Slow tire leak??
Results 1 to 3 of 3
Thread: Slow tire leak??
    benefactr is offline [OP]
    Wentzville, MO
    26
    Slow tire leak??
    Hello,
    I can't say for sure but seems like after my last oil change/tire rotation at the local dealer one of my tire has developed a slow leak. Last couple of weeks I have to fill it up to 35PSI on monday, and by the next monday it's back down to 29PSI. Anything I can check or do to alleviate this. I got 35K on the stock tires and will probably be changing them out in the next few months so don't really want to buy one new one right now. Seems like I heard fix-a-flat isn't good ideal to use. Thanks for any advice.
    Quick reply to this message Reply
    spacedout's Avatar
    SW Wisconsin
    6,920
    Fix a flat will damage the tire sensor so it would cost you even more to repair. Only thing you can do is go to the dealer or tire shop and have them check for a nail or some other road debris you picked up. if your lucky it can be plugged(if its in the tread and not sidewall), should not cost more than $20.
    3rd Gear Diesel Dan's Avatar
    May 2013
    Columbia, TN
    581
    I had one going low for some time. When rotating the tires found a small piece of wire in it. Plugged hole and good to go. You can buy a plug kit with the tools and plugs for around $10.
    2014 Cruze Diesel
    Tungsten Metallic
    2006 GMC CC/LB Duramax/Allison
    6.5L Turbo Diesel/auto/4x4/SRW/LB
  1. Possible Tire leak????????
    By chevycruze2012 in forum General Discussion
    Last Post: 07-28-2013, 02:16 AM
  2. its slow and its low
    By jakkaroo in forum General Discussion
    Last Post: 05-10-2013, 12:43 PM
  3. Some say the Cruze is slow????? i say BS
    By chaser x in forum General Discussion
    Last Post: 03-07-2013, 02:36 PM
  4. Tire Rack 16" snow rim/tire combo
    By scha7530 in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 10-28-2012, 10:16 AM
  5. Why is this site so **** slow
    By doc03 in forum Cruzetalk Site Issues
    Last Post: 04-25-2012, 12:16 PM
