TOP TIER Detergent Gasoline - Page 8
Page 8 of 9 FirstFirst ... 6 7 8 9 LastLast
Results 71 to 80 of 82
Like Tree13Likes
Thread: TOP TIER Detergent Gasoline
  1. #71
    Aug 2012
    18
    PS--after reading on the Mobil website, it appears 87 octane will be just fine for my car. As long as it's top tier gas, as the owners manual says. SO Mobile/87 is what I'll use from now on.
  3. #72
    4,339
    Interestingly, at a nearby corner, one gas station is Chevron and directly across the intersection is a Shell...but BOTH are operated under the "GIANT" franchise!
    2009 Pontiac Vibe 1.8L/SFI 4A
    2004 Pontiac Vibe 1.8L/MFI 4A
    1971 Dodge Charger 318 3A
    1968 Dodge Charger 383 3A
  4. #73
    titan2782's Avatar
    Nov 2011
    SoCal
    2,018
    Quote Originally Posted by 70AARCUDA View Post
    It's common for this. In fact, I can pull into my Chevron station and drive into the Shell next door. I commonly see these two stations together or in very short proximity.
    2014 Genesis Coupe 3.8 R-Spec Hidden Content
    2005 SRT4 ACR
    2011 Cruze Eco: Gone
  6. #74
    Aug 2012
    18
    do you pour Lucas right into your gas tank??
  7. #75
    Aesop
    9,934
    Consequences of NOT using top tier gasoline: May also apply to the Cruze.
    "TECHNICAL
    Bulletin No.: 03-06-04-030G
    Date: April 22, 2009
    Subject:
    Various Driveability Symptoms Due to Clogged Fuel Injectors, MIL/SES DTCs P0171, P0172, P0174, P0300, P1174, P1175 (Clean Fuel Injectors and/or Perform Injector Test With AFIT CH-47976)
    Models:
    2005-2009 GM Passenger Cars and Light Duty Trucks
    2005-2009 HUMMER H2
    2006-2009 HUMMER H3
    2005-2009 Saab 9-7X
    Zoom and Print Options
    Equipped with Engine RPOs listed in the Table above and MULTEC(R) 2 Fuel Injectors
    Attention:
    GM does not support cleaning injectors on any engines that are not listed in this bulletin. Engines other than the ones listed in this bulletin that diagnosis indicates having restricted injectors should have those injectors replaced.
    Supercede:
    This bulletin is being revised to update the model year to 2009 and to provide applicable engine RPO table. Please discard Corporate Bulletin Number 03-06-04-030F (Section 06 - Engine/Propulsion System).
    Condition
    Some customers may comment on any of the following various driveability symptoms:
    - Extended Crank Time
    - Hard to Start
    - MIL/SES Illuminated with DTCs
    - Hesitation
    - Lack of Power
    - Surge or Chuggle
    - Rough Idle
    - Light or Intermittent Misfire
    Cause
    Due to various factors, the fuel injectors may become restricted. Extensive testing has demonstrated that fuel related issues are the cause of clogged injectors. At this point, no specific fuel, fuel constituent, or engine condition has been identified as causing the restriction. The restriction causes the engine to operate at a lean air fuel ratio. This may either trigger the MIL to illuminate or the engine to develop various driveability symptoms.
    Correction
    Fuel injector restrictions, deposits can be cleaned on the vehicle using the following procedure. Under NO circumstances should this procedure be modified, changed or shortened. As a long term solution, and to prevent reoccurrence, customers should be encouraged to use Top Tier Detergent Gasoline. For further information on Top Tier detergent gasoline and fuel retailers, please refer to the following Corporate Bulletin Numbers:
    - 04-06-04-047G (U.S. Only)
    - 05-06-04-022D (Canada ONLY)
    Notice
    GM UPPER ENGINE AND FUEL INJECTOR CLEANER is the only injector cleaning agent approved for use with General Motors fuel system components. Other injector cleaners may cause damage to plastics, plated metals or bearings. General Motors has completed extensive laboratory testing of GM Upper Engine and Fuel Injector Cleaner, and can assure its compatibility with General Motors fuel system components, as long as the cleaning procedure is followed correctly."
  8. #76
    23,025
    Is there a newer bulletin than the one NickD posted.? His was written before the first Cruze rolled off the line in Lordstown.
    Hidden Content Hidden Content
    2002 Pont Montana AWD (traded for 2012 LS @182K miles - title transferred to son on college graduation)
  9. #77
    Aesop
    9,934
    Is it to wrong to assume that injectors are injectors? Major difference is the nozzle size, and you can bet your last buck that the nozzles in the Cruze engine are much smaller prone to further restrictions.
    Ethanol really screwed up the injectors in my 88 Supra using a brass tipped nozzle, but was able to save those with a lot of work. But new ones would only cost 600 bucks, only to corrode shut after a couple of tank fulls.
    I think about that when buying gas, only the very best goes into my vehicle's. Now I am favoring Mobil 91 octane top tier ethanol free gas. Nice little station I pass by frequently ten miles north of town.
  10. #78
    spacedout's Avatar
    SW Wisconsin
    6,921
    Decided to post on this old topic since the website Ethanol-free gas stations in the U.S. and Canada was mentioned earlier in this thread. Allot of the info on that website about what stations have 100% gas and what octane they offer is incorrect. You can update any of this outdated info or add new locations without creating an account, I think I did a dozen locally in a few minutes. Think it would be great if other cruze owners updated any they find too.
    One local Mobil station I drove by today that always had the cheapest premium (93octane 10% ethanol) now has a sign out front saying "premium contains no ethanol". Drove in and sure enough the fuel is now 91 octane with no ethanol.
  11. #79
    Apr 2013
    BOLTON,ONTARIO,CANADA
    28
    Quote Originally Posted by audog View Post
    I have found that mine runs best on 93 Octane Shell gasoline, don't know why, but it seems to get about 2 mpg better with the Shell, than with other brands
    I agree ,I have been using shell v-power and the car runs so much better ,smoother,more responsive ,and a little further on a tank of gas .From 87 octane to 91 or higher it's a matter of 5-6 dollars difference more to fill but it feels like it has a little more power then when I run 87 octane .Well worth the $5,and I know my engine is cleaner, injectors stay clean ,no carbon build up = lower maintenance costs down the road.
  12. #80
    Mar 2013
    7
    For me, the 5 or 6 dollar difference each time I fill up, whice is 2 to 3 times a week adds up to around $575 a year difference so I am using 87 exclusivly now. I do know that 87, 89, and 93 rated gasolines have the same detergents or cleaning additives within the gas itself. This subject seems relative to the driving and vehicle you have, but I have tried all three grades and the difference for me in my 2013 is about 1mpg difference, and the car drives seems to drive the same on all three so its a no brainer for my application.
  1. Top Tier Gas?
    By BucaMan in forum Gen1 Powertrain
    Last Post: 12-20-2012, 02:50 PM
  2. E15 vs 100% Gasoline
    By silvercruze in forum General Discussion
    Last Post: 05-24-2012, 04:43 PM
