How do you move a power drivers seat to remove from Salvage Car? - Page 2
Results 11 to 15 of 15
Thread: How do you move a power drivers seat to remove from Salvage Car?
    5,531
    Quote Originally Posted by resurgent cineribus View Post
    BTW I was just looking through my ford factory wiring diagram book for my escape and it is incredible; shows every single pin and connector imaginable. I just wish I could find a wiring manual this comprehensive for the Cruze....
    I have also been looking for some time.
    5,531
    Quote Originally Posted by carbon02 View Post
    I'm not an electrician, so don't try this on your car, and I'm not responsible for any damage. With that said, assuming we're working at a U-Pull yard where nearly anything goes this is what I'd try.
    On the top of the battery there is an electrical assembly snapped to the top. snap open the plastic on the top of this assembly. The main red battery positive enters the assembly and there are four circuit breakers on the top. These are the breakers shown in the drawing attached above. With a jump pack I would put 12V positive on each of the 100 Amp fuses. For safety I would fuse your jumper leads as to not cause a fire. You don't know how many wires are cut by previous people, and there could be shorts to ground somewhere.
    The negative from the jump pack would go to chassis ground. I think you could ground it out to ground stud near the driver side strut tower.
    In theory this would provide power to the interior fuse box. The interior fuse box is powered normally with engine off key removed. This powering circuits 5040 and 5140 mentioned above.
    Most of the underhood wiring is either gone or damaged. The fuse block is missing just about everything.
    This is my redition of my fuse block. Now that I am looking at it, I do not see the 100A fuses, so I will need to find another view. i may be able to jump them there, way easier than reaching under the seat in the glass.
    5,531
    Quote Originally Posted by Mochenmat14 View Post
    Negative, I was asking about the a pillar trim piece because I've been looking for some to put some tweeters in and rather not use my stock ones in case I mess up hah
    Where are you located. I could probably get a set for next to nothing. At the moment, I am planning on returning to the yard in the morning barring any unforseen circumstances. If your willing to pay whatever it costs me and shipping, let me know today sometime.
    5,531
    Several years ago I put some pictures up at the following website. Due to restrictions on my computer I can't e-mail pictures or even use USB jump drives.
    I believe I sent these pictures to Blasirl a year or so ago. The way I have it set up is that you should be able to see view and download photo's in this directory without having to create a shutterfly account.
    Shutterfly accounts are free, and I'm sure everyone has a junk e-mail account that they can use for this kind of stuff.
    I want to help, but I don't have the time to reformat pictures for posting directly on this site, and unfortunately use of google to send files as attachment's isn't an option either.
    https://2012cruze.shutterfly.com/pictures/8
    Give it a try and see if you can see these files
    You can see the files, but need an account to download. I will try and look for the ones I resized. If it is ok with you, I will edit your post and insert them - when I get more time.
    Here is what I think you are referring too though, I prt sc'd it.
    carbon02 is online now [OP]
    BOOOOST!
    1,276
    Yes--
    I believe one of those fuses, goes down and powers the fusebox inside the car.
    The one you have pictured, I don't know if I'd try powering from there.
    You might try applying 12V inside the instrument panel fuse box, but I think that would be a little more difficult.
    Not sure that you noticed, but the wires are labeled 1,2,3 and the terminals are labeled 1,2,3,4 with 1 being the connection closest to the battery post.
    If someone has ripped things apart t he top of the box might be disconnected, but I think you would be able to find those three red power wires.
    2012 Cruze LT, 1.4L, AT 78,000 Miles as of 1/19
    Looking for EV for next car.. Bolt or maybe Model 3 if Chevy doesn't speed up their EV's to the marketplace!
    Previous Rides
    2002 Intrigue 3.5L,LX5, AT 135,000- Owned for 10 years.. PM for Intrigue help. P1811 also a problem with this car.
    2000 Intrigue 3.5L, LX5, AT, 89,000- Owned for 12 years.. Dreaded P1811 killed this transmission.
  8. Remove Advertisements
  1. Driver seat won't move forward or back
    By HSchut in forum Gen1 Appearance, Body, Detailing, & Interior
    Last Post: 03-02-2019, 01:41 PM
  2. need to remove drivers seat but it’s stuck!
    By Foosgreg in forum Gen1 Appearance, Body, Detailing, & Interior
    Last Post: 07-09-2018, 07:31 AM
  3. How do i remove headrest posts on the front seat on my 2013 cruze
    By Ru03 in forum Gen1 Appearance, Body, Detailing, & Interior
    Last Post: 05-16-2017, 12:33 AM
  4. Aftermarket Heated Seats, How does seat Belt remove from seat bottom?
    By carbon02 in forum Gen1 Appearance, Body, Detailing, & Interior
    Last Post: 12-05-2014, 12:07 PM
  5. How to remove drivers seat - seat cover
    By travthomas in forum Gen1 Appearance, Body, Detailing, & Interior
    Last Post: 05-25-2014, 09:33 AM
