered under warranty. The service rep said a TSB is supposedly coming out for this very issue....said "debris" is floating around for some reason and damages these parts.
    Chevy Customer Care's Avatar
    Oct 2011
    Detroit, Michigan
    5,721
    Quote Originally Posted by ntymd8r View Post
    ntymd8r,
    I would like to apologize for the experience you have had with your transmission. I am happy to hear that you are getting this taken care of. Please keep me posted on the progress. If you have any questions please feel free to contact me anytime.
    Thank you,
  11. Remove Advertisements
  1. 2012 cruze lt - 6mt - problem after problem
    By trance|ghost in forum Gen1 Service Issues
    Last Post: 09-25-2012, 12:35 PM
  2. My first problem help?!
    By Patman in forum Gen1 1.8L
    Last Post: 07-05-2012, 10:27 PM
  3. transmission problem?
    By lecksi in forum Gen1 Service Issues
    Last Post: 06-19-2012, 03:44 PM
  4. SRI Problem
    By Calintz in forum Gen1 1.8L
    Last Post: 04-22-2012, 06:56 PM
