Broken exhaust leading to Particulate Sensor and NOx2 codes? - Page 2
Results 11 to 20 of 37
Like Tree9Likes
Thread: Broken exhaust leading to Particulate Sensor and NOx2 codes?
    MP81 is offline [OP]
    MP81's Avatar
    Washington Township, MI
    3,627
    Yeah, when she goes to work out, it's maybe an hour or so after work, so the car isn't too cold, thankfully. But going to/from work, it definitely gets up to temp just fine.
    I have to imagine this all was caused from the exhaust being wide open and corroding the **** out of the sensors...because exhaust bolts rust and break in less than 4 years and less than 72k miles...probably broke around 65k if I were to guess when I started hearing what I thought was a heat shield.
    Quick reply to this message Reply
    May 2015
    2,219
    Guess I need to look at the bolts and maybe replace with something more corriosion resistant proactively
    2018 Chevrolet Cruze Sedan Premier RS 11k
    2003 Buick Park Avenue 80k
    2004 Ford F-150 Reg Cab, 4.2L 45k
    2005 Mercedes E320 CDI 190k
    2015 Chevrolet Cruze CTD 71k traded
    2004 Cadillac Deville DHS 90k SOLD
    2002 Ford F-150 extended cab 4.6L 133k. SOLD
    Aug 2015
    NJ
    130
    Interesting. I had P11D7 for the rear NoX sensor but it never caused a countdown. Would just come up every time I reset the CEL. Ordered a new one off rock auto and installed myself ($600+ is highway robbery for that!). Really not hard at all, same procedure to get to the fuel filter.
    Also had a failed PM sensor, was replaced under warranty. Also never caused a countdown.
    Thankfully I proactively swapped out those flange studs or else I would probably be in the same boat!
    If I am reading correctly, you haven t replaced the NoX sensor and you probably should if it was exposed to any number of contaminates. I would also disconnect battery, can't hurt and maybe there are store values the pcm is getting confused with..
    2014 Cruze TD - Stock.
    1997 Camaro LT1 - 355/CC503/LTs/ORY/Corsa
    MP81's Avatar
    3,627
    Quote Originally Posted by IndyDiesel View Post
    Absolutely. I was planning on it, but I was too late, it seems.
    But I had no idea it was even running open after the SCR - it literally was not any bit louder.
    Quote Originally Posted by LulzT1 View Post
    Yep - I didn't think the NOx2 could cause a countdown, but apparently I was incorrect...
    Yeah, no way I'd pay $660 to have them do what I'm fully capable of doing - the only reason I was even considering it was in the interest of time. But they made the choice for me!
    May 2016
    MD
    300
    Something caught my eye a few posts ago so I figured I’d say something about it, but absolutely do NOT install a delete tune and leave the DPF in there. The car will never regen on that tune and it will load your dpf up with soot and fully block it, destroy it, and make your car run like crap, if at all. If you are installing a delete tune, you absolutely have to do the work to remove the dpf with it. Which honestly if I was in your situation, would be something I would have done already lol.
    MP81's Avatar
    3,627
    Yes, that is a good point - and thanks for the reminder about that.
    The next time it does something emissions related that isn't covered will probably be delete time.
    Off-Road Champion boraz's Avatar
    Aug 2013
    BC
    2,436
    yeah @diesel replaced his exhaust studs with SS
    i did as well, and replaced the gasket while i was at it, wasnt sure id be able to salvage it or not, it was cheap anyways.
    2014 Cruze Diesel - White 140,000 km
    1998 XJ 3" 31" Hakka LT 350,000 km
    1998 XJ 3" 31" Hakka LT 320,000 km
    MP81's Avatar
    3,627
    Since they just replaced the gasket, I'm going to clamp the two flanges down, and replace the hardware with stainless. Should keep everything good there, as it'll maintain clamp load while the bolt is swapped.
    MP81's Avatar
    3,627
    The new NOx2 sensor is supposed to be delivered tomorrow (would be delivered today if it were not for that inconveniently timed holiday...).
    I'm hoping that I'll be able to get the old sensor out...assuming I can, and I swap the sensor, will the countdown go away on its own?
    I don't have any means to do the "NOX Sensor Reset" I saw on the invoice, nor do I have to time to go to the dealer, maybe aside from Wednesday morning (before we go drive 4 hours) to have them do it...
    MP81's Avatar
    3,627
    Any info on whether or not some kind of reset is required after replacing the sensor? Or should the countdown go away, right then and there?
    I spent at least a solid hour beating on my 22mm wrench with a 1lb deadblow (so much for the coating on my 22mm, guess I'll need a free replacement ), to what appears to be absolutely no impact.
    I PB Blasted it 3 or 4 times, and then one last time after I called it quits. I'm borrowing my buddy's bottle torch. Hopefully that'll loosen the two up and I can get that stupid thing out. Otherwise it looks like we're renting a car for the trip (my tags will not be here in time for the Volt, and they expire...tomorrow). Because this stupid prone-to-repeat-failure of a sensor is not covered under special coverage.
  1. How To: Replace Diesel Particulate Matter Sensor (Exhaust Particulate Sensor)
    By revjpeterson in forum Gen1 Diesel How-To & DIY Library
    Last Post: 05-20-2019, 08:20 AM
  2. Particulate Matter Sensor Part No. (P24C6 code)
    By revjpeterson in forum Gen1 Diesel Technical Discussion
    Last Post: 02-15-2018, 06:44 PM
  3. 02 sensor codes
    By New2cruz in forum Gen1 1.4L Turbo
    Last Post: 07-12-2017, 04:11 PM
  4. Got 4 codes: 3 were P0324 and 1 was P0326; they all say knock sensor
    By alyssabesy in forum CruzeTalk New Member Introductions
    Last Post: 04-06-2017, 03:42 PM
  5. Special Policy 16018- Diesel Particulate Sensor Warranty
    By MilTownSHO in forum Gen1 Diesel General Discussion
    Last Post: 11-18-2016, 01:35 AM
