Battery drain
Results 1 to 10 of 10
Thread: Battery drain
    redheadx6 is offline [OP]
    Apr 2019
    Battery drain
    Feeling so frustrated..ive been threw 2 batterys in 1 yr and i keep having a battery drian problem
    Sent from my LG-LS998 using Tapatalk
    5,531
    Quote Originally Posted by redheadx6 View Post
    Welcome Aboard!
    I will move this post to the Gen1 Audio & Electronics from the Cruzetalk Site Issues subforum as it looks like you are not having issues posting. It would help if you give some particulars about the vehicle though.
    Special Coverage #14311: Negative Battery Cable
    Chevy cruze 2014 Electrical issues
    <span style="font-family: Tahoma"><strong>
    MP81's Avatar
    Washington Township, MI
    3,600
    Do you have any kind of amplifier (non-factory) or alarm?
    Apr 2019
    No dont have any amps or extras..and ive checkd the cables to my battery also..next im going to see if the onstar fuse is the problem
    Drag Racing Champion
    Nov 2017
    1,680
    First thing to do would be to measure the drain. By disconnecting the + cable. Pos lead goes on bat terminal. Neg lead goes on cable. Use a meter that can measure up to 20A DC. Or if you have access to a meter with a clamp. You can measure the drain with the battery still connected by putting the clamp over the + cable.
    It's not uncommon to have a bad battery. They sit on shelves for who knows how long before being put in to service.
    5,531
    There is a video in the second link I posted above that will explain how to look for drains
    Nov 2017
    1,680
    There's a vid that shows SOMEWHAT how to test volt drop on the battery terminal. It doesn't explain the whole testing procedure. And doesn't explain how to test drainage.
    It should also be noted that if the battery is dirty. Dirt makes a conductor also and will drain the battery. Put one terminal on the battery post and run the other terminal across the battery.
    Get enough dirt and YES you will get full battery voltage reading.
    ChevyGuy's Avatar
    US
    7,334
    Some folks have reported problems getting their car to sleep properly. Locking the car helps. Also, make sure to end any Bluetooth conversations on your phone before shutting down. The radio may not go to sleep properly otherwise.
    '13 LTZ
    Prior rides:
    '67 Chevy II, 250 ci/auto
    5,531
    Quote Originally Posted by snowwy66 View Post
    Well, cough up a better one then...
    Nov 2017
    1,680
    I don't have any links. Sorry.
    But I already explained it.
  1. RVC - battery volts, dead battery and early factory battery replace problems
    By theonlypheonix in forum Gen1 Diesel Technical Discussion
    Last Post: 04-24-2016, 07:11 PM
  2. Coolant Drain/Location of Radiator Drain Plug
    By strolsc in forum Gen1 Powertrain
    Last Post: 03-18-2016, 02:24 PM
  3. Electrical? Slow drain battery, accessories startup lag.
    By palanski in forum Gen1 Service Issues
    Last Post: 09-04-2014, 12:41 PM
  4. help radio and some interior lights not working after battery drain
    By nosidefcp in forum Gen1 Audio & Electronics
    Last Post: 01-22-2014, 01:05 PM
  5. oil drain plug and manual t drain plug.
    By 1877 iris ave in forum Gen1 Powertrain
    Last Post: 10-01-2011, 08:40 AM
