They say best things come in 3 right? (Perhaps the universe is telling me something)..
I have a 2011 Chevy Cruze LS 91,000 miles, car has been in a shop many times for warranty repairs due to thermostats going out, oil leaks, water pump leaks etc. Recently I was rear ended with minimal damage, then the next day had a guy back up into my rear left quarter panel. Now my car broke down to seems like an unrelated issue, or is it?
I am driving down the road and start to notice a squeal coming from the belts it seems, I immediately turned off my A/C, squealing continued. I then noticed white what appears to be vapor coming out of my vents, understandable since I was using recirculating air and its 80+ outside with high humidity. Then at the light my car was idling very rough and stability track maintenance light came on I pulled over immediately, then the check engine light came on. Since this car has had so many problems I bought a reader and read P0171 code, running too lean. I checked the air box to make sure that air flow mesh looking thing inside was still on, I've had it fall out before and causing the same symptoms. The mesh is intact and the car is still idling rough, I can hear what sounds like a vacuum leak as well as a squeal coming from the belt area. What can this possibly be?
Is my car safe to drive at least to make it to a dealership?
This is all I can find but cant find the actual procedure to fix this thing.
PI0850..........Whistle noise from engine compartment, rough idle and/or DTC P0171 set.
Maybe due to (PVC) Leak on Camshaft cover, anything else?
