Adjusting Headlights - Page 3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 40
Like Tree6Likes
Thread: Adjusting Headlights
  1. #21
    2nd Gear oMAHONEYo's Avatar
    Toronto, ON
    422
    Quote Originally Posted by Starks8 View Post
    Are members who have recently purchased a new to recently built 2012 Cruze from factory, still seeing the need to adjust the headlights?
    On my 2012 LS I had to do about a turn and a half to have the cutoff at 2ft, such a huge improvement. This was back in march when I purchased/made the change.
    2013 Cruze 2LT w/ RS Package
    2012 Cruze LS (oCRUZEo) -
    Traded in on 07/25/2013
    Follow me on twitter! Hidden Content
  3. #22
    Patman's Avatar
    Cincinnati, Oh
    4,127
    Quote Originally Posted by oMAHONEYo View Post
    My understanding is that most all Cruzes have an adjustment problem from the factory. Most everyone on this forum has done it including myself. I even went so far as to buy new Sylvania bulbs.
  4. #23
    1st Gear rbtec's Avatar
    Feb 2012
    Southeast Michigan
    383
    Were they too high or low? Which way to turn to lower?
  6. #24
    AZ
    5,009
    They come to low from the factory. Think counter clockwise raises I forget but just do it at night against a wall or garage door and you'll see which way they are going.
    ^Usually sarcasm.
    If anything I say offends you... you might need a snickers.
  7. #25
    Feb 2012
    Southeast Michigan
    383
    Anybody.......Which way to turn to raise the beams?
  8. #26
    sciphi is offline [OP]
    5,163
    Quote Originally Posted by rbtec View Post
    IIRC it's clockwise. Have the headlights on and aimed at a wall. If the beam lowers, go the other way. Make sure to count the turns the screwdriver is making!!! They don't need much adjustment, maybe 1-1.5 complete turns up.
  9. #27
    Jan 2013
    1
    How do you determine center of the headlight beam
  10. #28
    Dec 2012
    Halifax, PA
    90
    Every car and motorcycle I've ever owned has needed its headlights raised. I don't get all techie with measurements etc. Just adjust low beam so whem following a standard height sedan the cut off is just below their outside mirrors on a level hiway.
    If you drive at night like I do (every night) Keep the screwdriver with you and fine tune balancing the high beam pattern.
    crazylegs likes this.
    2012 Red Metalic Tintcoat 1.4T auto 1LT on 11/26/2012! Now 50k miles.
    2014 bright red 1.4T auto 1LT 5/22/16
    2006 Honda ST1300
    2007 Honda 250 Nighthawk
  11. #29
    9
    Quote Originally Posted by Mick View Post
    Counterclockwise to raise is correct, clockwise to lower. Screw down (in) to lower, back out, (up) to raise. I have been messing with mine a little bit. 1/4 turn will do a lot to fine tune. I keep mine up as high as I can without getting the oncoming bright flash from other motorists. I drive at night about 1/3 of the year and am always watching out for deer on the road. I saw 3 cross in front of me this morning.
  12. #30
    Handbrake Released Aussie SRi-V's Avatar
    Aug 2012
    Australia
    216
    Working through this thread this is what I came up with.
    Happy to amend if there is GM documentation on the alignment limits or if my figures are out.
    I'm sure they will have a documented procedure floating around somewhere..Cruze headlight alignment.jpg
  1. Adjusting the trunk open force
    By Patman in forum Gen1 Appearance, Body, Detailing, & Interior
    Last Post: 02-14-2012, 08:16 PM
  2. Adjusting boost?
    By 2011ecosa in forum Gen1 Powertrain
    Last Post: 10-18-2011, 11:30 PM
  3. OEM Headlights
    By FieroItaliano85 in forum Cruze Parts
    Last Post: 09-08-2011, 09:06 PM
  4. WTB: OEM Headlights
    By Mkulrey13 in forum Cruze Parts
    Last Post: 08-26-2011, 03:40 PM
  5. adjusting headlight questions
    By Derek_sngr in forum Gen1 Appearance, Body, Detailing, & Interior
    Last Post: 04-19-2011, 09:35 PM
