new key program
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
Like Tree5Likes
Thread: new key program
    13
    new key program
    I decided to drop onstar and get an extra key with a "secret hiding place" under the car in case of lock out. I ordered the key from parts for a pricey sum and then was supposed to go the shop to program for another pricey sum. I did not have the 30 minutes required at that time and just rode the new key around for the rest of the day. I had tried it at the dealer when I first got it and it did not work. Later that day I discovered the key had programmed itself. Try it if you are going to get an extra key.
    4,339
    ...as Arte Johnson -- the "German Soldier" on LAUGH-IN -- used to say: "....V-E-R-Y...I-N-T-E-R-E-S-T-I-N-G..."
    2009 Pontiac Vibe 1.8L/SFI 4A
    2004 Pontiac Vibe 1.8L/MFI 4A
    1971 Dodge Charger 318 3A
    1968 Dodge Charger 383 3A
    9
    Humm, what else does this key do? It would appear, there is a wireless connection to the key.
    1st Gear Gritts's Avatar
    Jan 2011
    Virginia
    269
    Quote Originally Posted by rmsls1 View Post
    Yah und ein secret laser beam weapon to drill holes in Lexus engine blocks. One day Daimler will rule da verld!
    TechCruzer likes this.
    God put obvious limitations on our intelligence...but none whatsoever on our stupidity.
    3rd Gear TSURacing's Avatar
    Jan 2011
    Detroit
    558
    I do not know about our Cruze. But on my other GM vehicles with a chip in the key the process goes like this:
    1. Place an already programmed key in the key cylinder
    2. Cycle the ignition from OFF to ON (RUN) to OFF.
    3. Within 15 seconds, insert the new key in the ignition. Turn the ignition to the ON (RUN) or START position. The "security" indicator light will go on and then off. Turn the ignition "OFF".
    4. The new key will now start the vehicle.
    Programming the FOB is a bit different. Did your Fob start working too?
    n1philli likes this.
    Resident Derp Smurfenstein's Avatar
    Nov 2011
    Corona, CA
    2,810
    I saw something in the cruze manual, but i'm not entirely sure about it. In the weird triangle hole in between the E-brake and the shifter, there should be a piece of plastic on the bottom that you remove. Then, you take your new key and put it into the key-hole, and the key syncs to your car, allowing you to re-program/program a new wireless key to work with your car.
    **EDIT: and NO I didn't read EVERY page of the manual, but i still thumbed through the parts I didn't read.
    2012 Chevy Cruze LS 6AT- Track Potato
    2016 Subaruu Impreza 5MT - Street Potato
    Potato is life
    Handbrake Released maven's Avatar
    187
    To initiate, this procedure requires that 1 learned key be available
    A total of 8 keys maybe be learned to a single vehicle
    This procedure adds keys only. The procedure does not erase previously learned keys.
    The keys to be learned must duplicate the mechanical cut of the current key.
    1. With a previously learned key, turn the ignition ON.
    2. Turn the ignition OFF and remove the key.
    3. Within 10 seconds of turning OFF the ignition, insert the key to be learned and turn ON the ignition. The vehicle has now learned the new key and key transmitter.
    You have to use new key/fobs, they only learn one vehicle.
    jblackburn and eline65 like this.
    Custom built headlight retrofits, wiring harnesses and lighting supplies & parts.
    Aesop
    10,005
    My 2012 owners manual explains how to program a new remote. Can DIY. Only problem is paying a small fortune for that extra remote.
    Handbrake Released SeanM402's Avatar
    Wisconsin, USA
    178
    Quote Originally Posted by NickD View Post
    My dealer told me around $50 and I believe others on here have confirmed. I think one person said $80-90.
    Handbrake Released chuck5330's Avatar
    Oct 2011
    Just outside Memphis, TN
    114
    considerably cheaper on ebay
    2012 Chevy Cruze LS Summit White (now retired)
    2012 Chevy Cruze LT/RS Victory Red
    2013 Chevy Cruze LT/RS Blue Topaz Metallic
    Yeah its nice to have two around the house (still) Hidden Content
  1. Flaw in 2012 Cruze Build Your Own program...
    By Jim Frye in forum General Discussion
    Last Post: 08-16-2011, 06:33 AM
