RPO Code List
The following table provides the description of the Regular Production Option (RPO) codes that are available on the vehicle. The vehicle's RPO list is printed on the Service Parts Identification Label, located on the right hand glove box door.
RPO Description
01A TRIM COLOR SEAT - JET BLACK
01B TRIM COLOR SEAT - LT NEUTRAL
01K TRIM COLOR SEAT - BRICK
01S TRIM COLOR SEAT - MED TITANIUM
03C TRIM COLOR SEAT - FURY RED
04Y TRIM COLOR SEAT - Midnight Onyx
1AB TRIM COLOR DR PANEL - JET BLACK
1AC TRIM COLOR DR PANEL - LT NEUTRAL
1AR TRIM COLOR DR PANEL - MED TITANIUM
1BF TRIM COLOR DR PANEL - BRICK
1BY TRIM COLOR DR PANEL - FURY RED
1CN TRIM COLOR DR PANEL - Midnight Onyx 939T
4AA INTERIOR TRIM - JET BLACK
4BO INTERIOR TRIM - COCOA/LIGHT NEUTRAL
A51 SEAT - FRT BKT, CUSTOM
A53 ADJUSTER PASS ST - MANUAL, 6 WAY
A64 SEAT RR - SPLIT, FOLDING, 40/60
A69 RESTRAINT - SEAT BELT TENSIONER, FRT, VAR. 2
AAW INTERIOR TRIM CONFIG - #17
AAX INTERIOR TRIM CONFIG - #18
AAY INTERIOR TRIM CONFIG - #16
ABX INTERIOR TRIM CONFIG - #19
ABY INTERIOR TRIM CONFIG - #20
ACB INTERIOR TRIM CONFIG - #21
ACI INTERIOR TRIM CONFIG - #23
ACC INTERIOR TRIM CONFIG - #22
ADS ADJUSTER FRT ST - POWER, MULTI-DIRECTIONAL, RECLINER MANUAL, DRIVER
AEC WINDOW - POWER OPERATED, DRIVER EXPRESS DOWN
AED WINDOW - POWER OPERATED, PASSENGER, EXPRESS DOWN
AEQ WINDOW - POWER OPERATED, RR DRS, EXPRESS DOWN
AFA INTERIOR TRIM CONFIG - #1
AFB INTERIOR TRIM CONFIG - #2
AFC INTERIOR TRIM CONFIG - #3
AFF INTERIOR TRIM CONFIG - #6
AFG INTERIOR TRIM CONFIG - #7
AFK INTERIOR TRIM CONFIG - #11
AFN INTERIOR TRIM CONFIG - #14
AFO INTERIOR TRIM CONFIG - #15
AFP INTERIOR TRIM CONFIG - #44
AH4 ADJUSTER FRT ST - MANUAL, 6 WAY, DRIVER
AHN RESTRAINT PROVISIONS - LATCH
AJC RESTRAINT - HEAD, FRT SEAT, UP/DOWN ADJUSTMENT
AKK WINDSHIELD STYLE - ACOUSTIC PVB
AKP WINDOW TYPE - SOLAR ABSORBING
AKX WINDSHIELD TYPE - SOLAR ABSORBING
AL0 SENSOR INDICATOR - INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR
AQP RESTRAINT - HEAD, RR SEAT, CENTER
ASV EQUIPMENT - SENSOR AIR MOISTURE & W/S TEMP
AU3 LOCK CONTROL - SIDE DR, ELEC
AWO RESTRAINT SYSTEM RR - SEAT BELT, REAR, 3 POINT, CTR
AXG WINDOW - POWER OPERATED-EXPRESS DRIVER UP/DOWN
AXJ VEHICLE TYPE - PASSENGER CAR
AYF RESTRAINT SYSTEM - SEAT, INFLATABLE, DRIVER & PASS FRT, FRT SEAT SIDE & RR SEAT SIDE, ROOF SIDE, KNEE
B34 COVERING FRT - FLOOR MATS, CARPETED INSERT
B35 COVERING REAR - FLOOR MATS, CARPETED INSERT
B76 CLUSTER COLOR - INST, BLACK
BAH EQUIPMENT - SECURITY SYSTEM, IMMOBILIZATION, STEP TWO
BS1 INSULATION - ACOUSTICAL PKG
BTV REMOTE START - ENGINE
BVG KIT - BODY KIT, SPORT
C42 HVAC SYSTEM - HEATER, OUTSIDE AIR, DELUXE
C49 DEFOGGER - RR WINDOW, ELECTRIC
C67 HVAC SYSTEM - AIR CONDITIONER FRT, ELECTRONIC CONTROLS
C68 HVAC SYSTEM - AIR CONDITIONER FRT, AUTO, ELECTRONIC CONTROLS
C91 LAMP - INTR, ROOF, COURTESY
C95 LAMP - INTR, ROOF, COURTESY & DUAL READING
CF5 ROOF - SUN, GLASS, SLIDING, ELEC
D31 MIRROR I/S R/V - TILT
D6I MIRROR I/S FRT VAN - SUNSHADE, DRIVER, W/MIRROR, COVER, ILLUM, PASS, W/MIRROR, COVER, ILLUM
D7A HANDLE O/S DOOR - BODY COLOR, CHROME STRIP
D75 HANDLE O/S DOOR - BODY COLOR
DA1 ARM REST - RR SEAT, STORAGE
DBU CONSOLE - FRT COMPT, FLOOR, ARM REST SLIDING
DD8 MIRROR I/S R/V - LT SENSITIVE
DLV MIRROR I/S FRT VAN - SUNSHADE, DRIVER & PASS, W/MIRROR & COVER
DP6 MIRROR PROVISIONS - HOUSING, PAINTED
DWE MIRROR O/S - LH & RH, RC, ELEC, HEAT, AUX WFOV/DRVR, MANFOLD, CNVX/PASS
DWF MIRROR O/S - LH & RH, RC, ELEC, HEAT, AUX WFOV/DRVR, PWRFOLD, CNVX/PASS
DWT MIRROR O/S - LH & RH, RC, MANFOLD, AUX WFOV/DRVR, CNVX/PASS
DWY MIRROR O/S - LH & RH, RC, ELEC, MANFOLD, AUX WFOV/DRVR, CNVX/PASS
DVR CLUSTER COLOR - INST, BLACK, TRANSLUCENT RINGS W/CHROME TOP
E17 BUMPER - 2.5 MPH
E3E HANDLE - O/S, L/GATE, R/CMPT, CHROME
EA1 POCKET - FRONT SEAT BACK, LH
EA2 POCKET - FRONT SEAT BACK, RH
EBF TRIM SEAT - LEATHER, MERIDIAN
EBJ TRIM SEAT - CLOTH, MESH
EF7 COUNTRY - UNITED STATES OF AMERICA (USA)
EN4 COVER, RR COMPT - HARD, RR COMPT, CARGO
EQK TRIM SEAT - LEATHER, PINNACLE
FCT TRIM DOOR - MESH FABRIC
FCU TRIM DOOR - PU LEATHER
FE9 CERTIFICATION - EMISSION, FEDERAL
FHS VEHICLE FUEL - GASOLINE E85
FHT VEHICLE FUEL - GASOLINE E100
FW7 RATIO - TRANSAXLE FINAL DRIVE 3.83
FX1 RATIO - TRANSAXLE FINAL DRIVE 3.94
FX3 RIDE AND HANDLING - AUTOMATIC ELECTRONIC CONTROLLED
FX6 RATIO - TRANSAXLE FINAL DRIVE 3.87
GAN PRIMARY COLOR - EXTERIOR, SWITCHBLADE SILVER MET (G) 636R
GAO PRIMARY COLOR - EXTERIOR, GOLDMIST MET (G) 316N
GAP PRIMARY COLOR - EXTERIOR, IMPERIAL BLUE MET (G) 403P
GAR PRIMARY COLOR - EXTERIOR, CARBON FLASH MET (G) 501Q
GAZ PRIMARY COLOR - EXTERIOR, OLYMPIC WHITE (G) 8624
GBE PRIMARY COLOR - EXTERIOR, CRYSTAL CLARET TINTCOAT (G) 505Q
GGW PRIMARY COLOR - EXTERIOR, DK LABRYINTH MET 707S (62U)
GLF PRIMARY COLOR - EXTERIOR, SPACE BLUE METALLIC 819T
GNA CHASSIS EQUIP FRONT - STRUT ASM
GNG CHASSIS EQUIP REAR - REAR AXLE, COMPOUND CRANK, ADDITIONAL WATT LINKAGE
GNF CHASSIS EQUIP REAR - REAR AXLE, COMPOUND CRANK
J67 BRAKE SYSTEM - POWER, FRT & RR DISC, ABS, 15"
J93 BRAKE SYSTEM - POWER, FRT DISC, RR DRUM, ABS, 15"
JJ2 BRAKE LINING - BRAKE NOISE AND DUST PERFORMANCE
K09 GENERATOR - 120 AMP
K34 CRUISE CONTROL - AUTOMATIC, ELECTRONIC
KA1 HEATER - SEAT, FRT
KC7 RECEPTACLE - ELECTRICAL, RR SEAT
KCL HEATER - DUCT, RR PASS (2ND POSN)
KPK HEATER - OIL PAN
KTF KEY - PRIMARY FOLDABLE, ADDITIONAL FOLDABLE
KTA AUDIO INTERFACE
LHD VEHICLE DRIVE - LEFTHAND DRIVE
LOD PLANT CODE - LORDSTOWN, OH, USA
LUJ ENGINE - GAS, 4 CYL, L4, 1.4L, MFI, DOHC, TURBO HO, ALUM, GME
LUW ENGINE - GAS, 4 CYL, 1.8L, MFI, 103KW, DOHC, E85 MAX
MDC MOLDING B/S UPPER - BRIGHT
MF3 TRANSMISSION - MAN 6 SPD, OPEL, 76.5 MM, 4.273 1ST, 2.158 2ND, 1.302 3RD, 0.959 4TH, 0.744 5TH, 0.614 6TH, M32-6 WR
MH8 TRANSMISSION - AUTO 6 SPD, HMD, X23F
MZ0 TRANSMISSION - MAN 6 SPD, OPEL, 76.5 MM, 3.82 1ST, 0.74 6TH, (M32 WR)
MZ4 TRANSMISSION - MAN 6 SPD, OPEL, 76.5 MM, 3.82 1ST, 0.615 6TH, (M32 WR)
N34 STEERING WHEEL - LEATHER, 3 SPOKES
N37 STEERING COLUMN - TILT, TELESCOPING
N45 STEERING WHEEL - 3 SPOKES
N92 COVER, WHEEL - BOLT-ON
NAG COVER, WHEEL - BOLT-ON, VAR 1
NE1 CERTIFICATION - EMISSION, GEOGRAPHICALLY RESTRICTED REGISTRATION FOR VEHICLES UP TO 14,000 LBS GVW
NJ1 STEERING - POWER, NON-VARIABLE RATIO, ELECTRIC
NL6 FUEL TANK - 49L, 13 GAL, SINGLE
NT7 EMISSION SYSTEM - FEDERAL, TIER 2
NU5 EMISSION SYSTEM - CALIFORNIA, BIN 4
P76 TIRE & WHEEL - SPARE, SPACE SAVER, STEEL 16"
PJE WHEEL - 17 X 7.0, J, ALUMINUM, DESIGN 10
PWL WHEEL - 15 X 6.5, STEEL, DESIGN1
PL0 POWER LEVEL - BASE PERFORMANCE LEVEL
PWM WHEEL - 16 X 6.5, STEEL, DESIGN2
PZV WHEEL - 18 X 7,5, J, ALUMINUM, DESIGN 7
QYF TIRE ALL - P225/50R17 SL 93 H BW AL3
QYW TIRE ALL - P215/60R16-94S BW R/PE ST TL ALS
RQ7 TIRE ALL - P215/55R17 SL 93S BW ALS
RTN WHEEL - 17 X 7.0, J, ALUMINUM, DESIGN 2
T4A HEADLAMPS - HALOGEN
T43 SPOILER - RR
T74 HEADLAMPS CONTROL - AUTOMATIC, DELAY
T83 HEADLAMPS CONTROL - AUTOMATIC ON-OFF
T3U LAMP - FRT FOG
T3W LAMP SYSTEM - DAYTIME RUNNING, REDUCED INTENSITY LOW BEAM
TM7 BATTERY - LN2, FLA, 12V, 60AH, 438 ENCCA
TPV GRILLE - RADIATOR, BLACK, W/CHROME BAR
TS6 LAMP - STOP, HIGH LEVEL
TTO RADIO EQUIPMENT - COOLING SYSTEM
TTX RADIO EQUIPMENT - AUX CONNECTOR (LINE IN)
TU2 LAMP - MARKER, SIDE
U04 HORN - SINGLE NOTE
U07 HORN - FANFARE
U19 SPEEDOMETER - INST, KILO & MILES, KILO ODOMETER
U68 DISPLAY - DRIVER INFO CENTER
U91 ANTENNA - SHORT, ROOF, RADIO
U2K DIGITAL AUDIO SYSTEM - S-BAND
UAG INFOTAINMENT DISPLAY - GRAPHIC INFO DISPLAY (GID), VAR 1
UD7 SENSOR INDICATOR - REAR PARKING ASSIST
UDB DISPLAY INSTRUMENT - DRIVER INFO ENHANCED (SEGMENTED)
UDC DISPLAY INSTRUMENT - DRIVER INFO ENHANCED (ONE COLOR GRAPHIC)
UDN INFOTAINMENT DISPLAY - COLOR INFO DISPLAY (CID) 7", WVGA
UEC SENSOR INDICATOR - AUTOMATIC AIR RECIRCULATION
UFD INFOTAINMENT DISPLAY - TIME, EXTERNAL TEMP, RADIO
UH0 INDICATOR - SEAT BELT WARNING , LH
UH1 INDICATOR - SEAT BELT WARNING , RH
UJ2 INDICATOR - ENGINE OIL LIFE
UJM TIRE PRESS INDICATOR - MANUAL LEARN
ULS LOCK CONTROL - STEERING COLUMN
UMN SPEEDOMETER - INST, MILES & KILO, MILES ODOMETER
UPF WIRELESS INTERFACE - SHORT RANGE, VOICE REC
UQA SPEAKER SYSTEM - PREMIUM AUDIO BRANDED WITH AMPLIFIER
UTJ THEFT DETERENT - ELECTRICAL, UNAUTHORIZED ENTRY
UYC RADIO - AM/FM STEREO, CD-ROM, CAF, RSA (GMNA VERSION)
UYE RADIO - AM/FM STEREO, CD-ROM, CAF, RSA, MUSIC NAVIGATOR (GMNA VERSION)
UYS RADIO - AM/FM STEREO, NAV, DVD-ROM, CAF, HDD, USB, RSA, RSE (GMNA VERSION)
UZ6 SPEAKER SYSTEM - 6, PREMIUM
V48 COOLANT - ENGINE MAXIMUM PROTECTION
VCG PROVISIONS - INTERNATIONAL SWITCH/CONTROL SYMBOLS
VHY PROTECTOR - BODY SHEET METAL, HIGH CORROSION PREVENTIVE
VK3 LICENSE PLATE FRONT - FRT MOUNTING PKG
VTW COMPARTMENT - STOWAGE, I/P, W/LID
VWC PANEL CENTER - INSTRUMENT, HIGH GLOSS BLACK
VY7 KNOB - TRANS CONT LEVER, LEATHER
VZ3 LABEL - MERCURY DISPOSAL NOTIFICATION
W1Y CONTROL - STEERING WHEEL, RADIO, REDUNDANT CONTROLS
WA7 PERFORMANCE PACKAGE - AERO
WR6 WHEEL - 16 X 6.5, J, ALUMINUM, DESIGN 8
WTC TIRE & WHEEL - INFLATOR KIT (DO NOT USE AFTER M.Y. 2011)
XJ2 CHASSIS - SPORT, LOWERED
XL7 FREQUENCIES RATING - 315 MHZ, LONG DISTANCE
Y67 DISPLAY - REMINDER PACKAGE
Y8X FUEL ECONOMY - ENGINE IMPROVEMENT
YF5 CERTIFICATION - EMISSION, CALIFORNIA
Z49 COUNTRY - CANADA
Z54 MODEL CONVERSION - LT
Z64 MODEL CONVERSION - LTZ
LinkBack URL
About LinkBacks
Reply
