Rain rain rain and injen cai - Page 2
Results 11 to 20 of 22
Thread: Rain rain rain and injen cai
    cruzeman is offline [OP]
    somewhere
    1,693
    some areas here in the northeast got approx 10 inches this week!!!!
    2nd Gear Crewz's Avatar
    Jul 2011
    Houston, Texas
    538
    Quote Originally Posted by Dayhoff35 View Post
    you have a stock bpv, no need for an aftermarket one unless you really want/need a new one. It also just lets the extra air back into the intake after you cut the throttle, it doesnt give it a constant supply of air.
    That's good to hear. What about the aftermarket intake guys? I assume all that goes out the window with the CAI, in which you would need a BPV.
    Cruze LTZ RS Silver Ice Metallic, Black Leather interior, connectivity package, sunroof, pioneer premium sound system, 18" split star wheels
    Sep 2011
    Maryland
    217
    i dont understand what youre asking, are you asking f you need the bpv with and intake? If so, then yes you still do. The only way you wouldnt need one is if you got a blow off valve.
    Jul 2011
    Houston, Texas
    538
    i dont understand what youre asking.
    Quote Originally Posted by Crewz View Post
    Get a bypass valve.
    I stated the OP should get a BPV, cause the title of the thread says "Rain..CAI". You mentioned it has a BPV stock. So are you talking about the Injen intake coming with a BPV as part of the kit, which is what you meant by stock? Or are you saying the stock OEM intake has a BPV? If that's the case, once you take out the stock intake you no longer have the BPV, correct? In which he would still need to get a BPV.
    I'm confused now.
    Sep 2011
    Maryland
    217
    the bpv is on the turbo, not the intake
    benton,ar
    206
    bpv= bypass valve....as in..something to open if water gets in the intake..to bypass the orginal spot of air intake..so fresh air..not water can get to the motor...and sence there would no longer be anything pulling the water into the cai..because the bpv opened...the water would then drain out...a bov=blow off vavle..is on the turbo..to let excess pressure out...so..bpv..isnt bov.....and the stock intake also has a drain...in the bottom of the airbox..with a little tube connected to it..so water can drain from the stock air box.....sorry if i rambled..
    36
    Hey Cruzers, for all worried about rain; install a Bypass Filter.
    Attached is a picture of her car with a Injen CAI w/ a bypass filter.
    Click here for: Hidden Content
    Handbrake Released JdmHonda'lude's Avatar
    Jul 2011
    Oshawa
    104
    Where did ya get that bypass from?
    3rd Gear
    Apr 2011
    665
    Installing a BPF will just reduce the amount of air coming from the CAI and increase the amount of air coming from the BPF. Unless of course you get a BPF in which the resistance of flow is greater than the CAI filter + the additional resistance of the extra 1.25 feet of tube including the bend + reduced viscosity of air in the compartment due to the increased temperature.
    In short, if you are installing a BPF, the SRI is probably a better option since the turbo will draw more air from the bpf and thus the engine compartment anyway.
    Dec 2012
    69
    Quote Originally Posted by crk585 View Post
    I tried doing the same exact setup and it drove me crazy trying to align the tubes and connect the filter so I just F-It and tossed the bypass. Oh by the way, what size did you order? I ordered a 2.75 bypass because the injen tubes are 2.75 but I couldn't get the tubes far enough through the bypass. Did you cut you tubes shorter?
  1. rain rain rain....
    By A&J Cruzin in forum General Discussion
    Last Post: 12-07-2011, 08:27 PM
  2. Wts: Injen CAI/SRI
    By shawn672 in forum Cruze Parts
    Last Post: 10-10-2011, 11:30 PM
  3. Injen CAI
    By mzodarg in forum General Discussion
    Last Post: 09-28-2011, 05:01 PM
  4. 1.4L Injen SRI vs CAI
    By pbeyer2010 in forum Gen1 Powertrain
    Last Post: 09-13-2011, 08:00 PM
  5. Help with rain gaurds
    By dreamsrpainful in forum Gen1 Appearance, Body, Detailing, & Interior
    Last Post: 07-11-2011, 08:42 AM
