Oil pan heater... - Page 3
Page 3 of 7 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 65
Like Tree19Likes
Thread: Oil pan heater...
  1. #21
    Handbrake Released GotDiesel?'s Avatar
    Sep 2013
    232
    A few loose bolts in the engine bay , wires not crimped in the engine bay and my back window on the passenger side was warped and needs/will be replaced and 3 missing clips that hold trunk liner were missing .
    Manny
  3. #22
    Merc6's Avatar
    Jun 2013
    Cleveland, Ohio East
    10,021
    Quote Originally Posted by GotDiesel? View Post
    ..3 missing clips that hold trunk liner were missing...
    That's what NickD was talking about if I can remember.
    Hidden Content Hidden Content
    2017 San Marino Red Honda Accord Sport 6MT (DD) Hidden Content
    2013 Black Granite Metallic Chevy Cruze ECO 6MT (Traded) Hidden Content
    2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) Hidden Content
  4. #23
    Jun 2013
    Coboconk ,ontario
    748
    Quote Originally Posted by Hack View Post
    I'm thinking the opening from the engine shield recall, route it under there, then zip tie the plug to the bottom of the bumper
    -Posted from my Galaxy Note 2 on VZW's LTE network.
    what is this recall that your referring to??
  6. #24
    Merc6's Avatar
    Jun 2013
    10,021
    Quote Originally Posted by oilburner View Post
    The engine shield was cut on 2011 and 2012 Cruze to prevent oil fires from piss poor oil change practices. 2013 and on got a new shield from the factory already cut. In short if you open the hood and look down and see ground, it's been cut.
  7. #25
    Jun 2013
    4,649
    Does anybody know the lowest temp this car is designed to start at, without any heater?
    I watch cold start videos on Youtube all the time and I see many diesels sitting overnight at well below -20 starting up without being plugged in or anything. I, personally, will not worry about that. The only diesel I ever had an issue starting was a 1979 Mercedes 300D with low compression. It would not start when it dropped below zero (but it was quite a show trying to get it to start!)
    2014 Chevy Cruze Clean Turbo Diesel 202K (Domenic), 1986 Mercedes 300E 5 Speed odo broken (Rammstein - Sold and then repurchased), 2017 Honda Civic Sport Hatchback 6M 7K (Gordon), 2004 Mercedes S430 4Matic 187K (Kevin) - Going to be the daily grinder for now, but I still love my Cruze!!
  8. #26
    Blue Angel's Avatar
    Ottawa, Ontario, Canada
    4,649
    Good day bigluke and others. It's a little hard to follow the start of this conversation as there are some deleted posts, but I think I've got he basic idea.
    I'm not sure if the oil pan heater on the TD is the same as the one on the gas Cruze, but if it is, I posted a thread a while back on how to defeat the thermostat inside the heater cord.
    NOTE: This is a non-reversible modification and the cord is not cheap from the dealer, so modder beware.
    On the gas Cruze the oil pan heater has a thermostat that doesn't allow it to turn on until the temperature drops below 0F (-18C). I modified teh cord to allow the heater to activate regardless of outside temperature. The gas car has the potential to set an SES light if a block heater is used. This is because the car runs a diagnostic when teh key is switched on and if two different temperature sensors in the engine don't register within a few degrees of each other on start up the car assumes an issue with one of the sensors.
    I don't know if the Cruze TD has similar diagnostics, or if the oil pan heater even has a thermostat in the cord. Here's the thread in case there's any relative information:
    http://www.cruzetalk.com/forum/57-ho...t-removal.html
    Since doing this modification to the heater cord I have educated myself quite a bit on engine oils. I am VERY convinced that even this little 200W oil pan heater is making a significant difference in how easy it is to pump the oil when starting at extreme temperatures. Warming the oil even a few degrees can make a huge difference in its viscosity at low temperatures, as can be seen in the following graph here:
    Widman viscosity graph - Bob Is The Oil Guy
    Anyone who is interested in learning about oil should consider reading through the "Oil University" tutorial on that Bob Is The Oil Guy site. Engine oil viscosity is not an overly complicated topic to comprehend, but it is really surprising how many people "think" they know certain things about oil, when in reality they know very little.
  9. #27
    Autocross Champion boraz's Avatar
    Aug 2013
    BC
    1,906
    ive never plugged in any vehicles til -15c anyways
  10. #28
    Tomko's Avatar
    May 2013
    6,214
    I only would plug in at -13 F and that was with a carburetated engine.
    Never plugged in a fuel injected engine.
    Cruze Diesel has been tested to start unassisted at -20 (one source says -22).
    The Diesel's oil pan heater does NOT have a thermostat.
    Tomko
    Current Fleet:
    2014 Cruze Diesel (daily grinder)
    2008 DTS Lux III (pleasure craft)
    1996 Impala SS (garage queen)
    Retired Fleet:
    1999 Tahoe PPV (14.5 years / 135,879 miles)
    1988 Caprice 9C1 (first new car)
    1984 6000 STE (first car)
  11. #29
    Blue Angel's Avatar
    4,649
    Quote Originally Posted by Tomko View Post
    Good info, thanks!
    Regardless of how cold the engine is capable of starting, cold oil is cold oil. Anyone starting any engine, gas or diesel, in extremely cold environments will be doing their engines a big favor by using a good full synthetic oil as well as using the oil pan heater.
  12. #30
    bigluke is offline [OP]
    1st Gear bigluke's Avatar
    Aug 2013
    Quebec, Canada
    287
    Thanks for the info! Never plugged a gas engine either but I want to baby this diesel because I want to keep this car as long as I can. Great info again!
  1. Cruze 1.4 LT Oil Pan Heater
    By Wally in forum Gen1 Powertrain
    Last Post: 01-27-2016, 12:06 AM
  2. DIY - Oil Pan Heater Thermostat Removal
    By Blue Angel in forum Gen1 Engine/Transmission Tutorials
    Last Post: 03-06-2015, 07:48 AM
  3. Oil Pan Heater?
    By Knucklehead1964 in forum Gen1 Powertrain
    Last Post: 12-03-2013, 05:03 PM
  4. Oil pan heater cord
    By bkarsin in forum General Discussion
    Last Post: 02-02-2013, 07:18 PM
  5. oil pan heater cable
    By mr_raider in forum General Discussion
    Last Post: 11-26-2012, 12:38 AM
