Very slow coolant leak on 2014 Diesel - Page 4
Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 39 of 39
Like Tree26Likes
Thread: Very slow coolant leak on 2014 Diesel
  1. #31
    May 2017
    18
    I had the same issue. It was the coolant pump. Sometimes when shutting the car off after a more "aggressive" drive , the pump will slightly leak due to the temp+pressure in cooling system. Then next drive there will be no leak because the pump is running and the coolant is flowing. I had my water pump and timing belt replaced under warranty at 95k, no more slow loss of coolant Currently at 101k.
    Hopefully this helps
    Rivergoer likes this.
  3. #32
    Handbrake Released HarleyGTP's Avatar
    Dec 2013
    Campbell Hall, NY
    166
    I'm going to bump this thread up. I've replaced my water pump, thermostat and reservoir cap and can't find this **** leak! I can smell the coolant when I get out of the car after a drive or if I'm sitting in traffic. Has anyone had any luck locating these leaks?
    MRO1791 likes this.
    2014 Chevy Cruze Diesel, full delete.
    1995 Dodge Ram 2500 Diesel "Nancy"
    2004 Harley-Davidson Road King Custom
  4. #33
    2nd Gear sailurman's Avatar
    Sep 2016
    432
    Transmission coolant lines?
    2015 Chevy Cruze CTD 120K (DEF Tank Replaced)
    2013 Chevy Sonic 1.4T Hatch
    2005 GMC Yukon XL SLT 2500 8.1L(496 Big Block)
  6. #34
    Sep 2016
    432
  7. #35
    Dec 2013
    Campbell Hall, NY
    166
    Replaced those coolant lines going to the oil cooler a few weeks ago and also the oil cooler itself.
    STILL getting the smell of coolant!!!! This is so frustrating.
  8. #36
    Sep 2016
    432
    Pressure tested the system yet?
  9. #37
    Dec 2013
    Campbell Hall, NY
    166
    Quote Originally Posted by sailurman View Post
    That's next on the list.
  10. #38
    Site Sponsor Greg@IDParts's Avatar
    Mar 2017
    Hingham, Ma
    87
    Have you checked by the EGR valve? Maybe one of the gaskets is failing causing a leak.
    MRO1791 likes this.
    IDParts.com is the only parts store dedicated to the Cruze diesel.
    From timing belt kits to brake sets and suspension, Hidden Content
    has the parts and knowledgeable staff you need for your Cruze diesel!
    Call us 888-444-7951 or visit our Hidden Content
  11. #39
    3rd Gear
    Sep 2016
    Washington State
    622
    Quote Originally Posted by HarleyGTP View Post
    My 2015 had a similar very slow leak, just a hint of smell. Dealership never could find it, and it still has the UV dye added. After a while it appears to have stopped. Have not seen any further loss of coolant, nor smell.
    Sent from my Moto G (4) using Tapatalk
    2x 2018 Cruze TD (1- Manual, 1- Auto), 2017 Cruze TD Auto, 2015 Cruze TD, 2009 Dodge Ram Cummins, former 2012 VW Jetta TDI
  1. 2014 diesel - coolant issue??
    By SCR3AMZ in forum Gen1 Diesel Technical Discussion
    Last Post: 12-18-2016, 07:13 AM
  2. 2014 Diesel Cruze exhaust leak
    By Nickhose14 in forum Gen1 Diesel Technical Discussion
    Last Post: 08-12-2015, 06:25 AM
  3. Replies: 1
    Last Post: 08-28-2014, 02:19 PM
  4. Slow tire leak??
    By benefactr in forum Gen1 Wheels, Tires, Brakes, & Suspension
    Last Post: 04-23-2014, 09:56 AM
