2013 Cruze New Engine Shield Photo, or What's Left of It.
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Like Tree7Likes
Thread: 2013 Cruze New Engine Shield Photo, or What's Left of It.
    Autocross Champion NickD's Avatar
    1,789
    As opposed to the 2012, only that panel on the right side of the vehicle is left. This car was parked about a block away from the dealers showroom, didn't bother him to open the hood. Still curious if that oil filter is in the same location.
    Starks8 likes this.
    Touring Champion jblackburn's Avatar
    3,690
    Well, at least it looks cleaner than hacking it up. Still seems like it's just the lazy way out of the problem, but whatever.
    2012 Cruze 1LT 6M
    1,789
    Is this really a lazy way out of the problem, or more precisely, a solution to the problem? That red hot exhaust system is still between that oil filter housing and the ground.
    5th Gear
    Hoon's Avatar
    984
    There's nothing wrong with the oil filter location.
    Compared to many transverse V6s there's a lot more room between the filter and the exhaust. It's also not directly above the turbo or cat, and even if it was, it still wouldn't be the cause of any engine fires. Nowhere does it say a fire or problem has been caused by oil leaking from the filter onto exhaust components. It's common knowledge that sloppy oil change procedures can lead to oil puddling in the shield, which can catch fire if that oil splashed onto the hot exhaust.
    You seem to have this recurring thought that the oil filter location is somehow a safety concern, when that is clearly not the case.
    '05 GSXR750 - Turbo
    '12 Cruze - DD/tow vehicle
    Resident Forum Drunkard brian v's Avatar
    1,239
    I refused the recall ..since the problem is atrbuted to spilled oil I do not spill oil onto the shield .
    chevy is changing a flaw they did not for see .due to human error oil pools on the older shields . I do check this shield often just in case oil leaks from the engine though it is a combustion engine . and they do leak oil.......a fix in design is just that .engine designs will not change much ..
    jdubb11 likes this.
    veteran Retired
    5th Gear
    Hoon's Avatar
    984
    Quote Originally Posted by brian v View Post
    Exactly, a few carefully drilled holes will be a perfect solution for the non-retards. Understandably, chevy can't take that chance.
    jblackburn likes this.
    '05 GSXR750 - Turbo
    5th Gear GoldenCruze's Avatar
    Central Ohio
    906
    Quote Originally Posted by NickD View Post
    I have more than one vehicle where the oil filter is above the exhaust system. And I have also had more than one engine that developed a leak in the valve cover gasket, which let oil run down onto the exhaust manifold. Never a fire, but sometimes some smoke.
    Going out for a CRUZE
    Accelerating to 6th gear!
    3,690
    Quote Originally Posted by GoldenCruze View Post
    ^Same. My Volvo even leaked directly onto the turbo, and it never caught fire. Smelled bad, though...
    Our old Toyota did it too.
    2012 Cruze 1LT 6M
    Drag Champion 2013Cruze's Avatar
    Aug 2012
    East Moline IL
    1,716
    My question is this if the Verano has the same engine shield as the Cruze why hasn't this become a problem for the Verano. Do Buick dealership hire better mechanics then chevy dealers do?
    6,510
    Attachment 9377
    That cut looks like it was done by a drunkard. I have a cleaner cut on my Cruze.
    Quote Originally Posted by 2013Cruze View Post
    The Verano's engine is plumbed differently so the exhaust doesn't run over as much of the shield and definitely not over where oil would pool. The real issue is the shield design itself was flawed. 1st - why make a under engine shield that can melt and burn (plastic vs. aluminum). 2nd - why make a shield that when sitting on level ground doesn't completely slope to the back where any liquid on it, regardless of viscosity can run off.
    steve333 and OnlyTaurus like this.
    2012 ECO MT - Black Granite/Cloth; Bluetooth Stereo AUX; OEM Fogs w/Chrome Covers; GM Spare tire; VG Shark Fin
    1986 Fiero GT MT (traded for Transport)
  1. Before and after pic of the engine shield recall
    By mcg75 in forum Service Issues
    Last Post: 03-22-2013, 07:12 PM
  2. Engine Shield after recall
    By mike505 in forum Service Issues
    Last Post: 01-29-2013, 10:44 AM
  3. Had your engine shield recalled? Has your car become unstable?
    By XtremeRevolution in forum Service Issues
    Last Post: 10-09-2012, 10:44 PM
  4. The purpose of the engine shield
    By GoldenCruze in forum Chevrolet Cruze General Discussion Forum
    Last Post: 07-21-2012, 11:13 AM
  5. Engine Shield Recall - Done
    By jfischer in forum Chevrolet Cruze General Discussion Forum
    Last Post: 06-28-2012, 11:28 AM
