where is this coolant temp sensor located - 2014 Diesel
Results 1 to 7 of 7
  • 1 Post By Ma v e n
Thread: where is this coolant temp sensor located - 2014 Diesel
    dieseldr is offline [OP]
    Jul 2018
    Florida
    25
    Trying to find this sensor on the daughter’s 2014 Cruze Diesel.
    ACDELCO 55591401 COOLANT TEMPERATURE SENSOR
    goldcruzetempsensor
    The problem is that the temp gauge does not ever show any reading.
    We installed a ScanGauge-II, it reports 40 degrees at all times.
    So I bought the easy to find and replace green sensor NTK EF0067, will replace that to see if the temperature starts working again.
    greencruzetempsensor
    But can’t find where the other gold 90 degree one is. Searched and found where it is on a 2016, but notes said it is in a different location on the 2014 - any ideas?
    Thanks,
    Frank
    1985 Mercedes 300SD = Son's Diesel cruiser 366,000
    1985 Mercedes 300TD = Dad's Diesel wagon 199,000
    2000 Ford Powerstroke 7.3 Diesel = Dad’s daily driver 276,000
    2014 Chevy Cruze Diesel = Daughter’s 67,000
    2017 Winnebago View 24G = Diesel RV 8,000
    2018 Kubota Diesel ZD1211 = mutant lawnmower 25hrs
    2018 Chevy Equinox Diesel = Wife's new daily driver 12000 miles
    829
    The green one is the engine coolant temp sensor that mounts near the thermostat.
    The gold slip in style one is a radiator temperature sensor, or sometimes engine coolant temp #2, if your car has it it's on the passenger side end tank of the radiator.about halfway down. Near the hose
    dieseldr likes this.
    Reverend Red Bull
    revjpeterson's Avatar
    Oct 2013
    Rockford, MI
    1,007
    Quote Originally Posted by dieseldr View Post
    Since there were no Diesels produced for 2016 (2014-15 gen 1 and 2017-19 gen2), you might mistakenly found a diagram for a gasoline 1.4L instead of a 2.0 Diesel. (unless the 1.4 and 2.0 share a radiator and sensor...)
    Jul 2018
    Florida
    25
    We just completed replacing the green one, now the SCANGUAGE-II says it is 114 degrees, instead of 40 degrees, as before with the original (broken) green sensor!
    (It is 93 outside here today)
    Still no reading on the dashboard temp gauge, but it might not display any reading until the engine gets to ??? 150 ???
    Anyway, my daughter can use her SCANGUAGE to keep track of the temp now!!!
    Jul 2017
    234
    If it's 93 outside, 2 minutes of driving should get the gauge to come off the bottom. Any update on if the cluster gauge works now?
    Also, good to replace this as you did since the ECM needs to know the engine temperature to help fuel delivery.
    Jul 2018
    Florida
    25
    It turns out that my daughter had the SCANGUAGE set to read air intake temp, so 114 makes sense now.
    When she sets it to read coolant temp, it still says 40 degrees.
    So we have no idea what the $55 green sensor does.
    If it is providing data to the ECM, great. But the original one probably was not defective anyway.
    We are still looking for the $7, gold, "right angle" sensor , that one might operate the dashboard temp gauge.
    Jul 2018
    Florida
    25
    Plan "C":
    If I can't find or access the other sensor so the stock gauge can be made to read again, we can add a temperature gauge somewhere in the dashboard area.
    Is there anywhere in the cooling system plumbing that has a plug to remove or place I can drill & tap for a manual temperature gauge ?
  10. Remove Advertisements
  1. Radiator coolant temp sensor
    By Drich84 in forum Gen2 Service Issues
    Last Post: 07-03-2018, 09:58 PM
  2. Coolant level sensor broken? When will it say I'm low on coolant?
    By FireFox31 in forum Gen1 Service Issues
    Last Post: 04-02-2018, 11:40 AM
  3. PCV Valve - Where Is It Located?
    By Spaceme in forum Gen1 1.4L Turbo
    Last Post: 10-01-2016, 07:31 PM
  4. Normal coolant temp, thermostats, and AC off due to high engine temp
    By UpstateNYBill in forum Gen1 Service Issues
    Last Post: 08-18-2016, 12:19 AM
  5. Where's the oil filter located?
    By tecollins1 in forum Gen1 1.4L Turbo
    Last Post: 04-06-2012, 01:35 PM
