Eco Cruze Fog Light Install--Warning: Lots of pics!! - Page 22
Page 22 of 23 FirstFirst ... 12 20 21 22 23 LastLast
Results 211 to 220 of 221
Like Tree61Likes
Thread: Eco Cruze Fog Light Install--Warning: Lots of pics!!
  1. #211
    May 2017
    You can have fog lights installed by a dealer for $100?
    Quote Originally Posted by Cruzer59 View Post
    silvercruze - you are a brave man, a skilled DIY technician, and a thoughtful documentarian! I purchased the GM fog light kit separately ~$205.00 via e-bay but knew I wouldn't have the time, skill, etc. to do what you did. BRAVO to you!
    I checked out approx. 10 chevy dealers for pricing on installing the fog kit and got different prices at every dealer - no surprise there - prices ranging from $91.00 all the way to $180+
    I decided to stick w/my neighborhood dealer where I purchased my Cruze from and had it done for $104.00 (no tax since I provided the parts) and got it done in just under 3 hours.
    Thanks for the great post, I'm sure many will appreciate and benefit from it.
  3. #212
    Apr 2011
    Central Florida
    18
    Looks like the pictures came back. I still have the car, it only has 51K miles. Other than the hesitation issue (that is now solved), it's been a really good car.
    2011 Cruze Eco 6-M
  4. #213
    Learning about my Cruze MKsmn515's Avatar
    Apr 2014
    Ann Arbor Michigan
    85
    I've done this to an 14 Eco manual but I just bought a 14 diesel. Does the wire go in the same spot in the fuse box? #48 15A
    Current:
    2014 Cruze Diesel Black
    - Weather Tech Mats
    - Thule Roof Rack
    - 20% window tint
    - OEM fog light
    Past:
    2011 Cruze Eco 6MT Black
    2014 Cruze Eco 6MT RFG
  6. #214
    Apr 2014
    Ann Arbor Michigan
    85
    Anyone have issues with pulling the harness out when you get ready to put the fuse in the back. I'm trying to pull it out and I've popped all the clips but the three pieces in the back wont come out. The 9mm bolts are loose and all the clips are popped back. I can get it up about an inch .
    Current:
    - Weather Tech Mats
    - Thule Roof Rack
    - 20% window tint
    - OEM fog light
    Past:
  7. #215
    Feb 2019
    9
    Quote Originally Posted by MKsmn515 View Post
    Are the fog lights functioning on your CTD? I was able to install aftermarket fogs since the 2015 Cruze Diesel doesn't support them, however, I'm not receiving 12v on the line side, not sure if the wire is getting continuity with the fuse holder or the placement of my wire might be in the wrong spot.
  8. #216
    5,771
    Quote Originally Posted by Kamal View Post
    Welcome Aboard!
    What fuse did you connect to? Do you have a meter? What kind of connector did you use. What switch are you using? ...
    Don't forget to introduce yourself and your Cruze here.
  9. #217
    Feb 2019
    9
    Welcome Aboard!<img src="https://www.cruzetalk.com/forum/images/smilies/welcome.gif" border="0" alt="" title="Welcome" class="inlineimg" />
    Great to be here, I connected it to fuse no. # 48. I also purchased a gm headlight switch that included the fog light feature, upon pressing said button the foglight symbol pops up on the dash. At first I stuck a wire under the #48 female block without the appropriate gm pin connector, as long as it makes contact with the fuse block it will have continuity. Unfortunately, I would never receive any voltage at the other side of the wire. After several attempts of inserting and reinserting the fuse block, assuming that it wasn't making enough contact with the fuse block side; I finally figured I should check the actual fuse itself to see if it was giving out voltage, unfortunately it was not. I'm here contemplating if I should wait for a fellow 2015 CTD follower who was successful in installing fog lights with the stock gm headlight swith, or just install an aftermarket switch, preferably drilled into the secondary fuse block cover door.
  10. #218
    5,771
    Use a fuse tap
  11. #219
    Feb 2019
    9
    My fuse box looks a bit different, I attached a few more pictures for context. I'm debating whether or not I should wait for somebody who was successful in installing the fogs with the stock gm switch thru the BCM to show up and help, or just settle with a $25 loss on buying the switch and install an aftermarket one via relay + straight battery connection.
    IMG_20190602_174557.jpgIMG_20190602_174606.jpgIMG_20190602_174717.jpgIMG_20190602_174719.jpgIMG_20190602_174803.jpgIMG_20190602_174810.jpg
  12. #220
    Apr 2014
    Ann Arbor Michigan
    85
    Used a fuse jumper and went to the top of the fuse box in #48 15Amp
    Current:
    - Weather Tech Mats
    - Thule Roof Rack
    - 20% window tint
    - OEM fog light
    Past:
  1. VG Shark Fin Antenna Install (With Pics!)
    By STUDLEE in forum Gen1 Appearance, Body, Detailing, & Interior
    Last Post: 08-30-2016, 07:45 AM
  2. I can see (OEM fog light install)
    By bpipe95 in forum Lighting
    Last Post: 09-16-2014, 08:03 AM
  3. HOW TO...Debadge** Lots of pics!!!
    By CHEVYCRUZE RS in forum Gen1 Appearance/Body Tutorials
    Last Post: 08-29-2014, 12:28 AM
  4. Fog light install
    By NBrehm in forum Gen1 Appearance, Body, Detailing, & Interior
    Last Post: 01-09-2013, 11:26 PM
  5. Trinity Motorsports trip to New Castle Raceway (lots of pics and videos)
    By Aeroscout977 in forum Off Topic Discussion
    Last Post: 11-01-2011, 08:05 AM
