Bigger brakes for the Cruze under $400. - Page 14
Page 14 of 15 FirstFirst ... 4 12 13 14 15 LastLast
Results 131 to 140 of 148
Like Tree58Likes
Thread: Bigger brakes for the Cruze under $400.
  1. #131
    Jan 2016
    Vancouver, BC
    74
    I just did the swap as the OP mentions. I went with new calipers instead of just the brackets, but other than a little bit of work, they feel way better than the old ones, but new pads will do that anyways. I have a small family trip coming up. I’ll know then if they feel better. Otherwise good post OP.
    EDIT: I have the steel 16” wheels. No problems with clearance. Little snug, but nothing to worry about at all. Lots of room!
    lonewolf04 likes this.
  3. #132
    5,517
    Quote Originally Posted by bsb2001ca View Post
    I just did the swap as the OP mentions. I went with new calipers instead of just the brackets, but other than a little bit of work, they feel grannies than the old ones, but new pads will do that anyways. I have a small family trip coming up. I’ll know then if they feel better. Otherwise good post OP.
    grannies?
  4. #133
    Jan 2016
    Vancouver, BC
    74
    Omg, auto correct. Feels great! Not grannies
    Blasirl likes this.
  6. #134
    Dec 2013
    Westminster, MD
    77
    On an LS or 1LT with rear drums, would this upgrade throw off the brake balance significantly? Getting close to needing front brakes on my 1LT again and would like some added stopping power as the stock setup is not confidence inspiring by any means.
    2012 Cruze 1LT RS Auto Topaz Blue
    ZZP intake, Forge BPV, BNR actuator, BNR tune, Ultra Racing strut bar, Konig Maxxim Winner 17x7, Bilstiens, 35%/25% tint, blacked out trim, sharkfin antenna
    1987 Buick Regal Turbo T
    Fully restored, 274ci stroker, 71mm turbo, 10sec sleeper
  7. #135
    Jan 2016
    Vancouver, BC
    74
    Quote Originally Posted by TopazRS87 View Post
    I did this with drum brakes on the rear. As long as your drum adjusters are properly lubed and brakes adjusted in the back, I think it compliments the brake setup.
  8. #136
    Aug 2017
    398
    just an FIY, ZZP has the bigger rotor and dual piston caliper setup for $450 shipped right now. Just a couple bucks more and you can have stronger/lighter calipers
  9. #137
    771
    Quote Originally Posted by eddiefromcali View Post
    "Stronger"?..... In what way? Are you claiming the caliper itself is stronger/stiffer? There's loads of 5th gen Corvette and Camaro guys that would vehemently disagree. Pad taper wear and caliper spreading is a pretty common occurrence.
    Are you driving a Cruze hard enough to do this? 99% of us aren't, but that doesn't change the fact that the Encore/Trax caliper is stiffer. You also have the added benefit of being able to buy over the counter brake parts anywhere you need them and not have worry about modifying things.
  10. #138
    Aug 2017
    398
    Quote Originally Posted by Ma v e n View Post
    relax, chief...im talking dual piston vs single and it being aluminum making it lighter. Havent compared pad surface area of an F-body caliper vs a cruze, but Id assume theyre bigger? Not gonna claim that for certain though.
  11. #139
    Learning about my Cruze Champagne Jam's Avatar
    Feb 2016
    I lived in Reno/Sparks Nevada since 1962.
    75
    The ZZP kit is not complete. No shields for instance. What size bolts? Were did they source the calipers? Hmm...
  12. #140
    Jan 2016
    Vancouver, BC
    74
    I think somewhere in the previous posts it had stated that someone needed rotors only or pads only and ZZP wouldn’t give out part numbers to buy over the counter pads and rotors and they wouldn’t separate them. And this option also allows anybody to just order something if the calipers fail while on a road trip, just stop and say they’re for the Buick
  1. Diesel brakes vs regular gas brakes Cruze
    By Invierno in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 06-23-2013, 05:49 PM
