'13 Eco - Transmission Bearing Failure
Results 1 to 10 of 13
Thread: '13 Eco - Transmission Bearing Failure
    LS1LOL is offline [OP]
    136
    Hi guys, haven't posted here in a while. Having some issues with the cruze. '13 Eco M6,128.5k miles. Transmission bearings are whining pretty good. Would like some advice as to what options are out there for replacing the transmission. Seems like buying a used one is possibly a time bomb as these failures are basically factory defects. From what I understand, this issue was fixed in 14, but finding a used 14 transmission for an eco is likely not an easy task. Any tips for what to do for finding a replacement?
    Also, the replacement itself. I'm fairly handy myself and likely will tackle this transmission replacement myself with a couple of buddies hopefully on a weekend. Any tips for getting it in and out? I breezed thru a walk thru and it looked like a nightmare...dropping the subframe and stuff. Someone else was saying pulling the motor and transmission is likely the easiest option. Is that also true? What other parts should I consider replacing? Clutch has never slipped on me once. In that walk thru he mentions replacing the slave and throw out bearing...i may consider that depending on cost but those also have never been an issue. Any wisdom here is also appreciated.
    Thanks!
    -Tyler
    136
    Thanks!
    -Tyler
    136
    '13 Eco - Wheel Speed Sensor Issue
    Hi guys, 13 cruze eco M6. ABS/Stabili-trak lights come on. Scan it with my buddies scanner. Open circuit passenger side rear wheel. Test the sensor, no resistance/continuity. Check the drivers side, has resistance. So I replace the speed sensor. Light comes back on. Now it's saying that the circuit is 'not plausible' C0050-5A. We played around with the crimp terminals and stuff, still no luck. My buddy recommended I replace the wheel bearing (keep in mind this has the drum rear brakes on it). Is this a semi common issue? Is that going to solve the issue? Not sure what else it could be? Thanks for any help! -Tyler
    5th Gear
    BowtieGuy's Avatar
    Jan 2013
    Columbus, OH
    949
    Have you checked the wiring between the sensor and computer? Maybe broken wire somewhere? Check for resistance/continuity and compare with other wheel sensor wiring?
    Hidden Content 2013 Cruze Eco Manual
    Hidden Content 2004 Grand Prix GT2
    136
    Mods, I was really hoping to keep the speed sensor issue separate from the transmission issue...any chance to keep the two posts segregated?
    2013 M6 Cruze Eco
    15,550
    Did you change the fluid, and fill up to 2.5 quarts?
    I'd just find a used 2014+ transmission and swap that in.
    Link::Hidden Content
    136
    Transmission maintenance was rather meticulous IMO. At probably 15K miles I swapped the fluid for Amsoil syncromesh @ 2.5 quarts, and again at 35K(ish). Ithen put in the Amsoil GL fluid at 65K(ish_, and again at 100K (ish). Now I am having the bearing whine. Seems like it is probably the common 5/6 bearing failure. The noise seems to be coming from the top of the transmission.
    I will see if I can find a decent used 14+ Eco transmission at a junkyard or something, but everything I have found online so far is rather pricey for what it actually is. Just wondering if I should put a new clutch in, slave, throwout bearing, etc while I am at it.
    EDIT: I actually did one additional fluid swap so I added that interval to the list.
    2013 M6 Cruze Eco
    1st Gear mechguy78's Avatar
    Jun 2016
    New Waterford Ohio
    283
    Quote Originally Posted by LS1LOL View Post
    if I t were me I would be replacing the clutch kit and slave cylinder/ throwout bearing while I was in there, but I guess that would also depend on how much you are driving the car.
    A high milage driver like myself would end up going back in to do the clutch in a few months whereas a low milage driver may make it a year or more before having to do so. All depends on how the car is being driven.
    '14 Cruze 1LT 6MT - KNN CAI - MAGNAFLOW CBE - Verano belly pans - NGK BKR8IEX plugs @.030 - Amsoil fluids throughout
    5th Gear
    BowtieGuy's Avatar
    Jan 2013
    Columbus, OH
    949
    Given the mileage of the vehicle, I would replace those parts. It would be a real PITA to have to pull it all apart again later if you had to replace a part later down the road.
    136
    Do you guys have any places I could look at for buying a good condition transmission (even new or remanufactured)? Trying to weigh out the cost difference for just a junkyard transmission vs all new components...
  1. noisy front wheel bearing... 78k miles '14 cruze eco
    By fj5gtx in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 10-04-2018, 10:23 PM
  2. Wheel Hub Bearing and Transmission Leak and I'm on my 2nd Cruze
    By 1902Brooks in forum Gen1 Service Issues
    Last Post: 10-30-2015, 10:11 PM
  3. Replies: 50
    Last Post: 08-25-2015, 04:01 PM
  4. Transmission FAILURE and many other problems...
    By Bruin2007 in forum Gen1 Powertrain
    Last Post: 03-02-2015, 03:00 AM
  5. Replies: 17
    Last Post: 03-22-2013, 05:28 PM
