XtremeRevolution's Subwoofer Boxes - Page 30
Page 30 of 44 FirstFirst ... 20282930313240 ... LastLast
Results 291 to 300 of 436
Like Tree93Likes
Thread: XtremeRevolution's Subwoofer Boxes
  1. #291
    SW Chicago Suburbs
    8,254
    Looks good! How did you figure out the port dimensions?
    XtremeRevolution & Co. Mobile Audio Parts
    XtremeRevolution.net
    "One of the keys to success is the ability to overcome the fear of putting yourself in a position to fail."
  3. #292
    Louisville, KY
    15
    still doing sub box design for us?
    Thanks for all the good info & time you devote to the site.
    I'm getting ready to do a little audio upgrade to my Cruze (12 Eco.) So my brother works for Harman and got me a good deal on some stuff:
    Amp - JBL GTO-5EZ
    • 5-channel
    • 50 watts RMS x 4 at 4 ohms + 350 watts RMS x 1 at 4 ohms
    • 75 watts RMS x 4 at 2 ohms + 500 watts RMS x 1 at 2 ohms
    • 150 watts RMS x 2 bridged at 4 ohms + 500 watts RMS x 1 at 2 ohms
    Sub - 12" Infinity 1262w
    4 ohms
    Dual Voice Coil
    Sensitivity 93 dB at 2.83 watts
    Frequency Response 23 - 400 Hz
    RMS Power Range (Watts) 100-300
    Peak Power Handling (Watts) 1200
    Vas (liters) 80.14
    Fs (Hz) 25
    Qts 0.46
    Xmax (millimeters) 13
    Front - Kappa 63.9i
    Back deck - Kappa 692.9i
    I think I'm going to keep the stock head unit for now and I'd the smallest sub box possible & still sound ok. I listen to mostly 90's rock/rap and maybe more current stuff like Beck/White Stripes/Flaming Lips I also listen to lot's of audio books & podcasts.
    So fell free to give any suggestions or tips, all is appreciated.
    Thanks
  4. #293
    SW Chicago Suburbs
    8,254
    What is the Qms and Qes of the sub?
    Sent from my myTouch_4G_Slide using AutoGuide.Com Free App
  5. #294
    Louisville, KY
    15
    Qms - 6.84 Qes - .49
    sorry just pulled all the stuff that crutchfield had...
    here's the full spec sheet http://us.infinitysystems.com/tl_fil...262W_PI_EN.pdf
  6. #295
    SW Chicago Suburbs
    8,254
    I'll get you a box designed as soon as I can.
  7. #296
    Slidell, New orleans
    27
    XtremeRevolution likes this.
  8. #297
    SW Chicago Suburbs
    8,254
    Quote Originally Posted by edro View Post
    1.6 cubic feet gross volume is what you'll want to use as a bare minimum. I really wouldn't go any smaller than that. Qts at that size is .78; a bit higher than what I prefer for SQ purposes, but you can make it work with limited space. A 2.5" thick acoustic pad on the walls is required for this box in order to flatten the frequency response.
    Bracing is recommended, but not required at this power level. You could get away with just a few straight pieces of bracing instead of routed bracing like I use on all of the boxes I build. However, a double thick baffle with a flush mount is highly recommended.
    Let me know if you have any questions or want to see the frequency response chart.
  9. #298
    Louisville, KY
    15
    So 3/4" mdf right? & you have linked to the acoustic pad in this thread before, are there any places locally to get that stuff?
    Sure I'd like to see the chart if it's not too much trouble.
    Thanks man!
  10. #299
    SW Chicago Suburbs
    8,254
    Thanks man!
    3/4" MDF is correct.
    Look at this website to see if you can find what they are selling locally at a home depot. Don't just buy any random insulation as it won't work. Acoustic Insulation - Order Online, Ships UPS
    Line all of the walls except for the baffle. If those specific products cannot be found, buy this:
    Acoustic Foam 2-1/2" x 24" x 18" UL 94 260-515
    Here's your frequency response, with the acoustic material on the walls.
  11. #300
    SW Chicago Suburbs
    8,254
    Got TerryM's box shipped out. One more IDQ12 box to carpet and ship, and I can start working on more recent orders.
  1. GMAccessoriesZone Subwoofer
    By obermd in forum Audio & Electronics
    Last Post: 09-22-2012, 11:08 PM
  2. Subwoofer mounting
    By Tonka in forum Audio & Electronics
    Last Post: 08-11-2012, 05:54 PM
  3. Adding subwoofer
    By jsn in forum Audio & Electronics
    Last Post: 02-19-2012, 09:15 PM
  4. Subwoofer for Eco?
    By zdave83 in forum Chevrolet Cruze General Discussion Forum
    Last Post: 07-20-2011, 05:20 PM
  5. tool boxes anyone?
    By DEcruze in forum Cruze Owners - Other Cars/Toys
    Last Post: 05-25-2011, 10:32 AM
