Special Coverage #14311: Negative Battery Cable - Page 24
Page 24 of 24 FirstFirst ... 14 22 23 24
Results 231 to 237 of 237
Like Tree141Likes
Thread: Special Coverage #14311: Negative Battery Cable
  1. #231
    Nov 2018
    I recently purchased a 2015 Cruze sedan with 50,000 miles and I experienced the same symptoms described in this post. My VIN wasn't covered under this recall so I simply purchased the cable and bolt online and changed them myself. It only took about 5 minutes and it solved the problem. Apparently, there are more cars affected by this problem than they are willing to acknowledge.
    Rivergoer likes this.
  3. #232
    5,751
    Quote Originally Posted by jdjones3109 View Post
    Good to know.
    Don't forget to introduce yourself and your Cruze here.
  4. #233
    Jan 2019
    4
    check all fuses
  6. #234
    Jan 2017
    22
    My 2014 Cruze diesel (93k miles) just started having some of the electrical issues that are described early in this thread. I have no problem changing the negative battery cable myself. Thank you all for your hard work on figuring this issue out. Could someone provide the part number that I should order? Thanks in advance.
    Cheers.
  7. #235
    Jul 2017
    234
    Quote Originally Posted by 89stingray454 View Post
    Cheers.
    You should still be under warranty for this. However, I replaced mine at my expense because every time the issue happened I couldn't reproduce it at the dealer. The $25 it cost me was cheaper than the fuel to drive back and forth each time I tried to have them look at it.
    2014 CTD I bought part #22754271 Runs about $20 online. You'll also need bolt #11561025 to connect the RVC negative cable to the terminal clamp (#3 in step 18 in link). However you could just buy the cable and take it to a local hardware store and find a bolt for 10 cents that would work.
    Here is a link that gives a better description of the bulletin and the parts. And for me, I did not have to do any of the modifications listed. I just removed the old cable and replaced the new one using the existing hardware except for the new bolt. Just make sure you don't forget to run the cable through the plastic loop.
    https://gm.oemdtc.com/1138/special-c...hevrolet-cruze
    weimerrj and Rivergoer like this.
  8. #236
    5th Gear
    weimerrj's Avatar
    Chesapeake, VA
    857
    If, like me, you have intermittent radio problems when starting - but everything else seems to work normally - this is likely the culprit. At least the RVC connection is. A temporary solution until you install the new cable is to remove the RVC cable, thoroughly clean the parts (eyelet, nut, and battery terminal) with a wire brush, and reinstall, firmly securing the nut. This seems to have corrected that problem.
    I've also been experiencing a lack of dynamic alternator voltage. I believe this same RVC connection is the problem, as the BCM controls that. It seems to work better in the short time I've driven it (it got down to 13.6 volts) but I'll find out for sure Monday.
    Also, the bolts required for the BCM on the new cable are M6-1.0 x 10mm flange bolts. About $1 for two at Home Depot.
    2012 Eco 6MT Blue Topaz Metallic (X2)
    2012 1LT RS 6MT Silver
  9. #237
    5th Gear
    weimerrj's Avatar
    Chesapeake, VA
    857
    One more thing - if you have an instrument cluster backlighting LED that works intermittently, this might fix that problem too. My tach had a "bad" LED that dimmed the area around the "4". I haven't had that problem since replacing the ground cable.
  10. Remove Advertisements
  1. Special Coverage 14232
    By Cabamino in forum General Discussion
    Last Post: 06-30-2016, 06:25 PM
  2. Free cable special is back!!!! 9/1-9/8
    By N.O.G8ter in forum Gen1 1.4L Turbo
    Last Post: 09-10-2012, 05:40 PM
  3. Labor day week cable special is here!!!! 9/1-9/8
    By N.O.G8ter in forum Gen1 1.8L
    Last Post: 09-06-2012, 11:29 AM
  4. Replies: 29
    Last Post: 04-15-2012, 01:08 PM
  5. Trifecta Performance Tune One Week Free Cable Special!!!!
    By InsaneSpeed in forum Gen1 1.4L Turbo
    Last Post: 04-15-2012, 03:14 AM
