Bigger brakes for the Cruze under $400. - Page 15
Page 15 of 15 FirstFirst ... 5 13 14 15
Results 141 to 149 of 149
Like Tree64Likes
Thread: Bigger brakes for the Cruze under $400.
  1. #141
    Aug 2017
    413
    Quote Originally Posted by bsb2001ca View Post
    I think somewhere in the previous posts it had stated that someone needed rotors only or pads only and ZZP wouldn’t give out part numbers to buy over the counter pads and rotors and they wouldn’t separate them. And this option also allows anybody to just order something if the calipers fail while on a road trip, just stop and say they’re for the Buick
    rotors would be the only issue, but calipers are stock f-body calipers, no secret there...you can just stop and say theyre for the camaro
  3. #142
    Learning about my Cruze Champagne Jam's Avatar
    Feb 2016
    I lived in Reno/Sparks Nevada since 1962.
    76
    F-body calipers? What about the brackets? Do they bolt up to the Cruze?
  4. #143
    Aug 2017
    413
    Quote Originally Posted by Champagne Jam View Post
    they must if that's what they advertise
  6. #144
    Feb 2016
    76
    They say they have brackets. They do not say if they are stock.
  7. #145
    Aug 2017
    413
    not sure what you want to find out or prove here. I'm just stating the fact that for a lil more money, you don't have to permanently modify your spindles and you get dual piston/light calipers. Dust shields are not included, but aren't necessary in this kit nor the one OP posted.
    This is off ZZPs kit
    looks like the same brackets on an autozone caliper for an LS1 Camaro to me
    Link to said caliper
    https://www.autozone.com/brakes-and-...41_341018_5913
  8. #146
    Feb 2016
    76
    Thanks for the research on this. I'm concerned about the mounting bolt distance and bolt size. This caliper fits the fourth gen camero, but not the third. What I am trying to do is make sure nobody buys the wrong caliper. And which version of the f body caliper we need.
    Thanks again for this info.
  9. #147
    829
    They specify a 12" rotor. We'll call that 305mm. The friction height on a Camaro pad is about 52mm or so.
    The area of a ring with an outer diameter of 305mm and an inner diameter of 253mm is 41,331mm².
    The Trax rotor is 300mm, and the friction height is about 58mm. The area of a ring with an outer diameter of 300mm and an inner diameter of 242mm is 44095mm²
    The Trax rotors have a larger swept area.
    Trax caliper has a 60mm piston, or 2827mm² surface area.
    Camaro caliper has dual 45mm pistons, or 3180mm²
    The larger piston area means for any given pressure applied at the pedal, a higher pressure will result at the caliper. This comes at the expense of pedal travel(it will travel farther and feel lighter) and altered front rear brake ratio/bias
  10. #148
    Feb 2016
    76
    I am the OP. I used shields for the same reason the factory did. Never the less, what is the center to center distance of the caliper bracket mounting holes?
  11. #149
    Jun 2019
    Bradenton, FL
    Does anyone have the caliper bracket dimensions? Looking like 5.040 on the Gen 4 Camaro stuff. Measurements taken from An S-10 forum. I can’t post the link due to low post count but if you google
    ls1, firebird / camaro front disc swap bracket plans, drawing updated 3-23!!!
    It should turn up the image for someone’s drawing.
  1. Diesel brakes vs regular gas brakes Cruze
    By Invierno in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 06-23-2013, 05:49 PM
