14 Cruze ECO seems to automatically accelerate and decelerate
Results 1 to 10 of 14
Like Tree2Likes
Thread: 14 Cruze ECO seems to automatically accelerate and decelerate
    Sep 2017
    Antelope Valley, CA
    106
    Daughter says the it keeps doing this in an almost jerking manner.
    Sep 2017
    Antelope Valley, CA
    106
    Drove it from the house to both ends of Rosamond Blvd (little over 75 miles), to AutoZone, got new codes, and home. Didn't have any issues like my daughter had described, but the codes were for either dirty or fouled fuel injector (running lean to super lean), so I bought some injector cleaner. I may have either a fuel injector or fuel filter change in the near future.
    Chris
    2014 Cruze Eco - Limo-tint (back doors, rear window, & top of windshield), blacked out bowties
    ChevyGuy's Avatar
    US
    7,334
    I'm not sure what code you got, but running lean could also mean a vacuum leak - unmetered air getting into the system. Perhaps the dreaded PCV system acting up.
    Edit: If air somehow gets into the system and IS metered, it will likely be sensed as an uncommanded acceleration. More air & metered = more fuel. More air + more fuel = acceleration.
    More air & not metered = runs lean.
    '13 LTZ
    Prior rides:
    '67 Chevy II, 250 ci/auto
    Sep 2017
    Antelope Valley, CA
    106
    Quote Originally Posted by ChevyGuy View Post
    There were 3 or 4 different codes on the printout, and AZ's computer said it was the FI. But I'll keep an eye out for a vacuum leak.
    Chris
    ChevyGuy's Avatar
    US
    7,334
    Do you have the codes? If so, you can compare them to what others have experienced here.
    obermd and Ravenkeeper like this.
    '13 LTZ
    Prior rides:
    5,528
    Yes please post them.
    Sep 2017
    Antelope Valley, CA
    106
    I was going to post them anyways, but I didn't have them at work with me.
    The codes are as follows:
    P0171: System too lean (Zone 1)
    P0106: Manifold Absolute Pressure/BARO Sensor Range/Performance
    P015B: O2 Sensor Delayed Response - Lean to Rich Bank 1 Sensor 1
    P0507: Idle Air Control System RPM Higher Than Expected
    P1101: Intake Air Flow System Performance
    Chris
    5,528
    A code P0171 may mean that one or more of the following has happened:
    The MAF (Mass Air Flow) Sensor is dirty or faulty Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry. There could be a vacuum leak downstream of the MAF sensor
    Possible cracked vacuum or PCV line/connection
    Faulty or stuck open PCV valve
    Failed or faulty oxygen sensor (bank 1, sensor 1)
    Sticking/plugged or failed fuel injector Low fuel pressure (possible plugged/dirty fuel filter!)
    Exhaust leak between engine and first oxygen sensor
    Read more at: https://www.obd-codes.com/p0171
    A P0106 could be caused by:
    Bad MAP sensor Water/dirt intrusion affecting MAP sensor connector
    Intermittent open in the reference, ground, or signal wire for the MAP sensor
    Intermittent short in the reference, ground, or signal wire for the MAP sensor
    Ground problem due to corrosion causing intermittent signal problem
    A break in the flexible air intake duct between the MAF and the intake manifold
    Bad PCM (do not assume the PCM is bad until you've exhausted all other possibilities)
    Read more at: https://www.obd-codes.com/p0106
    Potential causes for code P015B to set are:
    Defective O2 sensor(s)
    Burnt, broken, or disconnected wiring and/or connectors
    Defective catalytic converter
    Engine exhaust leaks
    Read more at: https://www.obd-codes.com/p015b
    A P0507 DTC trouble code may be caused by one or more of the following:
    A vacuum leak Leaking air intake after the throttle body
    EGR valve leaking vacuum
    A faulty positive crankcase ventilation (PCV) valve
    Damaged/failed/dirty throttle body
    Failed EVAP system
    Failed IAC (idle air controller) or faulty IAC circuit
    Read more at: https://www.obd-codes.com/p0507
    For P1101 read more here: https://www.700r4transmissionhq.com/...e-codes/#P1101
    And read this as well as watch the video:
    2011-2016 Cruze 1.4 PCV Valve Cover/Intake Manifold Issues
    Sep 2017
    Antelope Valley, CA
    106
    Failed EVAP system
    That I know of, air filter is whatever the dealership put in, guess I'll have to look at it, soon.
    I had to disconnect the MAPS and the upper O2 Sensor, to move the air inlet out of the way, to replace the Water Outlet Housing (leaking). Had P0171 shortly after changing WOH, so I've check the connections on those, may have to spray some contact cleaner.
    Chris
    Sep 2017
    Antelope Valley, CA
    106
    Ran one bottle of Chevron Injector Cleaner through with just over 1/2 tank of gas. Electrically disconnected, cleaned, & reconnected MAPS and the upper O2 Sensor. A friend came over, reset CEL/Codes. Daughter drove to school, and said that she got about 10 miles away, when the CEL came ON again.
    NEW codes are as follows:
    Ordered a new valve cover, should be here on Wednesday/Thursday, and will be replacing it on Saturday.
    Chris
  1. Replies: 7
    Last Post: 04-15-2019, 12:03 PM
  2. 2014 cruze squealing noise when idle goes away when I accelerate
    By Miniman14 in forum CruzeTalk New Member Introductions
    Last Post: 05-14-2018, 01:15 PM
  3. Accelerate sound 2017 cruze
    By Joseyac18 in forum General Discussion
    Last Post: 12-05-2017, 01:29 PM
  4. My Cruze doesn't accelerate. HELP
    By chevycruzedriver in forum General Discussion
    Last Post: 01-27-2015, 05:09 AM
  5. Accelerate then coast MPG gain?
    By McNeo in forum General Discussion
    Last Post: 07-27-2014, 07:01 PM
