Cruze transmission fluid & filter change
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 39
Like Tree7Likes
Thread: Cruze transmission fluid & filter change
    Denver Bob is offline [OP]
    Jun 2012
    Recently, I took my 2011 Cruze LT to the dealership for a transmission fluid & filter change because it has over 30,000 miles and there is no dip stick to check the color and smell of the fluid.
    Since it is a new 6 speed automatic technology, it thought is was best to be on the safe side and change it. I left it at the dealership for service. Several hours later, I go a call from the dealership stating that they could not change the fluid or filter because the engine must be pulled to service the transmission. They said it has a 100,000 mile warranty. When I asked how much this service will cost when the car has 100,000 miles, I was told that they don't know because they have never done it!!!!!!
    If the normal transmission fluid change costs $200 - $300, how much will it cost to pull the engine? $800 - $1,000.00
    I an not sure that I want to find out the hard way. This car is a candidate for replacement at 80,000 - 90,000 miles.
    Does Chevy have an answer to this problem???
    spacedout's Avatar
    SW Wisconsin
    6,911
    Take it to a different dealer, that one is clearly full of ****. The owners manual clearly states the transmission fluid should be changed by 45,000miles. There is no way the trans has to come out to do it.
    I have not looked much into this on the cruze but my last car(a 2004 cavalier) had the same missing dipstick. On the drivers side of engine on top the trans was a black knob you could remove to fill trans. Looking in the same location on the cruze there is the exact same black knob to remove to fill.
    I will admit on the cavalier I just paid the dealer $90 to do the change, but from the reading I did It sounded like on the cavalier there was a small window on the side of trans to see if the trans was at the right fluid level(though that could be wrong). Would think there has to be some way to check the level on the cruze too. Even if there is no way to check, how hard is it to remove pan, replace filter & refill transmission fluid to spec.
    Last I checked my dealer is now charging more for the trans fluid change. Think the ad in paper said $150-175. I suspect these days all a dealer tech would have to do is look up a service procedure on the computer & have step by step instructions on how to do it. Your dealer sounds completely incompetent.... or just lazy.
    Starks8 and sciphi like this.
    5,163
    Your dealer is giving you the runaround. It's entirely possible to change the transmission fluid on these cars with the transmission in place. The 6T40 has a drain plug, and a fill plug. IIRC Amsoil lists the capacity as around 5 quarts for a drain and fill. It beats me where the drain/fill plugs are on the automatic, though.
    There's no serviceable filter, though. That gets replaced when the transmission is overhauled.
    And, if you're going to trade you 2011 in at 90k miles, that's a waste of money. With even a little bit of care, these cars should be good for 200k+ miles pretty easily.
    4th Gear mcg75's Avatar
    Canada
    718
    Quote Originally Posted by sciphi View Post
    This ^^^^^^^^
    Seems to me the dealer didn't think he would make enough off doing this simple job for you. It shows right in GMSI where the drain & fill plugs are for the auto trans.
    2013 Chevy Cruze LT RS - Black granite, 6M
    14,514
    To be specific, the service manual lists 5.8 quarts for the drain and refill.
    May 2012
    1
    Quote Originally Posted by mcg75 View Post
    This ^^^^^^^^
    Is the GMSI a mechanics online manual or a different manual then the one that came with the 2012 Cruze?
    I don't see anything in my 2012 Cruze manual about a fill and drain plug.
    Thank you,
    Skid
    Handbrake Released montess1's Avatar
    127
    i think when i go to change mine i will drain the fluid in a container that i can measure the amount of fluid that comes out and see how close it is to 5.8 quarts. you don't want to over fill an automatic transmission. this seems like a safe way to do it to get close on fluid.
    12,893
    Quote Originally Posted by montess1 View Post
    Exactly the way I've always done it.
    5,163
    There's a post in the how-to section about how to change the ATF. It's a drain/fill procedure. I'd do it every 30k miles or so to be on the safe side.
    Sep 2011
    8
    Auto trans in 2012 Cruze...I just went out and looked..The trans filler cap is like a black knob affair just to the right of the trans cable on top of the transmission..I am going to read the manual and if it says to refill with 5.8 quarts then that is what I plan to do.. On second thought I guess it won't hurt to measure what I drain out just to be sure..I had an '83 Accord that was very easy to do because the drain plug was accessible from the top ;no crawling required..I changed it often because the trans would start slipping going into 3rd gear..A quick change with a pint of some cheap " trans medic " and it would stop slipping for 6 months...I may have forgot to tell the guy I sold it to about this.....
  1. How-To: Change the Manual Transmission Fluid
    By sciphi in forum Gen1 Engine/Transmission Tutorials
    Last Post: 11-17-2016, 06:55 PM
  2. Cabin Filter Change
    By Jewel Red 5 in forum Gen1 Appearance, Body, Detailing, & Interior
    Last Post: 10-27-2014, 03:12 PM
  3. Replies: 8
    Last Post: 04-11-2012, 10:47 PM
  4. Think its time to change the Man Trans fluid - advice please....
    By Campuscop2003 in forum Gen1 Powertrain
    Last Post: 03-12-2012, 08:12 PM
  5. Oil Change on 1.8 - need PN for filter and how-to
    By inssane in forum Gen1 Powertrain
    Last Post: 08-11-2011, 02:57 PM
