How-To: GM 1.4L LUV/LUJ PCV Fix Kit V1 Install - Page 2
Results 11 to 14 of 14
Thread: How-To: GM 1.4L LUV/LUJ PCV Fix Kit V1 Install
    May 2018
    Florida
    93
    Good work, you really don't need the hose clamps there. The most pressure that hose will ever be under is 1/2 a PSI unless something else is broken, so I chose not to include hose clamps in the V1 kit. It doesn't hurt to have them, just not necessary.
    Looks good though! Thanks for the feedback!
    I had those hose clamps sitting around collecting dust from a previous project. I figure I put them to good use. Your correct I really did not need to use them. Again thanks.
    May 2019
    I registered just so I could say Thank You!
    Took me 2 half days, I let the epoxy set up over night. No more engine light! Runs great! 6 valve covers and three intake manifolds, I’m not paying Chevrolet for any more!
    May 2019
    After a 120 mile round trip today the oil pressure light came on telling me to shut the engine down. Three quarts blew out all over the right side of the engine compartment. Either my valve cover gasket blew on its own or the check valve isn’t releasing the pressure and blew the gasket out. Guess I’ll be back under the hood this weekend. I’m thinking faulty or clogged check valve. I hope I’m wrong.😞
    May 2019
    I don’t know what happened to my second post, it doesn’t seem to be on the page. I was hoping you guys would have some advice. I installed v1 kit with bnr spacer. Ran great for one day, no engine light. Third day I put 120 miles on it and it blew out three quarts of oil (I think from valve cover but not sure.) I know I didn’t install valve backwards. Do you think I got a faulty check valve? Or maybe my valve cover gasket just failed. I’m going to pull the check valve and test it this weekend. I guess I’ll order a new valve cover gasket tonight and replace that too. If i can’t fix it I’ll have to go back factory, I don’t want to do that! Any advice appreciated.
  7. Remove Advertisements
  1. GM 1.4L Turbo Intake Manifold PCV Valve Fix Kits
    By XtremeRevolution in forum Gen1 1.4L Turbo
    Last Post: 04-17-2019, 06:07 PM
  2. Replies: 2
    Last Post: 05-20-2018, 07:06 PM
  3. ZZP vs Vtuner vs BNR Turbo Options for the LUV/LUJ 1
    Last Post: 05-10-2018, 02:07 PM
  4. LUJ/LUV engine swap compatibility
    By st6787 in forum Gen1 1.4L Turbo
    Last Post: 03-23-2018, 02:15 AM
  5. Cam specs for LUJ LUV
    By a2chris in forum Gen1 Powertrain
    Last Post: 12-07-2017, 12:48 PM
