Turbocharger Failure?
Page 1 of 16 1 2 3 11 ... LastLast
Results 1 to 10 of 159
Like Tree21Likes
Thread: Turbocharger Failure?
    1st Gear CRUISE-CRUZE's Avatar
    USA
    304
    Exclamation Turbocharger Failure?
    I may have a turbocharger failure. I just entered on highway and I had around 60MPH. When I pushed the gas to pass another car, suddenly I felt the engine losing power and I saw dense blue smoke behind. I drove the car another 10 miles to home and the engine felt under power all the time. Trying to push the gas, I saw again blue smoke. I have MT so I played with the speeds to get some power. Check engine showed up. And…. Warnings regarding the stability and traction control! I have Trifecta so today I’m going to put back the factory tune and I'll go to the dealer in the morning. I can hear rattling when engine is idling. Will see what’s happening tomorrow. Anybody had similar experience with turbo?
    Retired Moderator Aeroscout977's Avatar
    Ypsilanti, MI
    2,266
    Quote Originally Posted by CRUISE-CRUZE View Post
    I may have a turbocharger failure. I just entered on highway and I had around 60MPH. When I push the gas to pass a car, suddenly I felt the engine losing power and I saw dense blue smoke behind. I drove the car another 10 miles to home and the engine felt under power all the time. Trying to push the gas, I saw again blue smoke. I have MT so I played with the speeds to get some power. Check engine showed up. And…. Warnings regarding the stability and traction control! I have Trifecta so today I’m going to put back the factory tune and I'll go to the dealer in the morning. I can hear rattling when engine is idling. Will see what’s happening tomorrow. Anybody had similar experience with turbo?
    I haven't seen any post like this here yet. Please keep us informed as to how everything goes! Good luck man.
    USA
    304
    This is what I said too! Car has 11k miles and 5k since I added Trifecta.
    Retired Moderator shawn672's Avatar
    Oct 2010
    Rochester, NY - Charlotte, NC
    2,475
    flash back immediately and bring it back tomorrow
    Drag Racing Champion jakkaroo's Avatar
    1,743
    didnt spaceme have the same issue?
    USA
    304
    Just did the flash back. I read the OBD code first. They areP0299 (Turbo/Super Charger Underboost) and P0304. After reflash I drove the car a few miles but the check engine didn’t show up again. Just “stability traction service”. The car is underpowered and going up over 2000 RPM it’s starting rattling, smoking. I hope for something minor like a sensor, hose, but it could be much more regarding the turbo charger. I’ll see tomorrow….
    USA
    304
    Yes, it is but it's strange that I got so many warnings:
    P0304, P0299, stability and traction control warnings + lights.
    P0304 - Check Engine Light Diagnostic Trouble Code Description
    3rd Gear weimerrj's Avatar
    Chesapeake, VA
    653
    This is conjecture, but look under the hood and make sure all your intake piping is secured. Something may have come loose or broken and the boost could be venting out before it gets to your engine. That could cause an extreme rich condition due to the computer mapping and the MAF sensor, especially if you have a hole between the turbo and the intake manifold. you may be flooding your cylinders, causing the misfire and blue smoke. It should also give the p0299 code.
    5,163
    Blue smoke is oil burning in the exhaust. The places oil could get into the exhaust in quantities enough to burn are the valves/valve guides, PCV system, and the turbo. Seeing how the OP has blue smoke, no power, and a DTC indicating no boost when commanded, it's likely the turbo ate a seal.
    A rich condition would be black smoke from the soot caused by unburned fuel. And the ECU (it's a manual car, so the engine computer doesn't control the transmission, therefore ECU) would be skewing the injectors as much as it could to correct that condition., setting a LTFT out of range code and pegging the long-term fuel trims to -16.4.
    Learning about my Cruze ShowCar's Avatar
    Highland Park Illinois
    91
    Sorry to see this thread. Good luck with the dealer fix.
    Daily Driver
    2013 Cruze 2LT RS
    Crystal Red
  1. No Remote Detected, TPMS failure
    By Andy2012ltz_rs in forum Gen1 Service Issues
    Last Post: 06-10-2014, 08:21 PM
  2. Replies: 3
    Last Post: 07-02-2012, 08:11 AM
  3. Trasnmission Failure
    By 96vteclude in forum Gen1 Service Issues
    Last Post: 02-06-2012, 10:01 PM
