FIRST OFF, I am only providing this "how-to" to make sure this is not what caused my brand new sub to pull a 3 miles island(melt -down)on me. SO , PLEASE DONT FOLLOW THIS UNTIL VERIFIED BY A KNOWLEDGEABLE POSTER.
With that out of the way, I have posted a few pics to make sure this is an acceptable method to wire the PAC AA-GM44. Please note on my original attempt had bare wires, did not have black wire spliced to Blue/black wire, and was idiotically done in haste. But hey hindsight is always 20-20. If you are not able to tell in the pics, all splices have now been soldered and shrink wrapped.
To begin with i attached the wiring harness to the input side and the RCAs to the output side. Next I spliced the BLACK WIRE to BLUE/BLACK WIRE, per manual "IF switch is set to RCA(OUTPUT) then BLACK wire termination(ground/no connection) determines whether Negative OUTPUTS are common to ground or to each other")
Following this, I redundantly spliced the BLACK WIRE from the input side into the BLUE/BLACK wire, even though manual states they are internally connected.
Then, using spare black wire from the non-used connector as an extension, I spliced the BLUE/BLACK wire to the GROUND WIRE(BLACK 38) in the harness, as reported in post #3 in here
