Slow engine warm-up Cruze Eco?? - Page 2
Results 11 to 20 of 31
Thread: Slow engine warm-up Cruze Eco??
    Handbrake Released David1's Avatar
    Sep 2011
    Ohio
    247
    Mine takes 25 minutes to get to 220 when it is below 30 degrees. Makes defrosting the windows a bitch.
    13 Cyber Gray Cruze LT RS Auto
    BOOOOST!
    UpstateNYBill's Avatar
    Albany NY area
    1,381
    What fan speed setting are you using?
    Sep 2011
    Ohio
    247
    Quote Originally Posted by UpstateNYBill View Post
    Not even on high, 3 mostly. If I am on high, I hardly get heat.
    BOOOOST! limited360's Avatar
    Detroit, MI
    1,250
    I can suck my car from 190F back down to 150F by driving easy and putting defroster on high... this is when its 32F out only too...
    Going to be a complaint when it gets really cold from me...
    Suburban Washington DC
    198
    Shoulda sprung for the heated seats. Maybe you can add a block heater?
    Detroit, MI
    1,250
    Quote Originally Posted by atikovi View Post
    Block heater won't help anything... I can drive 40 miles (20 city, 20 highway) to work and still not be warmed up. Vehicle simply has too much cooling for the amount of heat this engine puts out!
    I don't see a point in heated seats in a 18k car... I will keep the HVAC seats in my Lincoln however...
    Apr 2011
    Westchester cty NY
    2,813
    Yes agreed - Engine warms up slow especially if you want interior heat. Like Sciphi, I let the engine warm up before even thinking about sending heat to the cabin. Last night it was around freezing, temp gauge was about 1/4 so I turned on the heat. The gauge started dropping. Small displacement engine/iron block all contribute to slowness to warm.
    5th Gear GoldenCruze's Avatar
    Central Ohio
    904
    I don't see a drop in temp on the DIC when I turn on the heat.
    BOOOOST!
    Albany NY area
    1,381
    Quote Originally Posted by David1 View Post
    Try setting it on 2. I defrosted my windshield and got heat within about 5 miles on this setting. Outside temp was about 20 degrees. The higher the fan setting, the longer it will take to warm up.
    BOOOOST!
    Albany NY area
    1,381
    Quote Originally Posted by GoldenCruze View Post
    Where are you located? Someplace warmer? I can definitely make the temperature drop on a higher fan setting, which is why I set it to 1 or 2. Once the block has warmed up, then I can turn up the fan more, but even on a fan setting of 2, I have to turn down the temperature control because it gets quite warm in the car.
  1. Slow Shifts, Hanging Shift
    By skavfive in forum Gen1 Powertrain
    Last Post: 08-06-2013, 06:00 PM
  2. Time to warm up the 1.4L when cold
    By jfischer in forum Gen1 1.4L Turbo
    Last Post: 01-16-2013, 01:43 PM
  3. Why is this site so **** slow
    By doc03 in forum Cruzetalk Site Issues
    Last Post: 04-25-2012, 12:16 PM
  4. Cruze 1.8 slow to get up to temperature
    By unsub in forum General Discussion
    Last Post: 12-30-2011, 10:19 PM
  5. ZZP SRI - warm intake temp?
    By Orange in forum Gen1 1.4L Turbo
    Last Post: 07-08-2011, 01:50 PM
